Sony kv40xbr800 with flash code 5.What and where is the problem
  • 7 more comments
  • mdfiore Apr 27, 2010
    Thanks for the reply.I have recently replaced the "D" board and have tried to make an adjustment,is this what you are referring to?. Thanks,Mark
    I have tried to adjust from one end to the other of the lower transformer adjust and the code still remaims.Seems to be a problem with lets say the edges of letters from the video menu,I have restored the factory default setting and tried the edge feature still a little blurred.
    I can measure volts ok.This is on the cx board but there wasn`t a problem before I changed the d board.I did however splice the transformer wires together that go to the cx board with good quality aircraft crimping tool.
    The wires are color coded red and white and they never came off the cx board,I just spliced in the middle to change the d board.I see g2 for measuring the volts What ground can I use?
    I connected the negative to what looks like a bonding on the crt which goes to the cx board and the positive to the white wire splice for g2 .Meter was set up for 1k vac ,switched tv on and no volts or "ol" for overload.
    Well you are right,no volts and a flashing code present.Does this mean the transformer is bad?
    Sorry,I understand now.I was able to turn tv on with channel button and there were no volts.I tried a second time but couldn`t get channel button to turn tv on.
    Thanks for your patience and help
  • mdfiore Apr 28, 2010
    I would like to mention one more clue to you that I`m not sure I made clear.Letters and figures have that "halo" effect around them that I cannot adjust.Video adjustments,reset factory and pallette adjustments where effective in reducing the halo,but picture was too dak to watch.Transformer voltage was such a slight adjustment it didn`t have any effect,focus was somewhat effective.Again all with flash code 5
  • 10,594 Answers
Standby red light flashing 5 times in KV-40XBR800 shows problem of "white balance failure" and possible reasons for that problem are appended below:
1- Video OUT (IC9001-IC9003) is faulty on CH, CX Board
2- CRT (picture tube) drive (IC2801) is faulty on B Board.
3- G2 (screen volts) is improperly adjusted.
You should have schematics to check ICs and G2 volts adjustment procedure is also mentioned in service manual.
Hope this info will help you.
Let me know if you have additional question.
Thanks.
Posted on Apr 27, 2010
  • 7 more comments
  • Shahid Electronics
    Shahid Electronics Apr 27, 2010
    Thanks,Mark
    OK,
    If tv shuts down after flash of bright screen then reduce screen volts and if screen remains dark and tv shuts down then increase screen volts.
    Screen volt control knob is located on flyback transformer as above is for focus and lower is for screen volts.
    Thanks.
    blurred.
    That seems screen volts output is not proper, it should be 1000V DC and should be at least 600 to 800 DC volts at G2 pin of CRT.
    I'm not sure about your expertise. If you know how to check/ measure these volts then test it with voltmeter.
    Right, are you sure focus and screen volts wires are connected in right places?
    Focus wire is bit thicker than screen volts wire. Focus wire will go in CRT connector and screen wire will go to couple of resistors that further connect with G2 pin of CRT.
    OK, CRT ground is fine to measure G2 volts
    overload.
    Prob of meter are in correct place, turn On tv by pressing channel button on tv front or its remote and test volts before tv gets Off again.
    In standby light flashing mode, no volts will appear at G2 point.
    No, I said to turn ON tv by pressing Channel buttons either on tv front or its remote.
    This will cancel protection mode and power will turn On so deflection circuit will work and you will get G2 volts for may be 2-3 seconds, enough time to get reading until tv turns Off / standby again.
    OK, please make sure all connectors are plugged back in securely after D Board replacement.
    If every thing seems fine then D Board is suspected because its not working properly.
    Contact your part source for another D Board.
    No problem, I tried to help you out in all possible ways over internet.
    Shahid Electronics Apr 28, 2010
    G2 of picture tube is not getting volts (screen volts) and causing dark picture that ended up with white balance error of 5 blinks.
    Disconnect screen volt wire from picture tube circuit board that is coming from flyback transformer, get ready to take reading of screen volts in multimeter, turn on tv and see do you get volts on disconnected screen volt wire?
    If yes, that means flyback is working properly and providing screen volts, problem lies in picture tube circuit board.
    and if screen volts still missing then flyback transformer seems bad.
Kv40xbr800 2 flashes
Two blinks - B+ over current protection (OCP), unit goes to the standby mode then displays the 2 blink fault. Could be a short in the power supply of any of the circuits.
For more details, visit the site
Electro-help. Type in the site name, in the search box of your Google or Yahoo search engine, and click it to open.
May 11, 2012 | Sony Kv-40xbr800 Fd Trinitronr Xbrr Wegatm...
Tip
SONY PFM-42B1E FLASHING ERROR CODES
Ok i have here the problems that occur when the red standby led flashes on these sets which is an error code.
2 FLASHES ( PAUSE ) 2 FLASHES = X SUS TEMP (DD CON)
3 FLASHES ( PAUSE ) 3 FLASHES = Y SUS TEMP (I/O BLOCK)
4 FLASHES ( PAUSE ) 4 FLASHES = CENTRE TEMP
5 FLASHES ( PAUSE ) 5 FLASHES = DIGITAL 5VOLT
6 FLASHES ( PAUSE ) 6 FLASHES = PDP PANEL FAULTY
I hope that helps you cheers.
on Nov 11, 2007 | Sony PFM-42B1 42 in. HD-Ready Plasma...
How can I change my Sony RDR-VX530 to a multi region DVD planer?
Follow the below instructions closely;
1. In order for this hack to work, you will have to send an infra-red code to your player with a OneForAll remote such as the OneForAll 6 (or URC7560) or OneForAll 4 (or URC7740) or OneForAll 4 Digital, or One For All 5 Digital (or URC 7555) with the following instructions:
* Press the DVD button
* Hold down the Magic button until the unit performs a double LED flash
* Configure your remote using the setup code 0 5 3 3
2. On your DVD recorder, using the official Sony remote, select the System-Menu option
3. On your DVD recorder, using the official Sony remote, select the Setup option
4. On your DVD recorder, using the official Sony remote, select the Options option
5. On your DVD recorder, using the official Sony remote, select the Command-Mode option
6. On your DVD recorder, using the official Sony remote, select the DVD1 option
7. On the official Sony remote, set the DVD1 option for the Command-Mode switch, under the sliding cover
8. Verify that both the official Sony remote control and your OneForAll remote control can power off and on your DVD player
9. Program your OneForAll remote with the following instructions:
* Configure your remote using the setup code 9 9 4 or 0 0 9 9 4 if your remote only accepts 5 digit codes
* Press the Magic button once
* Configure your remote using the setup code 1 8 9 or 0 0 1 8 9 if your remote only accepts 5 digit codes
* Press the 1 button once, a double LED flash should occur
10. Program your OneForAll remote with the following instructions:
* Configure your remote using the setup code 2 5 5 or 0 0 2 5 5 if your remote only accepts 5 digit codes
* Press the 2 button once, a double LED flash should occur
11. Program your OneForAll remote with the following instructions:
* Configure your remote using the setup code 0 9 5 or 0 0 0 9 5 if your remote only accepts 5 digit codes
* Press the 3 button once, a double LED flash should occur
12. Program your OneForAll remote with the following instructions:
* Configure your remote using the setup code 2 2 1 or 0 0 2 2 1 if your remote only accepts 5 digit codes
* Press the 4 button once, a double LED flash should occur
13. Program your OneForAll remote with the following instructions:
* Configure your remote using the setup code 0 7 9 or 0 0 0 7 9 if your remote only accepts 5 digit codes
* Press the 5 button once, a double LED flash should occur
14. Place your DVD player into Standby mode
15. Press the buttons 1, 2, 3, 4 and 5 on your OneForAll remote control, in order, one at a time
16. Your DVD player should show the words TIMER OK
17. Press the buttons 1, 2, 3, 4 and 5 on your OneForAll remote control, in order, one at a time
18. Your DVD player should return itself to Standby mode
19. Remove the batteries for significant period of time to wipe the programmed codes on your OneForAll remote
Good luck.
Jan 14, 2011 | Sony RDR-VX530 DVD Recorder/VCR
Sony KV40XBR800 won't turn on, flashes 6, sometimes 7 times on trouble code.
IC in power supply needs to be replaced, this is a specialized part and should be done by an experienced tech.
Jan 12, 2010 | Sony KV-36FS16 36" TV
Sony KV40XBR800- My Sony blinks 7 times.Does
i would love to tell you that these are the for certain parts but i can only tell you without looking at the tv the parts that could be the possible culprits. the horizontal deflection has stopped. could be Q8035,8038 has shorted on the D board. this is the answer that my research has come up with. please rate my solution. thank you.
Nov 13, 2009 | Sony Televison & Video
Blinking red light
Almost certainly it will be necessary to remove the set from any enclosure as access to its innards is gained by removing the rear housing completely.
If you feel around the back edge (hidden) of the bezel, I'm sure you will find several depressions; these are recesses for the screws that must be removed.
Sorry about your Sony problems, their quality has greatly diminished in recent years.
Feb 11, 2009 | Sony KV-40XBR700 40" TV
Kv40xbr800 standby flashes 7 times, sony 40" Hello. I hope some 1 can help. I've a 41" rear project Sony TV ModelKP-41T65. One day it just decides not to turn on. When you turn on thepower you hear the...
7 blinks on a sony indicate that high voltage has exceeded 33K and the set is going into safety shut down. Check your Horizontal and rgulator circuits. Something in those circuits are causing the increased voltage.Hope this helps let me know if I can help you further.
Dec 02, 2007 | Sony KP-41T65 41" Rear Projection...
Is it multiregional
Sony are probably the most protective manufacturer of this kind of information. All manufacturers carrying a DVD logo are obliged to say "no" but will normally intentionally leak this to boost sales, particularly in non-US areas.
But try this:
  • Press the DVD button
  • Hold down the Magic button until the unit performs a double LED flash
  • Configure your remote using the setup code 0 5 3 3
2. On your DVD recorder, using the official Sony remote, select the System-Menu option 3. On your DVD recorder, using the official Sony remote, select the Setup option 4. On your DVD recorder, using the official Sony remote, select the Options option 5. On your DVD recorder, using the official Sony remote, select the Command-Mode option 6. On your DVD recorder, using the official Sony remote, select the DVD1 option 7. On the official Sony remote, set the DVD1 option for the Command-Mode switch, under the sliding cover 8. Verify that both the official Sony remote control and your OneForAll remote control can power off and on your DVD player 9. Program your OneForAll remote with the following instructions:
  • Configure your remote using the setup code 9 9 4 or 0 0 9 9 4 if your remote only accepts 5 digit codes
  • Press the Magic button once
  • Configure your remote using the setup code 1 8 9 or 0 0 1 8 9 if your remote only accepts 5 digit codes
  • Press the 1 button once, a double LED flash should occur
  • Configure your remote using the setup code 2 5 5 or 0 0 2 5 5 if your remote only accepts 5 digit codes
  • Press the 2 button once, a double LED flash should occur
  • Configure your remote using the setup code 0 9 5 or 0 0 0 9 5 if your remote only accepts 5 digit codes
  • Press the 3 button once, a double LED flash should occur
  • Configure your remote using the setup code 2 2 1 or 0 0 2 2 1 if your remote only accepts 5 digit codes
  • Press the 4 button once, a double LED flash should occur
  • Configure your remote using the setup code 0 7 9 or 0 0 0 7 9 if your remote only accepts 5 digit codes
  • Press the 5 button once, a double LED flash should occur
14. Place your DVD player into Standby mode 15. Press the buttons 1, 2, 3, 4 and 5 on your OneForAll remote control, in order, one at a time 16. Your DVD player should show the words TIMER OK 17. Press the buttons 1, 2, 3, 4 and 5 on your OneForAll remote control, in order, one at a time 18. Your DVD player should return itself to Standby mode 19. Remove the batteries for significant period of time to wipe the programmed codes on your OneForAll remote
Nov 27, 2007 | Sony DAV-S500 System
Sony kv40xbr800 wont turn on, standby light flashes 7 times
Research replacement of MCZ3001D IC's......Not a repair for
novice, senior tech only...................T.
Nov 21, 2007 | Sony KV-36FS16 36" TV
Research replacement of MCZ3001D IC's.......senior tech only.
Not a repair for novice....................T.
Televison & Video Logo
143 people viewed this question
Top Televison & Video Experts
Electro Med Services...
