Question about Viking VDSC365-6B Dual Fuel (Electric and Gas) Kitchen Range
Viking dual-fuel range ignition problem
Yesterday, all six ignitors on my Viking dual-fuel range began firing non-stop for no apparent reason. I shut off the power but when power was restored the firing resumed. Does anyone have a solution? Thanks.
  • 23 Answers
You may have wet it somehow. There are two fixes. Leave them on for 20 minutes on high to let the ignitors dry out. If they dry and stop clicking you have solved it. If not then contact Viking 888-845-4641 and purchase a 6 point spark module. You can try to replace this yourself. With the power OFF. Remove the wires one by one placing them on the new module and then attaching it to the wall. (this is if ur spark module is located under the burners.) If it is in the rear of the unit and u can pull out your range yourself without hurting yourself then you do the same thing. Good luck. If none helps you you may need to replace all 6 burner bases or ignotrs. Also easy. Good luck.
Posted on Sep 18, 2009
Viking oven not heating past 150 degrees
My viking oven had same issue - I needed to replace the ceramic ignitors (if ignitors fail to heat up properly the gas valve remains partially closed). Apparently they are intended to be replaced every 3-5 years. Also inspect and clean the oven burners - mine had corroded somewhat and prevented the flame from 'moving' to the opposite side - ie only half the burner was lighting. If you are handy the ignitors are very easy to replace - one screw, two wires each.
Jan 02, 2010 | Viking VDSC365-6B Dual Fuel (Electric and...
Have a Viking range, gas top, electric oven, neither work.
Check connector block where electric is brought into stove for loose or burnt wires. Check Breaker in house power box. Push the breaker firmly to off and then return to On position. Read owner's manual to see if ignitor circuit has a fuse and check said fuse.
Sep 12, 2009 | Viking 30" Dual-Fuel Range, VDSC3054B...
Viking 30" Range - Igniter works - but NO FLAME in oven or ranges
No pilot light need to be ignited. You may need a new ignitor. It might not be catching. If you pull the bottom oven plate off you can see the ignitor on the side of the burner and see if it is in its place or broken or just plain old. It is a simple fix. You can buy a universal ignitor or contact Viking and they will sell it to you. Its only two wires and can do it yourself if you are somewhat technical. Good luck.
Jan 09, 2009 | Viking VDSC365-6B Dual Fuel (Electric and...
Burner ignitor will not turn off after the burner lights Viking
replace the electrode that's the wire or pilot tip, it has a sensor built in, when it gets hot it stops automatically. if the electrode is between the front and rear burners, there are small holes on the burners going down on the side of the burner facing the ignition. they need to be clean. try a paper clip and insert the clip in side the holes.
Dec 14, 2008 | Viking VDSC365-6B Dual Fuel (Electric and...
Ignitor sometimes clicks, sometime not
You will need the ignition bird located il under the cooktop
Mar 28, 2017 | Kitchen Ranges
Ignitor won't shut off
The Viking manual says that an ignitor that continues to try to light even after the burner has been lit indicates improper grounding, and that an electrician should be consulted.
Perhaps you could try to replace the ignitor, and see if that fixes the problem?
I have a similar age, 6-burner 36" rangetop.
Sep 30, 2008 | Viking 48" 6 Burner, Grill Professional...
Ignitors stopped working.
  Probably a spark module.  Some models have 2 of them.
Oct 11, 2007 | Viking VGIC485-6G Gas Kitchen Range
Viking VDSC365-6B Dual Fuel (Electric and Gas) Kitchen Range Logo
346 people viewed this question
Top Viking Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Craig Butler
Craig Butler
Are you a Viking Kitchen Range Expert? Answer questions, earn points and help others
