Question about Whirlpool GU2400XTP Built-in Dishwasher
My dishwasher leaks. a small puddle is in front
My whirlpool GU2400XTP dishwasher leaks. a small puddle is in front on the floor
  • 5,911 Answers
The symptoms you describe, sounds like it could be caused by a worn door seal. Over time, these seals compress to the point where they no longer seal correctly, or food particles and grime get caught between the door and seal and leave small air gaps.
The following link explains some of the common causes of dishwasher leaks and what you can do to prevent them:
http://www.fixya.com/support/r3555822-my_dishwasher_leaks
The part number for a replacement gasket for the model number you provided is 8268888.
This is a very simple repair. If you have questions, or require additional assistance, please post back and let me know. hope this helps you.
Posted on Apr 28, 2010
  • Jeff Rockwell
    Jeff Rockwell Apr 28, 2010
    Replacement part (if required) can be purchased at any of the following websites:
    searspartsdirect.com
    pcappliancerepair.com
    appliancepartspros.com
    repairclinic.com
    All these sites are reputable and have great service. Prices vary between them, so shop and compare. The first three sites I have listed include helpful exploded view parts illustrations to assist you in locating and properly identifying any parts you may need.
Leaking door
Here is a tip that I wrote about dishwashers and them leaking.
Leaking Dishwasher
heatman101
Jun 08, 2010 | Whirlpool GU2400XTP Built-in Dishwasher
Purchasing this Whirlpool dishwasher
probably a new one. lifespan is 10 years average
Apr 05, 2010 | Whirlpool GU2400XTP Built-in Dishwasher
I have a Whirlpool Gold Series dishwasher installed in 2000. I started having water leaking on the floor from the bottom of the door. Is their a gasket that failed or needs replacing? Wayne
You have check where the leak orginates from.If it is from the frame you to check the gaskets. If the machine is old chances of the gasket becoming hard is possible.
Try cleaning the body of the machine Gasket pressing area.
Apr 01, 2010 | Whirlpool GU2400XTP Built-in Dishwasher
Whirlpool Front load washer - Water leaking
I would check to see if you have a hole or crack in the rubber boot inside the door. Open the door and seperate the fold in the rubber boot and check for a leak. If something sharp was left in someones pocket it will get stuck in this part of the bood.
Dec 28, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Water leaks onto the floor
  1. open the bottom panel 2-4 screw
  2. take a flashlight and turn the machine on
  3. see where it come from
  4. if you need take the unit out a bit from the counter
  5. check it all around to find the sorce of the leak
  6. good luck its EZ :)
Mar 11, 2009 | Whirlpool GU2400XTP Built-in Dishwasher
NOT DRAINING AND WATER ON FLOOR
hi ya,there is a blockage in your waste pipe take it off and clean it out i had the same prob about 2 months ago
Feb 05, 2009 | Whirlpool GU2400XTP Built-in Dishwasher
Puddle on the floor, 36" diag. SW of Dishwasher door after cycle
TO MUCH SOAP RUN A FEW TIMES WITH OUT ANY AND STOP USE THE PACK OF SOAP
Dec 03, 2008 | Whirlpool 24 in. DU1055XTPS Stainless...
Whirlpool dishwasher.
reach inside your d/w and jiggle the mushroom shaped float switch located on floor of d/w. should move freely up and down if its stuck up(or something lodged under it your unit wont fill with water
Feb 28, 2008 | Whirlpool GU2400XTP Built-in Dishwasher
Whirlpool GU2400XTP Built-in Dishwasher Logo
306 people viewed this question
Top Whirlpool Dishwashers Experts
Oloyede Monsuru
Mike
Are you a Whirlpool Dishwasher Expert? Answer questions, earn points and help others
