Question about Mantis Tiller Tines #1622 00 02
I have a mantis tiller, the tines won't turn, the engine IS seated to the flange. any ideas on a fix?
  • 54 Answers
If the motor rpms up without drag it might be a bad gear in the transfer case or a broken cable if it's a cable drive, could also be a bad or stuck clutch. Hope this helps
Posted on Apr 28, 2010
Engine runs tines dont
The following was extracted from the Mantis owners manual..
At some point, you may find that the tines won't turn when you press the throttle. This may mean the engine isn't sitting all the way down on the worm gear housing. Perhaps you've been using your Tiller
for several years. Or perhaps you've removed the engine for use with the Mantis hedge trimmer attachment, then replaced it. In either case, the flange bolt may have come loose and lifted the engine up.
If this happened you'll notice a gap between the bottom of the engine clutch case and the top of the worm gear housing.
To fix this, loosen the flange bolt. Take the engine off the worm gear housing. Notice the hex head on top of the drive shaft . Inside the clutch case, you'll find the clutch drum. Make sure the hex head
lines up with the clutch drum inside the clutch case. Then put the engine back on the worm gear housing. Make sure the plastic carrying handle is not under the fuel tank. If you've followed these steps properly, there will be no gap between the clutch case and the worm gear housing. Make sure you tighten the flange bolt.
Jun 12, 2015 | Mantis 2-Cycle Tiller
MDT Tiller starts and runs but tines won't turn
-Won out drive or driven gears.
Good luck
Mai
Jun 28, 2014 | Mantis 2-Cycle Tiller
When I Start Mantis Tilleer it starts in gear ( tines are turning)
The Mantis has a speed controlled automatic clutch.
Lower the idle speed by turning the idle screw counter clockwise. The idle screw is attached where the throttle cable meet the carb. The screw has a pointed end that resembles a pencil point.
The engine speed should be adjusted just above stalling.
If the tines turn even when the engine pull rope is pulled, the the clutch is defective and needs repairing.
j
Aug 03, 2013 | Mantis Tiller
Tines bent
I would call mantis - the tines are covered by a lifetime warranty, and they should send you replacements for just S&H... not a bad price to pay for new tines.
Jan 28, 2013 | Mantis 2-Cycle Tiller
Mantis tiller 4 cycle engine runs but tines won't turn
Hmmm... Just a thought, but you could try checking the tension screw in the front of the tiller - It may be turned out (Way) too loose
Jul 28, 2012 | Mantis Garden
Tines turning, mantis 2 cycle tiller
sounds like a piston seizure. are you using correct oil and ratio. carb could be going lean and causing the cylinder to over heat, adjust high speed mixing screw and hope no damage has resulted.
Jun 30, 2010 | Mantis 2-Cycle Tiller
Mantis 2 cycle - tines lose power.
I had this problem today. Loosen the flange bolt. Pull the engine off and check that the hex end of the shaft is lining up with the clutch pad in the engine-that it seats properly. Then make sure the shaft is seated all the way into the worm gear and put the engine back on. You will probably have to wiggle the shaft until it seats into the clutch. Tighten the flange bolt when the engine is seated flush with the worm housing (with no gap). That's all I did and the power is back up. Hopefully you still have your manual with the parts blow-up. (page 29?) BTW, have you checked that the wormgear is greased?
Jul 05, 2009 | Mantis 2-Cycle Tiller
Mantis tiller blades
Common problem with these small tillers.
The gear box needs replaced or repaired.
But first try removing the muffler and see if it helps any as it could be the muffler is stopped up since it runs a gas/oil mix.
Jun 24, 2009 | Mantis 2-Cycle Tiller
Engine runs fine on 2-cycle Mantis tiller, but tines won't turn when they touch ground. They turn when I start engine and when I "walk" the machine around, but if I try to till, they stop turning and...
Your problem is a common one on Mantis tillers. The engine sounds like it is not breathing properly. I have fixed dozens of these problems and it is almost always the spark arrestor clogged up. The spark arrestor is found inside a small housing on the muffler (easy to fix). There are 3 screws that need to be removed to get the muffler cover off, then you will see a small housing a little over an inch long with another 3 screws...remove them and you will see a small screen that is probably clogged. Clean it and the housing with a solvent (I usually use carb cleaner) then re-install the arrestor and reassemble the muffler cover. This will fix your problem about 80% of the time.
If that is not the problem you may need to fix the carburetor (take my advice and just buy a new one...not much more expensive than the repair kit and a lot simpler.
Jun 04, 2009 | Mantis Tiller
Mantis Tiller Tines #1622 00 02 Logo
592 people viewed this question
Top Mantis Garden Experts
paulfvincent
Jim Parker
Jim Parker
Mike Squire
Are you a Mantis Garden Expert? Answer questions, earn points and help others
