Question about Lexmark X73 All-In-One InkJet Printer
Lexmark x73 all in one printer
Hi
I've reconnected my printer to my computer but everytime i switch it off and try to print something, its off line and won't print anything until i remove and install the printer program again.
    Genius:
  • 2,035 Answers
Perform the following checks on the bi-directional communication:
  1. Temporarily unplug the power cord and then plug it back into the wall outlet. If necessary, turn the printer back on. The printer should make a resetting sound.
  2. Make sure that the print cartridge has been installed correctly and the cover snapped into place.
  3. Also make sure that the printer is directly connected to the USB port (or parallel port, where applicable) on the PC.
  4. An IEEE-1284 bi-directional parallel printer cable is required (not applicable for USB).
  5. If there is another peripheral device connected, remove it and connect the printer directly.
  6. If the problem persists, continue as instructed below.
To prevent the drvwppqt.vxd virtual device driver from being loaded:
Warning! Do not implement this solution if you have a tape backup device connected to a parallel (LPT) port on your computer.
  1. Click Start, point to Find, and then click Files Or Folders.
  2. In the Named box, type drvwppqt.vxd and then click Find Now.
  3. Rename all instances of the file by changing the file name extension from .vxd to .old. This will prevent the driver from being loaded.
Posted on Mar 25, 2008
Lexmark x73 printer offline?
is the printer driver compatible with your computer. see if your printer runs with the windows you are useing.
Nov 12, 2011 | Lexmark X73 All-In-One InkJet Printer
Printed copy will not feed out line by line and finally will not feed the printed page. How to get it to work properly?
There could be something blocking the paper path that's not allowing the paper to not go all the way through the feeder. Try to open the printer and access the cartridge area. Remove the cartridges. Check for any foreign objects blocking the paper path. Rebrick your printer by removing the power adapter (black box found on the back of your printer where the power cord is plugged in) and then re-plug after 30 seconds. When your printer turns back on, re-insert your cartridges. Then try print your document again to verify that the problem is fixed.
Nov 10, 2011 | Lexmark X73 All-In-One InkJet Printer
Problem communicating with printer message when printing. printer says offline
This could be just a slight communication issue. Try to unplug your printer from your computer. Unplug and replug the printer into your power outlet to reset itself. When the printer powers on, reconnect it into your computer. Doing this usually fixes minor communication issues. Thanks.
Feb 21, 2011 | Lexmark X73 All-In-One InkJet Printer
Lexmark X73 not pulling paper through properly, overprinting lines, part printing documents and printing some lines in colour shadowing the black print. I have used different grades of paper but still the...
Your printer's rollers sound like they are worn along the paper path. I suggest you taking your printer in to have a maintenance cleaning or have the rollers replaced. This will resolve your issues.
May 28, 2010 | Lexmark X73 All-In-One InkJet Printer
Lexmark X73 Printing Problem
When you say that your all-in-one system will copy, but will not print from the computer, this tells me that there could be a connection problem between the printer and the computer. This is more then likely a driver problem. you will need to go to lexmark and download the latest drivers for your operating system.
But this could also be a broken or loose cable.
Apr 15, 2010 | Lexmark X73 All-In-One InkJet Printer
I bought a new computer with Windows Vista. I have a Lexmark x73 printer that was used with my old computer with Windows XP. I bought a USB port and my printer still doesn't work. I need help with this.
Not finding a Vista driver to be available from Lexmark x73. They only show the XP driver. You can get this driver free here: http://download.cnet.com/Lexmark-X73/3000-2116_4-22576.html?tag=mncol
One, try installing printer without the XP driver. Lexmark may have provided a quailifying driver with Vista hardware setup wizard. If it does not work or wizard cannot locate a driver, try the XP driver.
Beyond this, you may have to talk to tech support at Lexmark or repost here for another expert.
Oct 04, 2009 | Lexmark Office Equipment & Supplies
The paper jams when it tries to feed. I have turned the printer off and discontected the power and cable feed. After reconnecting and turning the printer back on the problem still occurs. There is a...
Use only recommended paper. Paper must be straight and low moisture content. Moisture can cause such problems.
If the problem remains then I ask whether your printer is new or dismantled for repairs?
Jul 29, 2009 | Lexmark X73 All-In-One InkJet Printer
Printer works, copier and scanner do not
you might try enabling bi-directional printer support in printer properties, if its paralell cable then it is in bios, epp or ecp.
Jul 27, 2009 | Lexmark X73 All-In-One InkJet Printer
My computer says that my printer is offline.
Please follow the steps given below to perform a self test on the printer:
1. Switch off the printer.
2. Press and hold down the paper feed button.
3. While keeping the paper feed button depressed, turn the power back on.
4. When the printer starts to print, release the paper feed button.
5. When the first page is printed, switch off the power (otherwise the printer will keep on printing).
Apr 04, 2009 | Lexmark X73 All-In-One InkJet Printer
Printing
Trying this fix from the Lexmark X63.
On the printer itself.
Hit the "setup" button.
Press "menu" 'til the maintenance appears.
Press "options" 'til cartridge clean appears.
Press "start"
or you can do it from your computer.
start, programs, lexmark print control panel.
Click cartridges tab.
Then select clean print nozzles.
Apr 03, 2008 | Lexmark X73 All-In-One InkJet Printer
Lexmark X73 All-In-One InkJet Printer Logo
154 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
