Question about Garmin eTrex Legend GPS Receiver
Need outer rubber cover and tape inner seal - Garmin eTrex Legend GPS Receiver
Contact Garmin for "Bumper Replacement" and tape. Also review forums at Geocaching.com. Many solutions listed there. I have not done it yet. Getting ready to.
Posted on Apr 29, 2010
Model #AWM392W when water is filling tub, water is coming out from around the bottom
the outer tub seal is bad,you need to remove the inner tub then outer tub to replace this seal
Aug 07, 2011 | Speed Queen AWS52NW Top Load Washer
My 1996 yamaha yz250 is leaking oil from the shifter.What can i do to fix it?
Remove the shifter by removing the locking bolt completely. Pull the shifter off. Use a selftapping screw and screw it into the seal that you see around the shifter's shaft. Using a pair of pliers you can now pull the seal out. It is quite tight so be prepared to battle some. Once out you will need to source a new one. The sizes you need are usually stamped into the seal but for the untrained eye is gibberish. Measure the shaft thickness. This is the inner diameter of the seal. Measure the outer diameter of the seal and also the seal thickness. These are the 3 measurements you will need, or you can just take the seal to the spares shop and they can check it for you.
To put the seal back in, clean the shaft properly. Apply some grease around the inner and outer sides of the seal. Wrap some insulation tape or similar around the shaft splines and end. This is to protect the inner lip of the seal so you dont damage it. Slide the seal over the shaft. It can now be carefully tapped into place. Be careful not to tap it in skew. Use a circular drift(pipe, socket) that is no more than 1mm less than the outer diameter of the seal.
Aug 18, 2010 | Yamaha YZ 250 Motorcycles
Removal of rubber seal
I take off the top cover unplug machine 1st ..Safety...Then take offretaining ring on inner drum /also ring on outer drum remove boot seal..Check utube video, explains in good detail...
Oct 07, 2009 | GE WBVH6240F Front Load Washer
Need help replacing front hub
Here's the steps....getting some pics for you....hang on a minute or two.
Front Hub Removal & Installation To Remove:
  1. Remove steering knuckle.
  2. Using a suitable slap hammer, remove wheel hub assembly.
  3. Using a suitable bearing press, remove outer bearing, oil seal, outer bearing race and preload spacer.
  4. Remove inner oil seal, inner wheel bearing and inner bearing race.
NOTE: It is not necessary to remove dust cover (back plate).
To Install:
  1. Using a suitable bearing press, install bearing races in steering knuckle.
  2. Pack the bearings and hub area with lithium grease.
  3. Install inner bearing in steering knuckle.
  4. Lubricate lip of NEW inner seal and press seal into knuckle.
  5. Install preload spacer into bore.
  6. Install outer bearing into bore.
  7. Lubricate lip of NEW outer seal and press seal into knuckle.
  8. Using an appropriate tool, support inner wheel bearing and press wheel hub into knuckle with a force of 2500kg.
  9. Install NEW inner seal.
  10. Install knuckle assembly.
May 13, 2009 | 2004 Kia Rio
Leaking front door rubber seal
this might be a job you might want a appliance tech to do this repair depending if its the inner or outside part of the seal thats loose. if its the outer ,press seal around front panel opening and strech outer spring to retain outer seal to outer panel
Dec 13, 2008 | Frigidaire ATF6000ES Front Load Washer
GE Front Loader rubber boot completely out of shape
You can replace the rubber door seal yourself if you are logically minded and are handy with tools. Isolate the washer from the mains supply. Remove the top fixing screws at the back of the washer. Slide the top of the washer to the rear of the washer and remove. Now you will be able to see the outer drum and the securing band to the drum. This needs loosening and moving clear of the outer drum so you can disconnect the seal from the drum. When you open the door, you will find see that the door seal connects to the washer outer body. You should see a holding catch probably made of plastic. This has to be removed and take care not to break anything. When re fitting the seal,you will find on the front inner edge a small hole, this must be in the 6 o'clock position. Working from the door access, feed the new seal on the outer drum and secure it with the retaining band that you removed earlier, at this stage do not fully tighten as you may need to readjust the seal later on. Now working at the door, feed on the door seal and position the small hole at 6 o'clock. If you find that the seal is twisting, then you will have to readjust the the seal on the inner outer drum. When everything is lined up, tighten the inner securing band then the outer retaining band by the door. Recheck that the small hole on the door inner lip is at 6 o'clock and both the door an outer drum securing bands are tight. This done, check for leaks by part filling the washer and then putting the washer on an emptying cycle. If all is well, then isolate the power to the washer and refit the the top of the washer and secure with the screws you removed earlier. On no account put your hands or tools inside the washer when it is on and connected to the power supply.
I have not yet replaced a door seal on your model of washer, but I have done quite a few and the process is the same. I hope you can follow these instructions and if you come across a snag, think about it and i am sure you will find the solution. You can always get to me at FixYa.
Oct 27, 2008 | GE Energy Star WCVH6260F Front Load Washer
Toyota camry 1994 wide body 2.2
Hi nanadevi,
There are two rubbers fitted to each of the caliper pistons.The outer one is a dust cover and the inner is the seal.... i you've removed the inner, you'll have to refit very carefully, not causing any damage....Lubricate with rubber grease and open the bleed nipple....push it in gently....The dust cover fits over the caliper housing and tapers outwards to fit the piston....
Hope that's a help?
Regards Johngee10
Sep 04, 2008 | 1994 Toyota Camry
Harmonic balancer rubbing on the timing chain cover
The rubber in the balancer has broken down and the inner and outer pieces shift and rub on the cover. You need a new balancer.
May 22, 2008 | 1989 Jeep Cherokee
Garmin eTrex Legend GPS Receiver Logo
212 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
Steve
Are you a Garmin GPS Expert? Answer questions, earn points and help others
