Question about Sanyo Televison & Video
I HAVE A SONY DLP TV MODEL#KDS-60A2020. RED POWER LIGHT IS FLASHING.TV WONT TURN ON. COULD YOU PLEASE TEL ME WHAT IS THE PROBLEM. NURUL
  • 1 more comment
  • NURUL HASAN Apr 27, 2010
    yes, it red power light is flashing with a pause of three sec.
    its flashes 6 times before it pause.
    thanks for tour coments, appriciated. nurul
  • 10,594 Answers
Red power/ standby light would be flashing in sequence with 3 seconds long pause, please count its flashing from pause to pause and let me know as its an error code that indicates problem section in tv.
Any further info like how this problem occurred would also be helpful to diagnose problem.
Thanks.
Posted on Apr 27, 2010
  • Shahid Electronics
    Shahid Electronics Apr 27, 2010
    Please count how many times red light flashing between pause to pause, like 2 times, 3 times, 4, 5 times etc.
    OK, thanks.
    6 times red light flashing shows problem with low voltage power supply (+5 Volt) and few circuit boards like A, B and M needs to be tested by qualified tech.
    It seems hardware failure, however, unplug tv from AC wall socket for 5-10 minutes to get it reset, replug back in and turn it On and check.
    If problem still not solved then qualified local tech presence is needed to check above mentioned circuits of tv.
    Hope this info will help you.
    Thanks.
My sony kds 60a2020 won't come on. When I push the
That is a error code and in several of these sets it means thermal fuse is blown--Google the model number with owner manual or service manual to learn for sure.
Jun 07, 2012 | Sony Televison & Video
I have a Sony KDS-60A2020. TV went blank. No flashing lights. I have sound, but the screen is blank.
have you tried a power reset, unplug all components from the TV unplug it from the wall, then push and hold the power button for about 30 seconds, then plug all components back in, plug it into to wall then turn it on again.
Jan 14, 2012 | Sony KDS-60A2020 60" HDTV
I have a sony kds 60a2020. the lamp sensor light was flashing and no picture. i bought a new lamp and installed it and now all i get is red power light flashing three times. as much as i can tell am ...
A lot of these had problems with the lamp door; you need to remove the door and take a careful look at it edgewise---heat from the lamp can warp the door.
Notice the small plastic peg on the back of the door--when installed it engages a lever which is a safety switch so set cannot be operated with door removed.
If door appears slightly warped what I do is engage the lever (usually tiny and blue in color) and turn the set on.
WARNING: IF SET COMES ON DO NOT LOOK AT LIGHT FROM LAMP DIRECTLY. If set works with lever engaged you need to replace the door (EBAY has sellers with most of them) and DO NOT OPERATE SET WITH DOOR REMOVED OR REPLACE OUTER SHIELD AS HEAT FROM LAMP CAN DAMAGE THAT WITH DOOR REMOVED.
Before you rate this solution let me know if you have questions or what you find; engaging the lever will either rule the door out or confirm it is your problem.
SD TECH
Jul 09, 2011 | Sony KDS-60A2020 60" HDTV
The tv went blank @ the red led is flashing continuosly sony kds-60a2020
If its lamp light on tv front that is blinking red then lamp is dead/ broken and need to be replaced. Lamp replacement procedure is easy and written in user mnaual of tv.
If it is standby/ power light that is blinking then please count how many times it is blinking after three seconds pause and let me know to diagnose tv problem because it is an error code that has info in its blinking.
Thanks.
Apr 03, 2011 | Sony KDS-60A2020 60" HDTV
Replace bulb tv wont turn on
make sure the lamp and lamp door are seated properly. does it blink any codes. 3 blinks is lamp or lamp door not seated properly
Jun 25, 2009 | Sony KDS-60A2020 60" HDTV
No picture, and ren lamp light goes on
You need to buy a replacement lamp, the part number is XL-5200, make sure you get the one with the housing, it will make installation much easier. You can pull out the old lamp from the access panel on the right of the TV.
Jan 03, 2009 | Sony KDS-60A2020 60" HDTV
Televison & Video Logo
89 people viewed this question
Top Sanyo Televison & Video Experts
 Grubhead
Grubhead
Are you a Sanyo Televison and Video Expert? Answer questions, earn points and help others
