Question about HP LaserJet 4240n Printer
HP 4240n prints with vertical white line on right side of page. I have changed the toner cartridge and it is not the problem.
    Director Badge:
    Uploaded 100 video answers.
  • 1,751 Answers
Check if piece of paper is stuck in the over of your printer
try printing in a heavy paper (160+ grams)
Posted on May 01, 2010
Canon irc4580i print dark problem
In the process used printer, will be inevitable printed page by your printer have the bad quality prints. For example: Toner specks, Light image, Vertical line, Dropouts, background, Toner smear, Vertical black line and band, Vertical white line, Background scatter, Black pages, Loose toner, Horizontal stripes, Ghost, Uneven Density, poor fusing ...
The common print quality problem Canon IRC-4580 printer
Currently, The Canon IRC-4580 is the laser printer have high speed, easy to use, friendly for user and printing clear text.
However, we can not avoid the damage of some components of the printer when used.
In this article, I will introduce some basic errors with printing quality problems of Canon IRC-4580 printer and "How to fix it".
After viewed artical, you know:
- How to fix (repair/solve) Vertical line (black or white) in Canon IRC-4580 printer
- How to fix (repair/solve) Poor fusing (loose toner) in Canon IRC-4580 printer
- How to fix (repair/solve) Uneven Density in Canon IRC-4580 printer
- How to fix (repair/solve) Light image in Canon IRC-4580 printer
- How to fix (repair/solve) Ghost in Canon IRC-4580 printer
1. Fix print quality problem "Vertical line" for Canon IRC-4580 printer How to fix print quality problem Vertical line
This plobrem "Vertical line" is usally error of Canon IRC-4580 printer. For this "Vertical line" error, technicians divided into two smaller error are: Vertical black line and band and Vertical white line.
Description:
- Vertical line and band: On the printed image appear some straight thin black vertical.
- Vertical white line: On the printed image appear some white vertical voids.
Error location:
- Surface of the charge roller
- OPC drum
- Cleaning blade
- LSU unit
- Developing roller
Cause of error "Vertical line" on the printed page:
- May be surface of charge roller scratched or dirty by toner powder.
- May be have some grooves on the OPC drum.
- May be cleaning blade is damaged.
- May be LSU window or LSU lense has dirty.
- May be surface of developing roller has scratched.
How to fix(repair) "Vertical black Line and Band" for {{SPkey1}} machine:
- Replace the charge roller of toner cartridge.
- Replace the OCP drum.
- Replace the cleaning blade
If printed page are not improved
- Clean the LSU unit by soft cotton cloth and try to print. If Vertical line is not clear on the printed page you should replace LSU unit.
- Replace new axis developer and try to print
2. Solve print quality problem "Poor fusing (loose toner)" for Canon IRC-4580 printer. How to fix print quality problem loose toner
Description loose toner: Toner is not properly fixed on paper, use to hand rubbing lightly on the printed image toner powder may be stick in hand
Error location: toner cartridge or fuser unit
Cause of error "Dark Image or black" on the printed page:
When toner cartridge is empty. You toner refilled by toner powder ware not compatible. This is makes toner cartridge components demaged and temperature of fuser unit is not enough melt to toner powder
How to fix(repair)"Poor fusing (loose toner)" on the printed page for Canon IRC-4580 printer:
With this error, you should replace toner cartridge or fuser unit to fix it.
3. How to fix print quality problem "Uneven Density" for Canon IRC-4580 printe How to fix print quality problem Uneven Density
Description: The printed page has one half light and one half clear.
Error location: Toner cartridge, transfer roller, springs, doctor blade
Cause of error "Uneven Density":
- The pressure force on the left and right springs of the transfer roller is not even.
- May be toner low also causes this error
- Doctor blade has bent
How to repair error "Uneven Density" on the printed page for Canon IRC-4580 printer:
- Replace springs and transfer roller.
- Toner refill toner cartridge Canon IRC-4580 and reset toner cartridge chip (replace new chip) or replace new genuine toner cartridge.
- Replace doctor blade.
4. How to solve print quality problem "Light image" for Canon IRC-4580 printer How to fix print quality problem light image
Description: The printed image is all light and no Ghost.
Error location: Toner cartridge, Developer, HVPS board
Cause of error "Light image" on the printed page
- Enabled toner save.
- Toner cartridge is low
- OPC drum may be faulty by strong light intensity
- Temperature in room is below than 10*C
- Bad contact caused by the toner dirty between the high voltage terminal in the HVPS and the one in the set
- Abnormalities output from the HVPS
How to fix(repair) error "Light image" on the printed page for Canon IRC-4580 printer:
- Disable toner save by change in printer driver.
- Replace the OPC drum.
- Replace developer.
- After printer is power on, wait 30 minutes then start printing
- Clean up the contact between the high voltage terminal in the HVPS and the one in the se- Replace the new HVPS if the problems are not solved by 4 away above.
5. How to fix print quality problem "Ghost" for Canon IRC-4580 printer How to fix print quality problem Ghost
Description: Ghost occurs intervals of the OPC drum or transfer roller.
- OPC drum has fauty.
- The life of the transfer roller has been expired
- The high voltage terminal is contaminated by toner powder or
- Replace OPC drum
- Replace transfer roller
- If performed 2 away and the error does not clear, you should replace ganuine toner cartridge .
- Replacce HVPS board.
Oct 29, 2016 | Canon Office Equipment & Supplies
HP m410n laserjet pro banding gray vertical lines
the two places to look is transfer roller and the fuser unnit.
i think there is a problem with the transfer roller it is under the toner and it needs to be spring loaded. The paper passes between the toner an the transfer roller to charge the paper en let the toner stick to the paper and if it doesn't make correct contact then it wont work
Dec 26, 2013 | HP LaserJet Office Equipment & Supplies
Vertical white lines on page after printing
There will be something covering a small patch of the laser mirror. Find the laser mirror inside the machine (Normally above where the cartridge sits) and wipe this with a clean cloth. Other than taking the cartridge out there is no dissassembly required.
Dec 25, 2012 | Canon LBP 1120 Laser Printer
I think i have a fuser error. When I print something the right side of the paper is very light in color. If I print multiple pages, it gets lighter by every page.
Put paper in the manual feed tray. Print. When the page gets half way into the printer, open the cover. Remove the toner. Look down at the paper. Is the right side lighter than the left? If yes, replace the toner cartridge. I don't believe that a fuser could cause your problem.
Aug 11, 2011 | HP LaserJet 4240n Printer
A vertical black stripe is printing on the left side of the page.
Have you tried replacing the toner cartridgein the printer? If you print a page then remove the toner cartridge, carefully open up the cover that covers the the drum on the toner cartrdige.You can often see a line that corresponds to the line printed on the page.
Oct 13, 2009 | HP LaserJet 1022n Printer
Hp 4550 vertical line down center of page
From the service manual:
Vertical lines or streaks
 Check for a leak where light might be entering the printer.
 Check for circumferential scars on the photosensitive drum. If scars are present, replace the
drum cartridge if the line goes through all colors.
 Check for circumferential scars on the upper fusing roller. If scars are present, replace the upper
fusing roller if the line goes through all colors.
 Remove the imaging drum and inspect main charger or imaging drum for a contaminant, such as
a fiber, if the line goes through all colors.
CAUTION Do not expose the imaging drum to light for more than 15 seconds. The drum is light sensitive, and
exposure to light can cause permanent damage.
Vertical black lines
 The toner cartridge is defective.
 The toner cartridge is not seated properly.
 The fuser entrance is dirty.
 The fuser has scratches on it.
 This might be a repetitive defect. If so, the lines will repeat at a consistent interval down the page.
 The printer needs to be cleaned.
 There is a problem in the heating element.
 If white lines or streaks appear only in the black areas of the printed media, print several
configuration pages to clear the anomaly. If this does not clear the problem, check the sleeve
surface to confirm the defect, then replace the black toner cartridge.
 If white lines appear only in a particular color, try printing several configuration pages to clear the
error. If the error does not clear, check the sleeve surface to confirm the defect, then replace the
defective toner cartridge.
 There is a lack of toner or the toner cartridge is faulty.
 There is dirt in the laser path.
 The fuser is defective.
 A mirror in the laser scanner is dirty.
Apr 07, 2009 | HP Color LaserJet 4550 Printer
Laserjet 5p leaves a thin white vertical line when printing
Either the drum and/or developer is scratched or has a line on it ..
Dec 26, 2008 | HP LaserJet 5p Printer
HP 4100DTN
Run a half test. Start printing a few pages, as it prints open the cover, remove the toner and look down at the paper. Does it have lines on the right side? If yes - replace the toner cartridge.
May 06, 2008 | HP LaserJet 4100dtn Printer
Print quality bad
To clear white vertical lines from printed documents follow the steps listed below:
NOTE: The use of non-Brother or generic toner may cause white vertical lines.
Brother strongly recommends that customers do not use generic drum units and/or toner cartridges, or refill their Brother toner cartridge. Each Brother laser printer is designed to work at pre-set temperatures that are matched exactly to each of our individual toner formulations. Each individual component is designed to work with the other to ensure quality and reliability. Using non-Brother supplies may affect the hardware performance, print quality and machine reliability.
The Brotherlimited warranty does not apply to any problem that is caused by the useof unauthorized third party drum units, toner cartridges or toner.
1. First, power OFF the unit for safety. The ON/OFF switch is located on the left, rear side of the unit.
2. Open the scanner cover by pulling the blue lever located below the control panel toward you and lifting the cover. Make sure the cover is completely open.
3. Remove the drum unit by holding each side of the drum by its handles and gently lifting the drum forward (toward) you.
4. Place the drum unit on a drop cloth or large piece of disposablepaper to avoid spilling and scattering the toner. Make sure thedirections and DR-250 stickers are facing you.
5. With the drum removed from the Brother machine, clean the laser glass. The laser glass is located inside the Brother machine where the drum was located. It is a piece of glass, about 1/2 inch wide and approximately 8 inches long, located on the bottom of the inside. Gently wipe the glass with a clean soft DRY cloth. DO NOT use isopropyl alcoholor any liquid to clean the glass.
6. Gently pull up on the mauve lever to turn the toner cartridge toward you until it stops. Remove the toner cartridge from the drum unit by gently sliding it out of the drum unit. ***Handle the toner cartridge carefully. If toner scatters on your hands or clothes, immediately wipe it off or wash it with cold water.
7. Gently rock the toner cartridge from side to side five or six times to distribute the toner evenly inside the cartridge. Then, reset the toner into the drum (be sure it clicks into place). Gently push on the mauve lever to turn the toner cartridge away from you until it stops.
8. With the DR-250 sticker facing you turn the drum upside down. There is a blue tab located on the right side. Slide the blue tab back and forth seven times to clean the corona wire. When finished, make sure the blue tab is locked to the right side of the drum.
9. Reset drum unit in Brother machine. Close the cover securely.
Print the help list to test the unit by pressing the REPORTS key located on the control panel and then (1) on the dial pad.
If the white vertical lines still continue, the drum unit will need to
be replaced.
If the purchase date of the original drum or replacement drum is less than 90 days (within the warranty of the drum), contact Brother Customer Service Center at 1-877-Brother (1-877-276-8437) . The center is open Monday-Friday, 9:00am to 7:00 pm EST, excluding holidays.
Dec 26, 2007 | Brother MFC 6800 All-In-One Laser Printer
HP Color LaserJet 2600n - Thin White Line on Print Out
Which color is this line? Try changing respective cartridge..
Sep 09, 2007 | HP Color LaserJet 2600n Printer
HP LaserJet 4240n Printer Logo
122 people viewed this question
Seeker5211
Seeker5211
