Question about Panasonic PT-61LCX65 61" Rear Projection HDTV
PT-61LCX65 Turned on one day and image is horizontally inverted like your looking at it through a mirror. Looks fine otherwise. This happens for all inputs and built in menus. Any ideas?
  • 58 Answers
Per panasonic's autorized tech website it is corrupt EEPROM data. It is corrected using the following jig with included instructions on how to perform software upgrade.
Correct symptoms using part LSUQ0100 jig that comes with instructions. (operation takes 6 mins)
Hope this helps.
Posted on Apr 03, 2008
How to mirror image an embroidery image?
After selecting the embroidery pattern, select ADJUST
Select Layout
Select the Horizontal Mirror Image key (looks like two
pyramids)
Oct 06, 2017 | Brother Sewing Machines
When you trun on my panasonic PT-61LCX65 tv it makes no sounds the light blinks green. and then red and turns off. what is wrong. i have looked at the buble and it looks fine.
does the TV bring out sound even as the screen display is dark?
How long have you been using this TV and have you ever changed the lamp/bulb? Problem should be from the TV lamp/bulb.
Have the lamp replaced and hopefully, your screen should be perfect as before.
Let me know if you need directions in replacing the lamp, even though it is very simple replace.
Yours sincerely.
Elect_Comp.
May 15, 2011 | Panasonic PT-61LCX65 61" Rear Projection...
I replaced my lamp on my PT-61LCX65 last year and
Depending on how much you watch this set the lamp could be out again, they don't have to look blown to be blown.
Sep 04, 2009 | Panasonic PT-61LCX65 61" Rear Projection...
Reset tv timer pt-61lcx65 after lamp installation
MAKE SURE LAMP DOOR IS COMPLETELY CLOSED,THATS WHY POWER LIGHT FLASHES YELLOW
Jan 10, 2009 | Panasonic PT-61LCX65 61" Rear Projection...
Panosonic PT-61LCX65 wont turn on, no power
Check your bulb. I had the same problem and it turned out that the bulb was shattered. At no time, did the lamp light turn on.
Jul 12, 2008 | Panasonic PT-61LCX65 61" Rear Projection...
Most likely the lamp will correct this issue.
Apr 08, 2008 | Panasonic PT-61LCX65 61" Rear Projection...
PT-61LCX65 image reversed
Per panasonic's autorized tech website5.gif it is corrupt EEPROM data. It is corrected using the following jig with included instructions on how to perform software5.gif upgrade.
hope this helps.
Mar 24, 2008 | Panasonic PT-61LCX65 61" Rear Projection...
Neon Pink Lines
"eprom upgrade" by Panasonic tech will solve the problem.
Jan 13, 2008 | Panasonic PT-61LCX65 61" Rear Projection...
Panasonic PT-61LCX65 61" Rear Projection HDTV Logo
280 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
