Question about Epson Stylus CX4200 All-In-One InkJet Printer
I replaced all of my ink with the proper cartridges, and my prints are coming out faded
  • 3,940 Answers
Follow these steps to clean the print head:
  1. Make sure the Stylus CX is on and the I replaced all of my - cp_light_183_er.gif ink light is off.
  2. Hold down the ink button for 3 seconds until the cp_light_1.gif On light starts flashing. The Stylus CX runs a head cleaning cycle and I replaced all of my - cp_light_1.gifhttp://i.fixya.net/uploads/images/cp_light_1.gif" alt="cp_light_1.gif" class="h_mi" /> On light flasheI replaced all of my - alert_caution.gif alert_caution.gif Caution:
    Never turn off the Stylus CX while head cleaning is in progress. You may damage it. I replaced all of my - cp_light_1.gif/>
  3. When the cp_light_1.gif On light stops flashing, turn off the Stylus CX.
  4. Load letter-size paper inI replaced all of my - cp_button_48_er.gif/li>
  5. Press the cp_button_48_er.gif ink and cp_button_1.gif On buttons together and hold them down for about 3 seconds. The Stylus CX turns on and prints a test pattern, which includes a nozzle check. Shown beI replaced all of my - im_158_er.gifexamples of what the nozzle check may look like:
    Nozzle check pattern with no gaps
alert_note.gif Note:
If you don't see any improvement after cleaning the print head four or five times, turn off the Stylus CX and wait overnight. This lets any dried ink soften. Then try cleaning the print head again.
If you do not use your Stylus CX often, it is a good idea to print a few pages at least once a month to maintain good print quality.
Posted on Apr 27, 2010
IB4G2008
  • 3587 Answers
SOURCE: Faded print job
ok...have you tried a clean and re calibrate lately on those print heads?
Posted on Mar 20, 2008
SOURCE: Print faded after replacing black cartridge Brother 240C
The print heads don't appreciate being out of ink so the Brother printer has sensors to prevent that but the tape defeated that prevention. Maybe more cleanings or maybe a cartridge with printhead cleaning solution will help. Otherwise, I fear a new printer.
Posted on Jan 08, 2009
SOURCE: canon ip1880 color cartridge cannot detect & extra ink still ful
press the resume button for 5 second
Posted on Jan 29, 2009
  • 326 Answers
SOURCE: new ink cartridge but not printing green on esp 5 kodak all inone
you need to use the head cleaning tool in the printer properties, youll need to keep running it untill it runs clear and it uses alot of your ink while it does it.
youll find the cleaning option if you go to your
start/settings/printers and faxes, right click on your printer and go to printer preferences then maintinence
Posted on May 08, 2009
SOURCE: HP L7590 black ink printing poorly even with new HP cartridge
I have had the same problem It is the print head not the cartridge If your printer is still under warranty have the printhead(s) replaced if not Open the unit where the print heads are and hold the OK button for 5 seconds. The Print head carriage will move to the left
Carefully remove the KY (Black & Yellow) Print head with a cotton swab and alcohol clean the contacts and replace the printhead. If this does not work remove the printhead and then with a spray bottle spray the nozzle area on the bottom (DO NOT TOUCH THE NOZZLES AS THEY WILL BE DESTROYED) HP techs have told me this will void any warranty so act accordingly I use a printhead cleaning solution available from most any online ink supplier
Replace the printhead after it has dried out (less than a minute). The printer will then go through an alignment cycle and should print I had to do this several times before the print head performed as it should
Posted on Jun 16, 2009
Yellow ink faded on one side of copy
Ink News - How To Correct Faded Prints From Toner ...
www.inkpal.com/ink.../tips-to-correct-faded-prints-from-toner-cartridges...
Rating: 3 - ‎12 votes
Mar 30, 2012 - You should particularly suspect this if the prints are faded on only one side and if the printer is not telling you to replace the toner cartridge.Missing: yellow
HP Officejet 6500 Printers - Fixing Print Quality Problems ...
support.hp.com/us-en/document/c01641184
Jan 16, 2016 | Office Equipment & Supplies
DOCUMENTS PRINT IN FADED GREEN OR FADED BLACK
do a test print and check to see if the nozzles are firing properly and the colors are correct. if you are using generic ink that could be an issue.
do a couple cleanings and then another nozzle check to see if it has improved.
if you replace the ink cartridge, remember that it will take time for the new ink to creep into the printhead system.
Sep 02, 2010 | Brother DCP-110C All-In-One InkJet Printer
HP officejet pro 8500 ink cartridge problem
Changing a printer cartridge is not complex but improper handling of the parts may damage the printer and the cartridge. If the user notices that while printing the ink comes out dry or faded, it may be time to change the ink or the toner. The user will know if it is time to change the toner because instead of a sharp image, one will get a faded image. It is time to change the ink cartridge when the printing comes out spotty or colors are used to replace others —for instance, blue for black or yellow for red. Remember, faded images signal the need to change the toner; spotty printing signals the need to change the ink cartridge get more help for change cartridge .
Hope this helps you.
Jan 21, 2010 | HP Officejet Pro 8500 Wireless All-In-One...
My Canon printer is having printing problems.
I think your cartridge have a cross contamination of ink ..you need to replace it ..
May 15, 2009 | Canon PIXMA MP210 Photo All-In-One Printer
Ink is fading fast while using brand new ink cartridges
Have you replaced the Drum or is it a BJ-Ink printer?
Nov 11, 2008 | Office Equipment & Supplies
Dec 13, 2007 | Brother Multi-Function Center MFC-240C...
Faded print on one side of page
I have a SCX-4100 Samsung, replaced the tonger cartridge, it was working fine for a few hundred sheets of printing, but after that, the left side of the page was printed very light, faded.
If I run the "Clean Drum", it will print a litter better, but still faded.
What can I do to correct this problem?
Thank you
TT
Nov 24, 2007 | Samsung ML 1710 Laser Printer
Printing
please check the cartridges holders and clean it
Oct 05, 2007 | Lexmark X85 All-In-One InkJet Printer
Epson Stylus CX4200 All-In-One InkJet Printer Logo
106 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
