Question about One For All URC4220 Remote Control
Remote code for RCA DTA 800 B1L
Hello, The Original remote quit working, So I bought a RCA universal remote control RCR314WZ. I need the code for (DTA800B1 B1L) converter box. so the remote will control it
Some RCA universal remotes list STB codes but you can try using code search to find something that can handle some or all functions. If a search through all codes contained in the remote does not succeed, you may have to try a different universal remote. All universal remotes do not contain all possible codes.
Jan 07, 2017 | RCA Televison & Video
I have 37LC50CB LG tv. When I turn on with new DTA remote control come up channel # 56-1 and cloud(nothing) on screen Then I...
Your DTA remote cannot turn on your LG TV. Find the red/white/yellow cable that was in the box with your DTA and connect it between the appropriate RCA outputs on the rear of the DTA and the corresponding RCA inputs on the rear panel of your TV. Disconnect the cable connected between your DTA and the antenna input of your TV. Be sure your DTA is on. Turn on your TV and select your DTA as the input source. You may have to press SET UP on your DTA remote to display the set up screen on your TV. Do a channel search and you should be all set.
Nov 24, 2016 | LG Televison & Video
How do I reset an ACCESS HD DTA 1030 converter box with an RCA UNIVERAL REMOTE and what is the code. Or how do I take the menu off tv.
Try turning your DTA 1030 off, then on to clear the menu.
You can use the code search feature of your RCA universal remote to find something that will handle your DTA 1030. If a search through all codes stored in the remote fails, you may have to try a different universal remote. All universal remotes, even others in the RCA "family" do not contain all possible codes.
May 22, 2016 | RCA Televison & Video
Use Universal Remote on DTA
I needed to setup my Vizio TV's remote to control the Cisco DTA 170HD. I was able to get it working by using the Scientific Atlanta code 01877. Follow this link to read the user manual for the Vizio and there are more codes posted in there.
http://store.vizio.com/documents/downloads/hdtv/VU42LF/Manual.pdf
Nov 24, 2013 | Televison & Video
I need to know how to access menu or run channel scan on rca dta 800b1l converter box without the remote
There is not a way, unless you get a universal remote, scan for the code to control the box, and then get into the menu.
Dec 18, 2011 | RCA (DTA800B1) Video Converter
Need Comcast DTA remote to control Panasonic TV/VCR combo
Try website 1-800-Remotes Factory original.To buy an exact remote or very close to the original.
Apr 25, 2010 | Broksonic CTSGT8118T 13 in. TV/VCR Combo
Need to program remote, don't have codes
RCA TV/VCR Combo Model T09085:
Comcast Digital Adapter Remote (DTA) Code is... 00000
Comcast Universal Remote - Red OK/Select Button (DTC)
Code is... 21479. This code controls TV On/Off and VCR All functions. I could'n find code for vol+/vol- and mute.
Oct 23, 2009 | Televison & Video
One For All URC4220 Remote Control Logo
155 people viewed this question
Top One For All Televison & Video Experts
Computer Repairing
Computer Repairing
Are you an One For All Televison and Video Expert? Answer questions, earn points and help others
