Question about Belkin N Wireless Modem-Router F5D8633au4A
13 hex pairs
I created my 13 hex pairs and i want ti input them into a laptop to create a shared connection [wireless] i created them using a passphrase.when i inout them i get an invalid code message.i tried lower case as well. is there a correct procedure or am i missing somthing
thanks
    Guru:
  • 825 Answers
Ok from your message i can understand that you have created 128bit WEP password..... i recommend you to use 64bitWEP password.... and in key1 i want you to enter only numbers manually instead of using HEX pairs....
in 128bitwep it will ask for 26 characters....you can also give a try by entering only numbers for it... still if you cant then go for 64bitwep and enter 10 characters(use only numbers).... this will resolve the issue....
Posted on Apr 28, 2010
Need to create password
Some later model wireless routers have the Password(ie.Encryption key) and the SSID already configured in the wireless router andthis information is printed on a label on the bottom of the router.
These settings can be used to configure the wireless card and wireless adaptersin your computer/laptop.
If these settings do not suit you, then it can be changed to suit yourrequirements.
The encryption key secures your data and wireless connection from unauthorizedaccess.To configure the wireless settings in the router, connect a LAN cablefrom your computer to the wireless router, then open a Browser on your computerand enter the router's configuration IP address, then enter the admin login andpassword and then go to the wireless settings and configure the SSID andEncryption key.
The router's encryption key can be a Passphrase or the WEP or WPA or WPA2key.If you use the Passphrase method select either WEP or WPA or WPA2 togenerate the encryption key. You can enter the WEP or WPA or WPA2 key with 8 to63 ASCII characters or 64 Hex digits.
Most people use Passphrase which is easier to remember eg. I was born inJanuary 1988.
The strongest and latest security is WPA2, the weakest and oldest is WEP. To connect to your wireless router from thecomputer/laptop, configure the wireless card in your computer/laptop with therouter's wireless settings ie SSID, plus the WPA or WPA2 encryption key. Thencomputer/laptops can communicate with your wireless router.
Jul 01, 2012 | Computers & Internet
Tip
How to setup Wireless security
So, you got a new wifi router and you can get online wirelessly, but you worry about your upstairs neighbor or the guy in the other building hopping onto your high-dollar internet connection and surfing who-knows-where without paying you a nickel. Here is how you put the brakes on that.
1. you must hard wire at least one of your computers into PORT 1 on the router. Login to that router (contact mfr for login details).
2. once logged in, select "Wireless security" (it might be called something slightly different, but essentially, it is the place where you activate a security key for the wifi signal).
3. Choose the style of encryption that you feel is best. A good general encryption is 64 bit WEP (13 digit Hexidecimal) setting. This setting works with wireless B and higher. If you are ONLY going to use wireless G, then 128 bit (26 digit hex) is stronger. You can also choose WPA, but I seem to have better luck with WEP.
4. you will be asked to choose a passphrase or keyword. something like "scoobydoo" or "goldilocks" or something familiar, like your first car "Oldsmobile" or "Cutlass" or the name of your long lost love, first born childs middle name. Any of those, but PLEASE remember it! this password will become encrypted into a 13 or 26 digit HEX key. Also, it may or may NOT matter, but in case it DOES matter, use all lower case letters when creating the phrase. Do NoT mIx ThEm lIkE tHis, or add !?><@& or any other special characters to it. make it a word that has meaning to you.
5. WRITE DOWN THE WORD and keep it in a wallet or safe place. The key will be generated. you can COPY and PASTE the key in a text (notepad) file along with the passphrase/keyword and save it in your main pc's my documents folder, or print it out and keep in your wallet/purse.
6. you will now APPLY this key and all your wifi computers will drop offline. Go to each one and input the keyphrase or the hexidecimal code (whichever it asks you for) and they will rejoin your wifi. If you want your friends to party at your place, they will need that wireless key as well.
7 Dont panic. if you mess up, press the RESET button on the router, and repeat.
on Dec 02, 2009 | Computers & Internet
Linksys 64bit passphrase
The passphrase is a phrase you create instead of using hex numbers (phrases are easier to remember than hex numbers) to setup the wireless encryption key.
To configure the Linksys wireless setting, connect a LAN cable from the Linksys LAN port to the computer's LAN port. Open a browser and enter the Linksys configuration URL
http://192.168.1.1
The default login = admin
The default PW = admin
Then go to the wireless settings and configure the SSID and WPA or WPA2 encryption.
Use a passphrase to setup the encryption key
To secure your wireless network from unauthorized access, please click on this link and follow my instructions :-
http://www.fixya.com/support/r3559128-wireless_router_security
Nov 08, 2010 | Linksys WRT300N Wireless Router
My father in law is having somebody steal his internet because he doesnt have password on it can anybody please help me out by telling me how to put a password on a ASUS WL- 520GC Router. his lost cd &...
Follow these steps and you should be able to set up a password protected connection. (NOTE: You should use the cable that came with your modem as the connection will be lost until you reconnect to the wireless after setting up a password protected network. It is not mandatory but it helps to keep the connection to the router while you are setting this up.)
1. Open up your web browser and type 192.168.1.1 in the URL address bar and select enter. This should open up the web page for your router.
2.Input the user id and password. The default for both are admin.
3. The security setting should be under the Wireless menu option on the left of the window.
4. There should be an option to select medium or high securty levels. I would go with medium as it is easier to set up and should provide the security you are looking for.
5. There should be an input for a passphrase. Input a passphrase that is easy for you and/or your father in law remember as it will be needed to set up your wireless device on your desktop or laptop.
6. Select generate keys or it may generate them automatically when you type in the passphrase ( I am not sure since I don't own this particular brand of modem)
6. Write down the passphrase and 1 of the 4 keycodes generated to use later.
7. Exit your modem setup after saving your changes.
8. Go to Control Panel and select Wireless Networks
9. Double click on the wireless network connection
10. Select Properties
11.Select Wireless Networks tab
12.Highlight your wireless network and select Properties
13.Select the proper Network Authentication method (WEP)
14. Select the proper Data Encryption (TKIP)
15.Input one of the keycodes created in step 6
16. Close everything out and save.
17. Disable your device and then enable your device. This will cause it to reset. When it comes back up it should automatically connect to your network.
If you have to select WPA instead of WEP you will follow the same steps. Hope this helps. Here is a link to the online manual if you need it.
http://support.asus.com/download/download.aspx?SLanguage=en-us
Sep 06, 2010 | ASUS WIRELESS ROUTER |WL-520G - RT...
Message when I try to connect wireless is I need
Check your router configuration under some sort of Wireless Encryption option. Essentially you or someone else set up a "passphrase" on that router which created either 64-bit or 128-bit encrypted keys from that phrase. You'll most likely find this passphrase under the Encryption information.
Mar 05, 2009 | Westell Wirespeed VersaLink...
Can't connect ibm laptops wep to wgr614
On my WGR under WIreless settings I have WEP, Automatic, 64bit, Key 1 checked, and a 10 character HEX key.
There is an SSID and when I log in via laptop, it askes for the key. I input my 10 character hex number and I'm logged in.
Carl
Dec 10, 2008 | Linksys BEFSR41 Cable/DSL Router W/4 Port...
Securing wireless router
Click here for a link to the instruction manual. All this was retrieved from p.48
First off make sure your wireless connection is working
1. On the Setup tab of the Router’s web-based utility, click the Enable radio button next to WEP. Then click the Edit WEP Settings button.
2. You will see the 2.4GHz, 54g, Wireless-G (WEP) screen (Figure C-1). Next to Default Transmit Key, select which WEP key (1-4) will be used when the
Router sends data. Make sure the receiving device is using the same key.
3. For the WEP Encryption drop-down box, select the level of WEP encryption you wish to use, 64-bit 10 hex digits or 128-bit 26 hex digits. Higher encryption levels offer higher levels of security, but due to the complexity
of the encryption, they may decrease network performance.
4. Instead of manually entering WEP keys, you can enter a Passphrase in the Passphrase field. This Passphrase is used to generate one or more WEP keys. It is case-sensitive and should not be longer than 16 alphanumeric characters. (This Passphrase function is compatible with Linksys wireless
products only. If you want to communicate with non-Linksys wireless products, enter the WEP key manually on the non-Linksys wireless products.)
After you enter the Passphrase, click the Generate button to create WEP keys.
Note: All Wireless-G and 802.11b devices in your network must use the same Passphrase or WEP key.
5. WEP keys enable you to create an encryption scheme for wireless LAN transmissions. If you are not using a Passphrase, then manually enter a set of values in each Key field. (Do not leave a key field blank, and do not enter all zeroes. These are not valid key values.) If you are using 64-bit WEP encryption, then the key must be exactly 10 hexadecimal characters in length. If you are using 128-bit WEP encryption, then the key must be exactly 26 hexadecimal characters in length. Valid hexadecimal characters are “0”-“9” and “A”-“F”.
6. Check all the values, and click theApply button to save your WEP settings and return to the Setup screen. To cancel any changes you’ve entered on this page, click the Cancel button. To get more information about the features, click the Help button.
Jun 15, 2008 | Linksys Wireless-G WRT54G Router
Belkin 54 encryption
1. Log into your Wireless Router or Access Point.
Open your web browser and type in the IP address of the Wireless
Router or Access Point. (The Router’s default is 192.168.2.1, the
Access Point’s default is 192.168.2.254.) Log into your Router by
clicking on the “Login” button in the top, right-hand corner of the
screen. You will be asked to enter your password. If you never set
a password, leave the password field blank and click “Submit”.
Click the “Wireless” tab on the left of your screen. Select
the “Encryption” or “Security” tab to get to the security
settings page.
2. Select “128-bit WEP” from the drop-down menu.
3. After selecting your WEP encryption mode, you can type in
your hex WEP key manually, or you can type in a passphrase
in the “Passphrase” field and click “Generate” to create a WEP
key from the passphrase. Click “Apply Changes” to finish. You
must now set all of your clients to match these settings. A hex
(hexadecimal) key is a combination of numbers and letters from
A—F and 0—9. For 128-bit WEP, you need to enter 26 hex keys.
For example:
C3 03 0F AF 4B B2 C3 D4 4B C3 D4 E7 E4 = 128-bit key
4. Click “Apply Changes” to finish. Encryption in the Wireless
Router is now set. Each of your computers on your wireless
network will now need to be configured with the same
security settings.
May 09, 2008 | Gateway Belkin 54g Wireless DSL/Cable...
NetGear WG111 802.11g/b Wireless Adapter
After a small amount of trouble, I have configured my Win 98 laptop to use
Netgear WG111v2 wireless modem to connect to my wireless router. I used
the driver from the CD that came with the modem, following the instructions and
got to the point, after rebooting a couple of times, where I was connected to the
router, but could not reach another computer on my network (or the outside world).
I double-clicked on the wireless model icon in the system tray and noticed that,
on the NetGear SMART WIZARD panel, the WEP key was set to use the
"Create from passphrase" option, even though I supplied the already generated key (the
hex numbers) during installation of the modem. (The modem was using the key
as a passphrase to create another key.)
To fix this, on the SMART WIZARD panel, I
selected the "Enter key manually" option and, er, entered the hex key (the one
the router/access point uses for security) manually.
I hit "Apply" on the Wizard and, lo and behold, I was pinging the rest of my network.
I rebooted one more time (I had some leftover bad settings in my "Network Connection"
TCP/IP entry for the WG111 connection; I reset them before the reboot
to allow my network to automatically assign an address) and I was then able
to view my favorite site (bythestadium) from my favorite browser (firefox)
Jan 29, 2008 | NetGear WG111 802.11g/b Wireless Adapter
Need to know the solution
Nov 20, 2007 | NetGear WG111 802.11g/b Wireless Adapter
Belkin N Wireless Modem-Router F5D8633au4A Logo
361 people viewed this question
Top Belkin Computers & Internet Experts
Prashant M
Prashant M
Are you a Belkin Computer and Internet Expert? Answer questions, earn points and help others
