Question about Sharp R306L 1100 Watts Microwave Oven
Do this microwave have a fuse my microwave wont turn on
  • Sharp Master
  • 9,047 Answers
Virtually all of them do.
You should make a new post including your brand and model number and let us know what was happening when it failed and how.
You can find links to helpful exploded view diagrams and part ordering help here.
I recommend that you bookmark that link to your favorites.We're happy to help you with free advice and we'd appreciate your thoughtful rating of our answer.
Posted on Apr 28, 2010
Tip
What to do when your microwave oven wont turn on after a electric storm.
When there is an electrical storm and your microwave oven is affected, and wont turn on. First you should un screw all the screws the two on the bottom right, then the two on the back of the microwave case and then the two others on the left bottom. Then you need to lift up the cover case upwards and then towards the back until the case is completly off. Then you must blow off the dust with a compreser and make sure thatall conections in side are fit tight, then look for the fuse. Some fuses are located on the right uper side of the microwave in a black little box with two cables and two screws, or it can also be located on the bottom of the microwave or the back panel. First unscrew the the containing unit for the fuse then pull the two cables from the conection and set them apart from each other if needed label them with a and b then with a small flat screw driver push the tabs on the containing case of fuse box and pull apart. Then a small shaft and spring will come out make sure to set them in the order they came out first the shaft then the spring. Then the fuse is at the bottom of the box in side, turn it up side down and the fuse will fall out. Then change the fuse "20" amp fuses needed in most microwaves but check the containg unit and see proper fuse amp. then installing method is reverse of taking apart. Remeber to make sure that all conections are not loose and falling. when done your microwave oven will work again.
on Aug 22, 2010 | Microwave Ovens
Microwave wont turn on
unplug take cases off. look for fuse. if fuse is blown. go get new one should work.
Apr 03, 2014 | Magic Chef MCD990W Microwave Oven
Do my microwave havea fuse because it wont turn
Yes, there is usually a 2 amp fuse located on the inside near the where the electrical cord feeds into the power supply. There might also be another fuse as well, be sure to check all around the power supply to be sure that there is only one fuse.
Plugging your microwave into an extension cord that is not rated for its use, or plugging the microwave into an un-grounded electrical socket could cause that fuse to blow.
I hope that this information was helpful to you in any way.
Apr 27, 2010 | Sharp R306L 1100 Watts Microwave Oven
Cuisinart CMW-100 , wont heat or turn the table? all else o.k.
We changed the 20amp fuse and that was not the problem so we returned it to Macy's. If anyone knows of a reliable brand of microwave today please let us know. All the reviews on microwave ovens recently are bad.
Jul 30, 2009 | Cuisinart CMW-100 Microwave Oven
MICROWAVE WONT HEAT
the lock on the door could be loose so the microwave light will turn on but it wont heat u should press on the door or buy a new one emai me at chattarbox24_7@yahoo.com
Jul 21, 2009 | Microwave Ovens
Ge spacemaker jvm1533 is dead wont turn on
check the circuit breaker first it may be the fuse is blown The fuse may be located behind the grille following the power cord on the rside of the unit.
it may be a bad thermal fuse or oven thermostat.
Dec 24, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
Small fire n microwave
check mains supply at control circuit, and check all the high voltage circuit diode and condencers and magnetron.
Dec 20, 2007 | Whirlpool MH7140XF Microwave Oven
Sharp R306L 1100 Watts Microwave Oven Logo
29 people viewed this question
Top Sharp Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Sharp Microwave Oven Expert? Answer questions, earn points and help others
