Question about Dell 962 Photo All-In-One InkJet Printer
My printer is printing but no ink on paper - Dell 962 Photo All-In-One InkJet Printer
  • 4,041 Answers
Summary
Usage of compatible ink and leave the printer idle too long may cause printhead clogging
What should you do if you get this problem. Relax; you may recover the printhead by unclogging it. Follow these steps to unclog the printhead
1. Right click in the printer driver name
2. Select Properties menu
3. Click Maintenance tab
4. Click on cleaning sign for regular cleaning. Perform this up to 3 times.
5. If this does not work, perform Deep Cleaning
And if that not work
Some times it needs a good clean up but this is up to you if you want to do this,
But after you done this prime the printer so it gets the inks back in the heads, it may take a little time for the inks to work.
Ok.
There is fluid cleaner for this but I can never find any in the shops the only ones I seen is when they sell them in Tesco but they come in with the ink refill bottles so I just use worm water by it self on a cloth and dabbing on the heads to clean them, it will not harm the heads but not to much water.
Some heads are on the inks them self but some have them inside the printer so I not know your printer so if the heads are inside you need to get them out you may find that some heads will just clip out put some need to be unscrewed so you got to know how they come out so be careful and not push to hard on them, if the heads are on the ink then it is a easy job to clean them,
It worth a try it worked for me more than ones.
Please all I ask is call back and just gave a vote, it will gave me some satisfaction to know am helping some one, so I will keep on helping.
All The Best: Pineworks
Posted on Apr 27, 2010
Black ink leaked on inside of printer.
try to replace the defective cartridge by a new one and see printing test result
Nov 18, 2011 | Canon PIXMA iP6700D InkJet Photo Printer
Ink
is it the exact ink replacement or did you have a company refill it ?
Robert
Aug 29, 2008 | Canon PIXMA iP1600 Printer
Black ink won't print and I just changed the ink
Try using the photo paper option instead of the plain paper option.
I was using plain paper but, selecting the plain paper option...I could barely read the print. The photo paper option worked great!
Hope it helps!
Nov 14, 2011 | Brother MFC 6490CW InkJet Printer
Epson Stylus PHOTO R220 red lights keep flashing
I hope this will help you :)
* Green Power light flashes- The printer is receiving a print job, replacing an ink cartridge, charging ink, or cleaning the print head.
* RED paper light is On- If the CD/DVD try guide is open, close the CD/DVD tray guide, load paper, then press the paper button. Your paper ran out or multiple sheets loaded at the same time . Load paper and press the paper butoon to resume printing.
* RED paper light flashes- Paper is jammed in the printer. Press the paper button to eject the jammed paper. If the light is still flashing , open the cover and remove all paper, including any jammed or torn pieces. Then reload paper and press the paper button to continue printing.
* RED Ink Light Flashes - One or more cartridges are low on ink. Check the message that appears on your screen to determine which cartridge is low, or follow the instructions in " Checking the Ink Supply". Make sure you have a replacement cartridge.
* RED Ink Light is ON- One or more cartridges are out of ink or not installed. If you have just installed a new cartridge, it may be incomaptible with the printer or incorrectly installed. Reinstall it or replace it with the correct cartridge
* RED Ink and RED paper lights flash alternately- The CD/DVD tray guide was left open when you turned on the printer or when printing on paper. Just simply close it/
* Green Power Light is Off; RED paperand RED Ink Lights flashing- Paper may be blocking movement of the print head. Turn off the printer, then open the cover and remove any jammed paper or other foreign objects. Turn the printer back on again. Or it may have an internal error. Turn off the printer, wait a few seconds, then turn it on again.
Jul 06, 2011 | Epson Stylus Photo R220 InkJet Printer
I put new ink cartridges in my hp 2575 about ~six months ago and hadn't used the printer since then. I tried to print and it goes through the motion of printing but nothing shows up on the page. The...
The Ink at the head of your Printer Cartridges has dried up.
Try this:
Load some plain paper in the printer
Remove the cartridges from the printer and carefully dab the print heads of the cartridges with a damp paper towel. ( when you start to see ink, the ink is starting to flow).
Replace the cartridges into the printer.
Go to:
Start
Control Panel
Printers
RIGHT click on this printer
choose Printing preferences
services
clean print cartridges 9some papers may print)
follow the instructions and do the heavier cleaning as well
Run the calibration function and allow the paper to print.
Jan 10, 2011 | HP Photosmart 2575 All-In-One InkJet...
U053 error code,tried removing and replacing cartridges, but code still present,cartridges are compatible as come with printer.
Printing with an empty ink cartridge may cause printer malfunction. U051 / U052
U053 / U059 The ink cartridge may not be set properly, or an ink cartridge not supported by the printer is installed.
Install the proper ink cartridge.
Make sure to install both the ink cartridges even when you set the printer to use only one ink cartridge (Color or Photo) in printing.
If one of the ink cartridges is missing, this error will occur. U075 / U076 The ink cartridges are not installed in the proper position.
Install each ink cartridge in the proper position. U140 An ink cartridge not supported by the printer is installed.
Install the proper ink cartridge. U161 / U162 A used ink cartridge may be installed, or the ink cartridge may be empty.
Replace the ink cartridge.
By pressing the OK button, printing can be done without replacing the ink cartridge. However, the remaining ink amount cannot be detected properly, so the function to detect the remaining ink amount does not operate. READ/WRITE MODE Since the memory card is currently write-enabled, printing is not possible.
Set READ-ONLY MODE ON. NO PHOTOS ON CARD Some images in the memory card may not be in a supported format. images listed below cannot be printed directly from a memory card. Print them from a computer.
- images edited on the computer
- images in a format other than JPEG or TIFF
- images with double-byte characters used in the file name
- images saved in a folder nested 4 or more layers deep INCOMPATIBLE CAMERA The printer cannot communicate with the connected camera.
Disconnect the cable between the printer and the camera to clear the error.
Confirm the following items and print again.
1. Confirm that the camera you are using supports PictBridge or Canon Bubble Jet Direct.
If the camera does not support either one, the printer cannot print directly from the camera.
2. Set the camera in PictBridge print mode before it is connected to the machine. This is required before printing for some cameras that support PictBridge.
Please refer to the camera instructions for more information about procedures required before and after connection to the printer.
3. There may have been no response from the camera for the prescribed time.
Re-connect the cable between the camera and the printer. WASTE INK NEAR FULL The waste ink absorber is getting full.
Press the OK button to clear the error.
Printing can be done until the waste ink absorber becomes full. If the waste ink absorber becomes full, please contact your local Service Center for replacement of the absorber and printer maintenance.
The waste ink absorber is a part inside the printer, which absorbs ink used in the cleaning operations, etc. CHECK PRINTER Turn the printer off, and remove the power plug from the outlet.
About ten minutes later, plug it in again, and turn the printer on.
If the problem is not resolved, the printer may require servicing. Please contact your local Service Center. HEAD ALIGNMENT ERROR Automatic print head alignment failed.
Press the OK button to release the error.
Check the followings and do automatic print head alignment again.
- Check if A4/Letter-sized paper is loaded in the auto sheet feeder.
- Check if the paper output slot is not exposed to a strong light source
- Print the nozzle check pattern to check the status of the print head.
If the problem continues, do manual print head alignment. LOAD PAPER If paper is not set, set paper and press the OK button. When paper is set, check each item and do printing again.
1. Confirm that unusable paper is not set.
2. Confirm that paper is set properly.
3. Confirm that recommended paper is used, and the number of sheets set in the auto sheet feeder is within the limit.
4. Cleaning the paper feed roller may resolve the error.
If the problem persists, the printer may require servicing. Please contact your local Service Center. PAPER JAMMED Remove the jammed paper.
If paper jam frequently occurs, check the following:
1. Confirm that no foreign material is inside the printer.
2. Confirm that unusable paper is not set.
3. Confirm that paper is set properly.
4. Confirm that recommended paper is used, and the number of sheets set in the auto sheet feeder is within the limit.
Dec 27, 2009 | Canon Office Equipment & Supplies
Error Message U053
Error messages displayed on the LCD and how to handle them
When an error has occurred in the printer, the error / check message is displayed on the LCD.
Take the appropriate action to return to the normal condition.
Error / Check message How to correct CHECK INK
U041 An ink cartridge is empty.
To cancel printing, press the Stop/Reset button.
To continue printing, press the OK button.
After the printing finishes, replace the empty ink cartridge.
Sep 15, 2009 | Canon PIXMA MX310 All-In-One Printer
My printer will feed paper, but no ink is printed..
i im  josh in cebu phils.may i help you? Friend the printer that prints and without ink appears even though not run out of supply. the problem is not the ink  but the tank lever that carries the cartridge.there maybe stuck dried ink on it came from previous ink installed that drain on the lever. Solutions: 1. try to remove all the ink and clean the lever with a soft cloth. 2. go to settings and perform the head cleaning and nozzle check. 3. do the printing repeatedly until the ink comes out. thats all friend good luck hope i helped you.
Mar 14, 2009 | Canon PIXMA iP1800 InkJet Photo Printer
When i turn my printer on the light flashes green once and then orange 5 times. cannot get past this stage - any ideas?
Here are all the flashing explanations:
Two flashes: Out of paper or paper feed error
Reload the paper correctly and press the RESUME/CANCEL button.
Three flashes: Paper jam
If paper has jammed in the printer, clear the jam, reload the paper in the printer correctly and press the RESUME/CANCEL button.
See Paper Jams
Four flashes: Empty ink tank
If you press the RESUME/CANCEL button, it will continue printing with an empty ink tank. After printing is finished, replace the ink tank immediately. If you continue printing with an empty ink tank, it may cause damage to your printer.
Refer to your Quick Start Guide for instructions on how to replace an ink tank.
Five flashes: No print head installed/Defective print head
Install the print head. Also, ensure that the protective tape has been removed.
If reinstalling the print head does not solve the problem, replace it with a new one. Contact the Customer Care Center.
Eight flashes: Waste ink tank almost full
The printer has a built-in waste ink tank for the ink used during print head cleaning. Eight flashes indicates that the waste ink tank is nearly full. Press the RESUME/CANCEL button to cancel the error so you can continue printing. Before the waste ink tank becomes completely full, contact the Customer Care Center.
Mar 08, 2009 | Canon BubbleJet i560 InkJet Printer
Dell 962 Photo All-In-One InkJet Printer Logo
718 people viewed this question
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Electro Med Services...
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
