Question about Oregon Scientific Electric PTO Clutch for Cub Cadet, MTD and Warner
Mower stopped dead. blades go, tractor starts and runs, won't move forward or backward, the transmission thingie rod is engaged. just finished mowing yard, riding to back and stopped moving.
  • 86 Answers
Broken drive belt
Posted on Apr 28, 2010
I need help putting rear end back together on a 10 hp30 Murray riding lawnmower
Safety and Preparation Serious injury can occur if the engine or mower blades accidentally start while you are working with lawn tractors. To prevent this, drive the Murray lawn tractor onto a flat work surface and disengage the mowing deck cutting blades. Engage the parking brake to keep the mower from moving; chock the wheels with a wooden block or brick. Adjust the mowing deck to the lowest position. Turn off the engine and remove the key from the ignition. While not necessary, you may even wish to disconnect the spark plug wire from the spark plug. Mowing Deck Removal You must remove the mowing deck on a Murray lawn tractor to gain access to the belts. Remove the adjustment rod hairpins, followed by the adjustment rod pins from the front left and right sides of the mowing deck. At the rear on the left and right sides, pull out the retaining hairpins and slide the mowing deck suspension links from the adjuster plates to separate the rear mowing deck from the frame. Remove the blade control rod stud, including the hairpin and washer, from the top of the blade control lever shift linkage at the left rear of the deck. Remove the front hanger rod, including the hairpin and flat washer that hold the rod in place. Loosen the belt guide retaining bolts with a socket wrench and remove the engine stack pulley belt so you can slide the mower deck out from under the tractor Transmission Drive Belt Installation Slide the new transmission drive belt between the engine stack pulley belt guides, over the belt guide plate and under the engine stack pulley. Fit the transmission drive belt around the top engine stack pulley. Push the free end of the transmission drive belt up through the transmission shifter hole in the lawn tractor floorboard. Slip the transmission drive belt loop over the transmission shifter. Pull the transmission drive belt down through the transmission shifter hole. Fit the transmission drive belt around the transmission drive pulley and tighten the transmission drive pulley belt guide retaining bolts to hold it in place. Fit the transmission drive belt flat side around the idler pulley. Slide the idler pulley onto the idler pulley stud while holding the belt in place. Tighten the transmission idler pulley retaining nut with a socket wrench to secure the idler pulley to the idler pulley stud. Mowing Deck Drive Belt Installation Pull back on the right side mowing deck mandrel pulley spring-tensioned belt retainer. Guide the new mowing deck drive belt around the right side mandrel pulley and release the belt retainer. Pull the drive belt spring-tensioned retainer away from the mowing deck idler pulley, guiding the deck drive belt around the idler pulley. Fit the mowing deck drive belt around the left side mandrel pulley and under the rear mowing deck cross link rod between the right and left side mandrel pulley. Slide the mowing deck under the right side lawn tractor frame, reconnecting the deck to the frame in reverse order of removal. Engage and disengage the mower deck while driving the mower to test the belt for proper operation.
Sep 28, 2016 | Murray Garden
Mower will not go forward .... it runs .... and the deck still engages but will not move forward or backward
i would inspect the belt the mower and the trans operate from different belts
Jul 10, 2012 | Garden
24 hp LA165 mower. While mowing the mower stopped moving. Engine runs, blades turning but won't move forward or backward (the side lock has been released and the pin at the back is pushed in) 11...
check the connecting rod to the tranny. follow the gear handle and you should find a rod connecting the handle to the axle make sure you're in neutral and adjust the rod until the handle starts to move
Jul 17, 2011 | John Deere 24HP VTwin Hydrostatic 48"...
The tractor will not go forward or backward it starts right up but will not engage
1) The drive belt between the engine and transmission has broken or jumped off a pulley.
OR
2) Your hydrostatic transmission is dead.
DO NOT STICK YOUR FINGERS UP INSIDE A RUNNING MOWER TO SEE IF THE DRIVE BELT IS MOVING.
Jul 01, 2010 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Mtd model series 790 mower wont move, belts are fine and transmission wont go in nuetral
mtd 1993 riding mower model 828 I was mowing then tractor stopped and wont go forward or backward It runs fine, and blades
seem fine. Drive belt looks fine.
Sep 17, 2009 | Mtd Garden
Sears lawn tractor. While mowing, ran over a
the branch probably got cought in the belt that runs the rearend it may have caused it to come off check the drive belt
Jun 06, 2009 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
Rider mower won't go forward or back
Ihave craftsman Lawn Tractor was cutting grass and it stop moving forward or backward. Can you help me
May 16, 2009 | Craftsman 20 Hp 42" Deck Lawn Tractor
Suddenly stopped driving...
Check for a worn belt first.Then check the linkage. Next jack the unit up and try to run it forward and reverse with the engine running.If there is any movement at all in either direction then check the fluid level to see if it is up to the top.The worst case is the hydro. unit has a stuck check valve or something broken inside.Hope some of this helps. donnyb60
Mar 23, 2009 | Garden
Oregon Scientific Electric PTO Clutch for Cub Cadet, MTD and Warner Logo
772 people viewed this question
Top Oregon Scientific Garden Experts
Dennis Key
Dennis Key
Colin Stickland
Colin Stickland
roeb
Are you an Oregon Scientific Garden Expert? Answer questions, earn points and help others
