Question about Garmin StreetPilot c340 GPS Receiver
Will antenna help?
Hi, I've recently purchased a Garmin c340. Its great! My only problem is that at times, when I first start up my car, it could take quite a while to acquire satellite signal. Will an antenna help? The unit is mounted on my dash and I park outside where there are some trees overhead although none of the leaves are in yet. Does anybody have experience with an antenna? Also, how about the less expensive antennas you see on ebay? Thanks, Lou
    Scholar:
  • 52 Answers
What is your car brand & model?
I ask, because some vehicles use a thinfilm windshield heater for defrosting/de-icing. This file is conductive, and will act as a shield to the RF microwave signals that GPS operates on. Consulting the owners manual, or the car dealer could help determine if this is your case.
Please try the unit outside the vehicle (in the same location as you have troubles) and see if the issue resolves itself. If so, then yes, using an external antenna can resolve the issue, but it will need to be located in a place not covered by that same problem.
All GARMIN external antennas are waterproof and have a very thin cable, so it could be located outside the vehicle. Alternatively, a side-window mount for the antenna could be used, if that's a viable solution in your application.
The "less-expensive" antennas mentioned can work, most will, but you may not get the optimal performance as one designed specifically for the GARMIN units. Personally, I've used an afermarket one and had good results, but the GARMIN ones always seem better.
Posted on May 04, 2008
Can the touch screen on my garmin c340 gps be replaced?
Yes, it could be easily replaced. If you want to purchase only touch screen, buy it from :-
http://cgi.ebay.com/GARMIN-C340-C-340-Street-Pilot-Touch-Screen-Digitizer-U-/270622808154?pt=PDA_Accessories&hash=item3f0260585a
If you wanted to replace LCD screen as well, buy it from :-
http://cgi.ebay.com/LCD-Screen-Touch-Digitizer-Garmin-C340-U-/120457660971?pt=PDA_Accessories&hash=item1c0bd60a2b
Let me know,if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Aug 27, 2010 | Garmin StreetPilot c340 GPS Receiver
What does the antena look like? I droped mine and it looks like mabe somthing broke off ican see a little koax showing.
The antenna on the C340 is internal. There is a connection for an external antenna, however, and you may be looking at this.
Feb 05, 2010 | Garmin StreetPilot c340 GPS Receiver
C340 will not come on by battery or plugged into car. Could the lithium-ion battery be bad, if so how do I replace?
Try pulling the face off and resetting it,
If it will not reset, work in the car or the house,
The battery need's replacing.
If your savvy (soldering), Ebay for battery,
or Garmin Around $100
http://www8.garmin.com/support/outofwarranty.html
http://www.gpspassion.com/forumsen/topic.asp?TOPIC_ID=67938&whichpage=1
Regards
Jun 19, 2009 | Garmin StreetPilot c340 GPS Receiver
Garmin street pilot
I had the same issue with mine during a trip. Probably needs to bereset. See page 31 of the users manual on Resetting your c340. Once Idid this it worked fine.
http://www8.garmin.com/manuals/StreetPilotc340_OwnersManual.pdf
Nov 01, 2008 | Garmin StreetPilot c340 GPS Receiver
StreetPilot C330 Need a Screen
If you are technically incline, purchase a damaged unit off ebay and swap out the parts. Take note that taking the Garmin apart is not difficult, just keep note of how the antenna comes out. That is the only hook I know that will hang up most people.06dd1c8.jpg
Jul 21, 2008 | Garmin StreetPilot C330 GPS Receiver
My Garmin C340 is dead!!!!
I had the same problem on a trip. Required two fixes and once I did this the unit worked fine.
1. Replace the fuse in the car adapter (reason it wasn't charging when I used it in the car).
2. See the users manual on page 31 regarding resetting your C340.
Jul 21, 2008 | Garmin StreetPilot c340 GPS Receiver
Upgrade the map
Map updates are available for purchase from www.garmin.com, or a local retailer which sells Garmin GPS products.
Jun 03, 2008 | Garmin StreetPilot c340 GPS Receiver
Street Pilot C340
The only way to update the maps is to purchase new maps from Garmin and download them via the computer. The 2008 map updates are currently available, and Garmin has told me new maps will be out in a few months.
Mar 09, 2008 | Garmin StreetPilot c340 GPS Receiver
Garmin c340 FROZE? Here is how to fix it!
My garmin shuts down immediatly when I switch it on. Dont know if there is an internal battery that needs to be replaced or some thing else.
Jan 26, 2008 | Garmin StreetPilot c340 GPS Receiver
C340
I had the same problem recently... What I did was open the front casing and hit the reset button under the cover, then it turned on while plugged into the car adapter.
Dec 29, 2006 | Garmin StreetPilot c340 GPS Receiver
Garmin StreetPilot c340 GPS Receiver Logo
62 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
Steve
Are you a Garmin GPS Expert? Answer questions, earn points and help others
