Question about Briggs & Stratton Briggs Stratton Intek V - Twin Vertical Ohv Engine with Electric Start 22 Hp, 1" X 3 5/32" Shaft, ModelNo. 44K777 - 0027 - E1
How can i remove the drive pulley on the 12.5 briggs and stratton
Countax C300 I have removed the long bolt and taken off the electric clutch which is on a key way, but cannot see how the drive pulley comes off, can anyone help. Many thanks Steve
  • 3,740 Answers
Hi Steve, There should be an allen head set screw (Sometimes 2) that has to be removed before the pulley will come free. One set screw should be directly above the key way "key" and the second one (If installed) will be within 90 degrees of the one securing the key. Also take a piece of 100 or 120 grit sand paper and sand off the rust areas on the old crank shaft. Occasionally it does require a puller to get them off but usually you can tap gently the pulley every 90 deg (not on the pulley V belt drive area) and it will come free.
This should be a 13HP 2 cyl engine.
Depending on the type pulley they are using. Some of them have a collar on the crankcase side of the pulley that will also have to be removed. (again secured with a set screw possibly 2)
If it is really stubborn you can and should use a puller to remove the pulley. Be very careful if you do have to use a puller; not to damage the V-belt drive area of the pulley.
Thanks for using FixYa.
Kelly
Posted on Apr 29, 2010
How to change blade boss on briggs &stratton sp 470
Unscrew the central bolt (9/16") - remove blade and any washers etc. It's a conventional right hand thread (anti-clockwise to remove), but may well be extremely tight. If necessary, grind the head of the bolt off and replace it.
The blade boss slides off the shaft - in theory. In practice, you will probably have to use a puller bearing on the blade bolt to pull it off. Remove the drive belt first!
Sep 21, 2014 | Briggs & Stratton Briggs Stratton...
Crankshaft pulley bolt keeps dropping out no matter how hard I reinstall it. Any idea? Countax A20-50 and its a Vanguard 20hp twin. Thanks!
Does that motor vibrate badly? The crankshaft may have gotten bent. If it vibrates VERY badly, it may be nearly impossible to keep that bolt tightened. Your best bet may be to try some (REMOVABLE) Loctite (like Loctite Blue 242) on the bolt threads. It's expensive, but it's well suited for situations just like this.
Aug 03, 2014 | Briggs & Stratton Garden
How to change battery on countax c600
Guess you remove gas tank to remove battery.
Apr 07, 2014 | Briggs & Stratton Garden
Removal of carburator from model 303447-0446-01 engine
How can I remove the drive shift pulley on a18hp Briggs & stratton engine
Feb 05, 2014 | Briggs & Stratton Briggs Stratton Intek V...
How do i remove a faulty magnet clutch on a John Deere LX277 Tractor
Hi, there is a single bolt in the middle of the clutch. Once undone, the clutch assembly should slide off the crankshaft. If not, it is seized on the shaft and will require the use of a puller. Try soaking the shaft in crc or inox first. Regards Phil.
Apr 29, 2011 | Briggs & Stratton Briggs Stratton...
I need to know how to remove the shaft with pulleys on it that comes out the bottom of the engine
the shaft you are talking about is the crank shaft. in order to remove it you must first remove all pulleys, drain oil, then remove the case bolts. slide case off of shaft then remove the connecting rod bolts. crankshaft should come out hope this helps
Jul 09, 2009 | Briggs & Stratton Garden
I am trying to get the 11 hp Briggs & Stratton engine out of my Toro tractor to replace the gaskets, since it is using & throwing oil over abundantly. How do I get the drive & mower pulleys from under the...
On the end of the shaft that comes from the motor there should be a bolt that holds the pulley in place. You will need to remove the bolt in order to get the pulley off. If you can lift the front end onto a couple of blocks it will make the job easier to do. You may have to place a screw drive in between the belt and the pulley. A wood wedge the width of the belt would be better as it would be less likely to damage the pulley. Depending on how old the tractor is, you may have to spray the bolt with a penetrating oil first to help loosen the bolt.
Hatter1
Mar 14, 2009 | Briggs & Stratton Garden
Briggs & Stratton Briggs Stratton Intek V - Twin Vertical Ohv Engine with Electric Start 22 Hp, 1" X 3 5/32" Shaft, ModelNo. 44K777 - 0027 - E1 Logo
2,683 people viewed this question
Top Briggs & Stratton Measuring Tools & Sensors Experts
Bill Boyd
Richard Warren
Richard Warren
Mike Squire
Are you a Briggs & Stratton Measuring Tool and Sensor Expert? Answer questions, earn points and help others
