Question about Sony BRAVIA XBR 52 in. LCD Flat-Panel HDTV
I have Sony bravia XBR and right side the screen is more darker and have lost color. Any idea. please help if u can.
  • 50 Answers
My guess is that the right side of the t-con board/LCD control unit if failing. this board controls video drive on screen 2 processors on the circuit 1 for right the other for left. if this does not fix then the problem is going to be the display it-self which is not cost effective to repair. Hope this helps some.
Also before replacing anything clean all ribbon cables between main board and lcd control unit and between the lcd control and panel.
can clean with pencil eraser. board location
main unit - circuit to the left or middle usually have inputs on it.
LCD control- top and center with 2-4 ribbons leaving the top and going to the screen.
hope this helps.
Posted on Apr 27, 2010
I have a 70 inch Bravia XBR 70X850B which up until yesterday green/red/pink vertical line that runs across the middle of the screen.
If you wish to get some details; check the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/ Line faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD & Plasma screen are similar, irrespective of its brand and screen size.
Search the site by type in the "BRAND NAME" of your device; (Exclude the model number), in the "Search box at the top right of the display window of the Homepage" to get gathered related posts
Nov 17, 2016 | Sony XBR Televison & Video
Sony bravia kdl-46Xbr4 right side of screen is darker until the tv warms up flickers like a floresent bulb and is a brownish color
Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis.
To some model sets; especially LED back-lighted types; the back-light inverter circuit will be part of the main power supply board [SMPS]. In such cases, the power supply board might need replacement. To some models sets, the back-light inverter and SMPS section circuit will be integrated at its main board itself. If so; the main board should be replaced. To some models of sets, all these section circuit will be integrated at its main board. If this is the case, you have to replace the main board.
Oct 01, 2016 | Sony Bravia XBR-Series KDL-46XBR4 46-Inch...
SONY BRAVIA KDL-40XBR2 faces look like cartoons
Tow possibilities. [1] The LVDS cable (the flat cable that connects between T'Con and LCD panel) loose contact at its connection sockets. Re-insert this very carefully, and check. [2] Fault to T'Con board itself. If so it should be replaced. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Faults & possible causes to LCD screen are given with illustrations. You can get an idea about the fault to an extent.
Oct 28, 2014 | Sony Bravia XBR-Series KDL-40XBR2 40-Inch...
We have a 52" Sony
This problems alway the causing of the board,that call the T-CON decodering board it is dying.This T-CON decodering board alway sit in the middle at the bottom of the LCD screen panel.Tries websites like Shopjimmy.com,Ebay.com to buy a rrefurbish T-CON decodering board for the replacement.
Mar 21, 2011 | Sony BRAVIA XBR 52 in. LCD Flat-Panel HDTV
I have a 46 inch Sony Bravia 46 XBR4 set. The right side went out only colored lines appear. The rest of the screen is fine. email address GLCSS19@AOL.COM.
Sounds like the tcon (timing control) board. Sometimes unplugging the LVDS cables from the tcon, cleaning and reconnecting solves this. The catches on the LVDS cables are easily damaged and must be handled carefully.
Jan 20, 2011 | Sony BRAVIA XBR 52 in. LCD Flat-Panel HDTV
LOST THE LIGHT BULB [SET ON RIGHT SIDE OF SCREEN] THEN LOST BLUE
I replaced bulb on SOny XBR 60 with sony brand bulb about six months ago. everything was fine, then a week ago it seems that I lost the "red" portion of the color. Any suggestions?
Jul 23, 2009 | Sony Grand WEGA KF60XBR800 60" Rear...
Sony Bravia KDL-46Z4100
if the line is in the same place all the time im afraid to say that is a pixel problem on your display contact sony they may offer you a replacement display or altleast a way of changing the set.
Mar 10, 2009 | Sony BRAVIA XBR KDL-V26XBR1 26 in. LCD...
Sony Bravia XBR 40" LCD
First, HORIZONTAL CENTER.
1) Press MENU.
2) Scroll to SETTINGS.
3) Scroll to SCREEN.
4) Go to HORIZONTAL CENTER. Move the picture to the right. Hopefully, the line will go away. Otherwise, there is a problem with the pixels or the signal processor. Call 1-800-222-SONY. Or, http://eservice.sony.com. Have a high-limit credit card handy for out of warranty repairs. Sorry about that.
Aug 27, 2007 | Sony BRAVIA KDL-40S2000 40 in. LCD HDTV
'No Signal' on Sony XBR
on the tv remote: press menu, external entry is highlight (yellow) right press on the outer circle then scroll down to video 4 (satellite entry) (it could be on video 3 depending of the satellite assignment entry) when video 4 is highlight (yellow) right press on the outer circle on the screen you will see 1080i if settle on an HD channel hope it will fix your Sony Bravia..
May 30, 2007 | Sony BRAVIA XBR KDL-V26XBR1 26 in. LCD...
Sony BRAVIA XBR 52 in. LCD Flat-Panel HDTV Logo
339 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
