Question about Fisher and Paykel DD605HSS 23 in. Built-in Dishwasher
The code F1 keeps blinking and I can't shut it off.
I am trying to run both drawers and the code F1 keeps blinking while a quiet alarm goes off and I can't turn it off.
  • Fisher and P... Master
  • 713 Answers
F1 means u have a leak on your machine and the water has triggered the flood switch underneath the lower drawer. if u need more help please reply.
Posted on Apr 30, 2010
Dishwasher showing wrench symbol after using dishwashing liquid
I am assuming this F1 error is coming in only one drawer and that you are able to run the second drawer as normal.
In the case of your dishwasher the F1 error occured because the foam would have overflowed over the drawer top into the base of the unit. This would have triggered a flood switch which is there to protect water damage to the dishwasher. You can either wait a few more days until the base of the dishwasher drawer unit dries up or you can dry it yourself.
To dry the base, extend the drawer as far out as possible (turn mains power off first). The use a few towels and push them on to the base. Pull the towels out and dry the base especially the centre of it with a hair dryer.
The F1 should disappear once you put power back on .
Hope this helps. You have a very helful child who sets the dishwasher up. I have to keep pushing my children to even empty it.
Jun 04, 2010 | Fisher and Paykel 23 in. DD-603SS Built-in...
How to shut off dishwasher? F1 is flashing on control panel.
Hi now F1 mean that your machine has triggered the flood alarm. there are two reasons this happens-- 1st-- there is a leak on one or both of your drawers. they leak because you might have a hole in one of the hoses or your lid is not shutting properly etc. the 2nd reason is that some water or soap suds escaped from the overflow. now i would like you to turn the machine off at the wall and leave it off for a couple of days to dry it out. then turn it on and use the lower drawer for one cycle. if it does not go F1 then try the top drawer for one cycle and see how it goes. if it continues to flash F1 then reply back for further help. good luck.
Jun 03, 2010 | Fisher and Paykel 23 in. DD-603SS Built-in...
F1 fault
Hi . F1 means your machine has triggered the flood alarm. either you have a leak on one of your drawers or water or soap suds has escaped throe the overflow. now the 1st thing to do is turn your machine off at the wall. then leave it for a couple of days to let it dry out. then turn it on and try the lower drawer throe a cycle,if it doesn't go to F1 then try the top drawer. if it doesn't go to F1 then it might be fixed.if it does go to F1 on any drawer then please reply and tell me which drawer it is and i can help you further.
Dishwasher keeps flashing F1
F1 on your dishwasher is the fault code for leaking inside the machine. the water has caused the flood switch to activate. have you put any detergent rather than your normal dishwasher detergent into the machine? if you have, the water probably leaked out of your overflow, if not, then you have a leak on the top drawer or bottom drawer. the easiest way to check is to leave the machine off for a couple of days until it drys then turn on the bottom drawer to go thru a cycle.if the F1 comes up again then the problem is on your bottom drawer. if F1 does not come up then try the top drawer. please reply if you require further help.
May 28, 2010 | Fisher and Paykel 23 in. DD-603SS Built-in...
DD603 Does Seal need replacement? F1 Error Code
F1 error code appears because moisture has been detected by the flood switch on the base of the housing under the drawer.
If you think the door seal was not fitting properly then that too can cause moisture leak into base of the unit where the flood switch is located. Steam condensation would also lead to moisture.
Best option might be to replace the door seal for the top drawer. This is not a trivial thing as the unit has motor actuated door seal which can be tricky to fit back in.
Also avoid foaming in the detergent by using the correct powder and not tablets.
Please rate this solution if you are satisfied otherwise post a comment.
May 22, 2010 | Fisher and Paykel 23 in. DD-603SS Built-in...
My fisher paykel nautlis dishwaher display error code F1
What is the Model #? If both drawers, if a double, display F1 and won't shut-up then the flood switch is tripped and you have to unplug it to keep it from beeping and the drain motor running. The causes for the F1 fault can be numerous but not excluding bad lid lifts, broken link support, cracked drain line and wrong soap. Call F/P
Jul 19, 2009 | Fisher DS603W / DS603B / DS603I Dishwasher
TOP DRAWER WAS NOT DRAINING..NOW THE F1 ON BOTH DRAWERS IS ON
F1 code indicates a leak,you will find the water under bottom drawer.Lid probably not sealing well.
Jun 17, 2009 | Fisher and Paykel 24 in. DD-602 Built-in...
F1 alarm keep coming back on both drawer
I just had the same issue as a result of "mother-in-law" using regular liquid dish detergent in both drawers. After numberous attempts of cleaning out each drawer it still was beeping and attempting to drain both drawers even when the water was drained it continue to run and beep.
My presumption of what occurred is the wrong soup caused so much suds that it triggered the flood sensor. I removed both drawers and discovered water in the base area and moisture throughout. After disconnecting the power to the unit I removed the white plastic cover and exposed the small circuit board. I disconnected the power leads and the screw holding the board in place and lifted it up a bit. I then used a hair dryer for about 15 minutes until the entire area was dry and put it back together and has worked just fine. You will see a service diagram taped to the back pannel when you remove the bottom drawer. It has additional information on various error codes and the instructions on how to trouble shoot problems. I would also remind you to run water in the units if the cause was due to the wrong type of soap as the residue will continue to recreate the same problem.
I hope this helps.
Mark
Oct 08, 2008 | Fisher DD603FCSS Dishwasher
F1 display and alarm will not shut off
hi there,
can you tell me the model # on your stove please?
Sep 13, 2008 | Maytag CWG3100A Gas Single Oven
Dish drawer leaks
The f1 is a flood error. There is a sensor in the bottom reading water. You have to dry it out before you can do anything or the drain pump will just keep running. Check the lid of the drawer you where using to see if anything may have been holding it up or if the seal is torn. If that looks ok you will have to check the lid actuators to see if one is not working. I would replace both right and left if one is out.
May 15, 2008 | Fisher and Paykel 24 in. DD603H W Built-in...
Fisher and Paykel DD605HSS 23 in. Built-in Dishwasher Logo
245 people viewed this question
Top Fisher and Paykel Dishwashers Experts
Brian Coughlan
marley mcelhinney
Are you a Fisher and Paykel Dishwasher Expert? Answer questions, earn points and help others
