Question about Compaq Presario R3000 Notebook
Compaq pressario r3000
My laptopr wont start up (no windows / screen doesnt come alive). I have tried holding down the power button for 5 secs and the release. Power button lights up but doest get the engine rolling. The origin of the problem may be that a few days ago I had a message on windows start up that it needed to "checkdisk" (through 3 stages), the laptop then worked. I did a disk clean up and all ok. I then did a defrag and the dr defraf analysis said there were a few errors and then during defrag the screen went blank. I now have a computer I try to start up and the screen will only come alive about 1 in 50 times. I'm concerned that my power on- off is having an impact. please help
    Genius:
  • 1,913 Answers
Your some sys files are missing
repair your window.
check your ram , hdd, smps power cable ,earthing pro
check hitting event, check your bord dont touch the cabinet
Posted on Mar 24, 2008
    Guru:
  • 55 Answers
First
reseat the ram
reseat the atx connection
reseat the HDD
swap the HDD cabled from the CD/DVD cable
try to go to BIOS if it goes to BIOS then do a BIOS default if it goes to the BIOS then it is an software issuer u need to run a recovery means that u need to reformat the HDD u can do that in compaq by tapping F11 when the computer restarts ...........now if it does not go to the BIOS then it is a HARDWARE issue ...
do a ram test ....if the computer gived contious beep sound without the ram not plugged in then the motherboard is ok...if not then the mother board needs to be replaced .....if everything is done then the power supplywill be replaced
Posted on Mar 27, 2008
SOURCE:
Blocked my ipad
try holding down the power and the menu button for ten sec it should power off release the menu button the screen should turn back on then release power it should go into a reset mode.if it doesnt work that way try the opposite hold both power and menu then release power first then wait ten sec to release the menu. that should work
Dec 29, 2012 | Apple Ipad I-pad
Wireless internet wont connect
Go to windows logo
in search box type cmd
in black screen type ipconfig /release
when completed type ipconfig /renew
try again if still no go do the following
reset to factory default
press and hold reset button during the whole process and only release when completed.
1)press reset button 30 seconds
2)remove power cable 30 sec
3)plug in power cable 30 sec and then release.
You should no be set for 192.168.1.1
username admin
password is password
If all fails check to see if the box is checked for wireless
Apr 04, 2012 | NetGear WGR614 Router
It said to update so i clicked yes now it say reattch ur your hard drive and i did and now it wont work
the xbox doesnt come on? try unpluging the power cable from the xbox and the wall then take off your harddrive for 30 secs reattach everything hold down the sync button on the xbox and while holding that down press the power button, release the sync button after 30secs or until you boot up to the avatar, if this dont work check what colour light is on your power brick when you press the power button on? hope this helps?
Jan 26, 2010 | Microsoft Xbox 360 Console
My iphone is frozen at the apple logo screen and wont power down or sync with itunes. How do I fix this?
Have you tried holding the power button and the home key together. Hold until unit reboots and once apple logo appears, release both buttons. If this doesnt work try this below.
Try launching I Tunes on PC without I phone connected. Then make sure I Phone is switched off. Now hold down the home key (square at bottom of screen) Whilst still holding home key plug in your I Phone usb lead. I Tunes should identify you I Phone after few seconds and prompt " detected I Phone in recovery mode" (or similar) it should then prompt 'yes' or 'no' to do recovery. Select yes and let it start. This should resolve this issue as it did on my 3G version.
If still no luck search FAQ's section on www.apple.com
Hope that works/helps?
Oct 14, 2009 | Apple iPhone 3G
Iphone wont reboot
With phone off connect to itunes and then hold home and power buttons for 6 secs. then release power still holding home until itunes sees phone. If that doesnt work with phone off hold home and plug in phone to computer and see if itunes sees phone. Then restore
Aug 08, 2009 | Apple iPhone 3G Black Smartphone
Alarm light on and u051 error mx310
Hi
You’ll need to reset your printer to clear the ink counters, after resetting it’ll not display the error code again. Follow this procedure to reset the printer--
1. Power off the printer.
2. Holding the stop/reset button, press and hold power button also. Hold both buttons together for 5 secs.
3. Still holding the power button, release the stop/reset buton, then press the stop/reset button twice.
4. Release power button (the screen should now say 'Service Mode').
5. Wait until the power button lights steady green, then press the stop/reset button three times with a 3 sec space between each press. On the 3rd press the indicator should turn steady orange.
6. Press the power button once, (the orange light should go off).
7. Open the printer and remove both cartridges. Wait for 10 seconds. Replace the cartridges and close printer. Wait for 30 seconds.
8. Press the power button, and wait until printer has shut down.
9. Press power button to power up. The printer will feed one piece of paper, then ask you to set the language.
10. The page counter is now reset.
Please rate the solution & revert for further assistance.
Thanks
Rylee
Jul 29, 2009 | Canon PIXMA MX310 All-In-One Printer
Password protected and wont power up and cant connect to itunes
here's how:
1. Turn on your iPod (in my case it would only get as far as displaying the Apple logo
2. Hold the power and home buttons down (the iPod will power off after 10 seconds, but keep holding those buttons down)
3. After the iPod powers off, release the power button (but keep holding the home button down)
4. After a couple more seconds, you should hear that magical “ding dong” that means the iPod is coming back alive, and that Windows has detected it. You may even see a little “New hardware” popup in Windows. It is now safe to release the home button, and your iPod is in DFU mode.
5. Now iTunes will see it as a DFU’ed iPod and should ask you to automatically restore its firmware.
6. iTunes has to download the new firmware, and it takes a while, so go make a sandwich.
Jul 25, 2009 | Apple iPod touch
My ipod says www.apple.com/support/ipod my ipod not started, not charging, ipod sad face coming on the screen. my product number is pe435a
Jul 25, 2009 | BoxWave Corporation Apple iPod mini (6GB)...
My iphone hanged up!
1. Turn on your iPhone (in my case it would only get as far as displaying the Apple logo
2. Hold the power and home buttons down (the iPhone will power off after 10 seconds, but keep holding those buttons down)
3. After the iPhone powers off, release the power button (but keep holding the home button down)
4. After a couple more seconds, you should hear that magical “ding dong” that means the iPhone is coming back alive, and that Windows has detected it. You may even see a little “New hardware” popup in Windows. It is now safe to release the home button, and your iPhone is in DFU mode.
7.jailbreak your iphone and unlock.
8.here's how to jailbreak your iphone:http://www.iclarified.com/entries/index.php?caid=2&scid=11&seid=2
9.here's how to unlock your iphone:http://www.iclarified.com/entries/index.php?caid=2&scid=11&seid=1
Jul 25, 2009 | Apple Cell Phones
Hangs up on start as I see apple sign on the screen,
5. Now iTunes will see it as a DFU’ed iPhone and should ask you to automatically restore its firmware.
Jul 24, 2009 | Apple iPhone Smartphone
Compaq Presario R3000 Notebook Logo
200 people viewed this question
Top Compaq Computers & Internet Experts
Ekse
Thomas F. Schneider
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
