Question about Kingston 4GB Secure Digital High Capacity Memory Card
Cant get my kingston flashdrive to connect to usb port
    Scholar:
  • 179 Answers
Instaal proper driver for your USB
Posted on Jul 19, 2010
My Kingston usb flashdrive 16 Gb files was corrupted and so with the installer. Everytime when I insert it shows unknown driver and it's not working. Can you provide us the the installer with this...
You do not need drivers for flash drives. The problem may be your USB ports.
Follow the steps given below to refresh USB ports.
1. Right-click My Computer icon on the desktop, and then select Properties.
2. Click the Hardware tab.
3. Click the Device Manager button.
4. Click the plus (+) sign to the left of Universal Serial Bus controllers.
5. Right-click the device listed under Universal Serial Bus controller and select Uninstall.
6. Click OK to confirm the removal of the device.
Please note, repeat Steps 5 and 6 until all the devices under Universal Serial Bus Controller are removed.
7. Shut down the computer.
CAUTION: Ensure that the Shut Down option is selected, instead of the Restart option.
8. Wait for 5 seconds and then restart the computer. When the computer restarts, a "Windows has detected new or added hardware" message window will open.
The above steps will refresh the USB ports.
Now connect the USB devices like mouse, video camera, your external usb hard disk...usb hubs...whatever you like and the drivers should install automatically.
Tip: It is always recommended to connect the main usb devices at the rear end usb port, as they require more power to initiate.
If it turns out that the files are indeed corrupted, there are several free recovery programs you can try.
http://www.easeus.com/resource/drive/usb-flash-drive.htm
Click on this link or copy and paste the complete link into your browser.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response
Thanks, Joe
May 21, 2011 | Kingston (DTIU3/2GB) 2 GB USB Hard Drive
The data after it is removed from the computer will be corrupted automatically in my kingston 4gb flashdrive even data are shown when i insert it for second time. but the data are not working
Try formatting it again and this may resolve the issue. Make sure your following the proper remove Device steps. Typically windows doesn't write all the data until you close the device properly.
Oct 29, 2010 | Kingston (DTIU3/2GB) 2 GB USB Hard Drive
I cant get my Kingston flash drive
These do fail. The easiest thing to check is to stick it into a differant usb port or even a usb on a differant computer. That way you will know if it is the stick or the usb port that is the problem.
Unfortunetly there is nothing that is repairable on the drive so if it has failed you are out of luck.
Jul 15, 2010 | Kingston (DTIU3/2GB) 2 GB USB Hard Drive
When i insert my pendrive its coming that device
DID you tried different USB ports?
IF YOU DNT NEED the inside data you can always format it.
..using any usb format tool (DriveKey), or u can even go to administartor tools, device managment, disk managment, locate your flashdrive and format, it will be back to normal state after that.
Jan 01, 2010 | Kingston (DTIU3/2GB) 2 GB USB Hard Drive
I can not copy enything onto the 8gb flashdrive and if copied it cant be deleted again
Do you have a write protect switch on the pen? If so switch it to the open position.
Sep 10, 2009 | Kingston (DTIU3/2GB) 2 GB USB Hard Drive
My USB flashdrive cannot be opened
have you tried it on a different usb port? if that doesnt work you may also try it on a computer
Jul 09, 2009 | Kingston (DTIU3/2GB) 2 GB USB Hard Drive
Flashdrive
right click on your folder which contains your photo's, or you right click on a single photo in your folder. Then select "copy". then locate your usb on your "my computer" folder. left click on this icon. Then select paste with your left mouse button.
Aug 18, 2008 | Kingston (DTIU3/2GB) 2 GB USB Hard Drive
Imation Swivel Flash Drive Cant detect
is it several times that youve used your flash driver at your office? and which side of the usb port did you plug it? coz when it is your first time to use your flash drive at your office and your plugging it at the front side of the PC. well there might be something wrong with connection and may cause damage to the board of the flash drive. if it your using it several times, well try to check at your PC, then do the following specs:
my computer (right click and select manage)
and under manage window ( select disk management )
try to see if your flash drive registered (you can see the drives of your PC) and see if theres a volume (either raw/ or theres a partition on it).
if not, well the board of your flash drive might be damaged, mostly these were caused by the power of the system, fluctuation is one of them, then improper plugging of the flashdrive.
Mar 12, 2008 | Kingston (DTIU3/2GB) 2 GB USB Hard Drive
Kingston 4GB Secure Digital High Capacity Memory Card Logo
35 people viewed this question
Top Kingston Electronics - Others Experts
Raghavendra Nagaraj
Raghavendra Nagaraj
Are you a Kingston Electronics - Other Expert? Answer questions, earn points and help others
