Question about HP OfficeJet 7310 All-In-One InkJet Printer
How to remove a large black line in middle of
On my HP Officejut 7310 All in One, I need to know how to remove a large black line in middle of document when trying to fax and scan.
    Scholar:
  • 118 Answers
Unplug printer cables, replug in
take cartridges out, put back in making sure sure nothing is obstructing the ink dispensary on the cartridges and that they're clean
look in the printer where the cartridges go, making sure nothing is blocking the ink
check the rollers to make sure no paper is caught inside the printer
turn on printer and try this
hope this works and good luck
Posted on Apr 30, 2010
I have a Epson cx11 and get a black vertical line down the middle of scans and copies
Check your flat bed and Document feeder scanning glass need to be clean, if any dot or dust in scanning glass of document feeder it will appear a line, check this points first
1- Check printouts from computer or FAX if it is clean problem in scanning section
2- Check using Copying a blank paper using only Flatbed if it prints without any line its problem from document feeder Scanning glass
So solution is clean the Document feeder scanning glass using wet cloth, note careful about wet cloth switch off the machine and clean it
Feb 04, 2013 | Epson AcuLaser CX11NF Printer
How do i get rid of a black line that ahows up down the r side of scanned documents, there is no line on the originals
If you are using the Automatic Document Feeder (ADF) to scan, you may need to clean the scanner bar glass.
First test: See if the line appears when you scan on the flatbed. If so, it is probably a hardware failure.
If it appears only when using the ADF, you need to clean the ADF.
HP has a general diagnostic and cleaning procedure here:
https://h10025.www1.hp.com/ewfrf/wc/document?docname=c00846928&lc=en&dlc=en&cc=us&destPage=document&product=391182&lang=ru
Apr 13, 2011 | HP OfficeJet 7310 All-In-One InkJet...
The receiver of my FAXes says that there is a black line down the middle of each page. The FAX is a good copy-clear, etc.... but this line has to go. What can I do? Thanks, Donna
Dear Donna,
When a document is scanned from the top portion of the printer, it will loop around and output from underneath. The scanning glass on the far left side will have some debris on it. Lift the the lid exposing the glass portion, inspect for "stuff" on the glass, perhaps pen or white out. You can use a mild soap and lightly dampened cloth to remove any debris.
Good Luck,
Pre
Jan 14, 2011 | HP OfficeJet 6210 All-In-One InkJet...
Lines in fax
down the middle or on the side..
Aug 18, 2008 | HP OfficeJet 7310 All-In-One InkJet...
Black line scanning on digital sender
Yes. There will be an access cover / lid where the document goes in.
Open the cover, and you will see a thin glass, called the 'scan glass'.
Look in the middle of the glass. You will most likely find a glob of white-out, or ink on it.
Use rubbing alcohol to clean off the culprit.
Welcome to scanner / fax / copier troubleshooting 101!
Jun 18, 2008 | HP 9200c Flatbed Scanner
Vertical lines
hi,
I just want to know that which did you try to use to scan. is that by using the ADF (automatic document feeder) or using the scanner glass?
Jun 18, 2008 | HP OfficeJet 7310 All-In-One InkJet...
Scanner seems to jam when faxing, scanning or coppying
CLEAN THE DOCUMENT FEED ROLLERS ON TOP INSIDE DOCUMENT FEEDER CLEAN ALL ROLLERS WITH MICROFIBER CLOTH MOSITENED WITH WINDEX
Jan 17, 2008 | HP OfficeJet 7310 All-In-One InkJet...
HP OfficeJet 7310 All-In-One InkJet Printer Logo
135 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
