Question about Kenmore 53502 / 53504 Side by Side Refrigerator
KENMORE 53504300 WATER ON FLOOR AFTER WEEKEND AWAY, FREEZER THAWED OUT, REFRIGERATOR SEAMS COLD, REMOVED REAR CARDBOARD COVER, FAN IS FUNCTIONAL, HEAR INTERMITTANT CLICKING AT SMALL WHITE BOX AT COMPRESSOR (RELAY?) COMPRESSOR IS HOT AND DOESNT SEAM TO BE WORKING. COULD I HAVE A RELAY PROBLEM OR A COMPRSSOR ISSUE?
  • Kenmore Master
  • 1,606 Answers
You have a bad relay . Replace the " white box " ( it just pushes onto the compressor ) with maybe a small wire to secure it . Take your complete model number , including the 3 numbers in front of the ones you gave , to make sure you get the correct part .
Posted on Apr 28, 2010
My drip pan under the frig over flows with water then on to my floor. both fans work. Air flow from freezer to frig and back seams good. Tube going to drip pan is clean. Seals looks good and clean. MOD...
I had a similar problem with my Whirlpool model 6ED25DQFW side by side refrigerator/freezer with ice maker/water dispenser. Water was slowly pooling under the refrigerator under the freezer section. The defrost drain pipe was not blocked, the condenser fan was running, the drip pan was not leaking.
The source of the leak was found to be the icemaker solenoid block plastic body which had a pinhole leak.
To fix requires either plastic welding, or replacement of the solenoid block plastic body.
To access the solenoid block firstly requires removal of the cardboard cover, located at the lower rear of the refrigerator.
Aug 16, 2011 | Whirlpool 25.6 cu. ft. Side-by-Side...
Tip
How to fix a leak inside a refrigerator
Turn off the refrigerator. Remove the rear panel and floor cover from the freezer. You will see a lot of ice covering everything. Remove/thaw this ice.
In the back of the freezer, under the coils is a drain. When the defroster runs and melts the ice on the coils, the water is supposed to run down the drain to a pan where it is evaporated by a fan under the refrigerator. Often, this drain freezes shut. Then, the water has no place to go but though the vent into the refrigerator.
Melt the ice in this drain with a hair dryer or small quantities of hot water. You will know the drain is clear when the water level suddenly drops. Finish drying everything in the freezer and replace the panels.
Now, you will no longer have water dripping inside your refrigerator.
on Feb 06, 2010 | Refrigerators
Refrigerator in center between refrig. and freezer is very hot
most likely problem is a failed condenser fan motor. pull your refrig away from the wall and then remove rear cardboard cover. you will see a fan motor that cools the compressor and condenser coils. heck to see if the fan is jammed with insulation or other objects. if the motor needs to be replaced you can place a portable house fan blowing int the rear to keep components cool until unit is repaired. thanks peyton
Feb 28, 2011 | Kenmore Refrigerators
Kenmore Refrig Model # 75922400 top Freezer. Freezer is freezing really good but frig is around 46 - 48 degrees at coldest setting. We discovered ice on vents in freezer and thawed them out with hair...
Sounds like a defrost failure.
Look on the back wall of the freezer from the inside.
If it is covered in ice your defrost system has failed.
Also check the fan motor in the freezer.
If it is not running it must be replaced.
Feb 24, 2011 | Kenmore 18.9 cu. ft. Top Mount...
Kenmore fridge, 7 yrs old, freezer on top. Water sprays periodically from somewhere at top inside of refrigerator, apparently from downward pointing chute or holes on either side. This seems to be part of...
Removed inside rear and floor panels of freezer (ice machine also) as ably advised by your tech. Found ice damming he suspected underneath floor panel. Thawed overnight with pot of hot water in freezer. could see that small rear drain tube was iced shut; why all water going into fridge below. Avoided floor mess from thawing water flow to evaporation pan on floor by tilting unit forward on blocks and laying several old towels inside freezer door to catch water that would run out. Also placed some in front at base of unit on kitchen floor. Continuing to thaw pipe to unclog, it is iced some way down, again as tech said it might. Will reassemble and be careful with freezer setting, in case it may have been too cold. Also, some food crumbs had found their way behind panel near this drain tube and may have fallen in to block it. Will clean out any remaining.
Jan 05, 2010 | Kenmore Refrigerators
Fridge working off/on
If the noise was coming from the compressor when it was cutting off or starting, it was the internal mounts of the compressor and the compressor will have to be replaced. If the noise was a fan, it may have stopped. One is in the freezer behind the rear cover and one is underneath where the compressor is behind the cardboard cover.
Dec 31, 2009 | Whirlpool ED2FHSS Side by Side...
Freezer stopped freezing on my side by side ED25TEXHW02
check the Ampere of the compressor. if below 60% load from the rating found in the labels your freon gas is out.
Jun 10, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Ice under freezer floor, water in fridge (drain clogged)
in the freezer remove the cover plate where the fan is an insert a pipe cleaner into the drainage tube opening.
Apr 28, 2009 | Kenmore 20.6 cu. ft. Top Freezer...
Water leaking into bottom of freezer and on rto floor in front. Kenmore elite bootom freezer 596 series
Drain hose clogged. Removed rear panel and blew out hose. draining fine and no water leaking into bottom of freezer or floor. Be sure to thaw out drain and tray before you return to service.
Sep 14, 2008 | Kenmore Refrigerators
Kenmore 53502 / 53504 Side by Side Refrigerator Logo
122 people viewed this question
Top Kenmore Refrigerators Experts
Sal DeAngelo
Jim Goldsmith
Jim Goldsmith
Jude24
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
