Question about Kicker KX400.2 Car Audio Amplifier
My kx 400.2 amp turns on but no sound
I have two ten inch subs and a kx 400.2 amp. The amp turns on but I think my amp and the subs aren't correctly hooked up. Can you please help?
2 Suggested Answers
jhall1793
  • 60 Answers
SOURCE: will this give me 400 watts on each
bignatedabal: You can't get something more out of a device than it's rating. In other words, if you have a 400W amp that's all it's going to produce. For example if you're looking to drive both sub spkrs @ 350W each then buy a sub amp with a rating of 700W @ 2ohms & connect your 4ohm spkrs in parallel to the amp. Each spkr will produce 350W of sound if everything is installed correctly.
1 thing to look for in amp mfg's. Look for those who rate their amps in RMS power. This is the true output rating. Many amps are rated in peak-to-peak which seems great but doesn't tell you the real story, unless you know how to do the math to determine the RMS. The better mfg's will take the time to test their amps & rate them properly. Also look for massive heatsinking (the cooling fins). I consider cooling fans to be a benefit as well.
If you have addtional questions, drop me a line.
peace-out
Posted on Jan 18, 2009
Cadence 400 watt active sub green light on, no sound from the sub. whats wrong?
proceed according and fix it. However yi\ou must read the diode LED for diagnose. God bless you
Mar 26, 2013 | Exercise & Fitness
My klipsch ten inch subwoofer is making a high pitch whinding sound when the sub is turned on
my fuse keeps poppin everytime i put a new one when i turn it on how can i fix dat?
Aug 01, 2012 | Klipsch Synergy Sub-10 Subwoofer Speaker
1300a, no sound, protect light
if u have the amp bridged un bridge it. chack an see wat the ohms are on the subs an make sure the amp is stable to carry the ohm load..if u have 4ohm subs one sub per channel then u shud be fine that wud make the amp see 4ohms but if u have dual voice coil subs it cud be the configuration of the subs..here's a link on how to wire subs hope this help..http://mobile.jlaudio.com/support_pages.php?page_id=145
Jan 12, 2010 | Car Audio & Video
Getting my son a sony xplod xm-1652 2 channel what subs would sound good and the things says 1000x2 and 500x2 what is the truth
165 watts x 2 @ 4ohms and 200-230 watts@ 2 ohms or 400-460 watts bridged into a 4 ohm mono load is what the amp will actually do. A single 12 inch sub or a pair of 10 inch subs or 12s would be great
Nov 22, 2009 | Sony Xplod XM-1652Z Car Audio Amplifier
Amp turns off.
your drawing/pulling too many amps. Is it a mono(one speaker), two way(two speakers/can be briged to one), or a four way(four speakers/can be brigrd to two). don't put too many speaker to that one amp if it's only a mono, or a two way.
Sep 24, 2009 | Kenwood KAC-9152D Car Audio Amplifier
I have this same problem
Check the power with a volt meter. The battery power, then the remote power. Also make sure it's grounded properly. bad grounds cause mayhem.
Sep 14, 2009 | Pyle BZDBP212 Car Subwoofer
Can i run 1 10 inch sub of the stock amp that
Not made for that. Its a high pass amp to power the speakers, unless you have a stock sub, but its still going to be to weak to get full potential out of the sub.
Aug 17, 2009 | 2001 Jeep Grand Cherokee
Subs sound terrible (Ive tried so many things)
NO it won't be your battery. Sounds more like your deck.
Jan 22, 2009 | Jl Audio 12W3 Car Subwoofer
Will this give me 400 watts on each
peace-out
Jan 18, 2009 | Kicker ZX400.1 Car Audio Amplifier
Problem when hooking two 12 inch subs to one amp
the amp is no where near strong enough that sound you hear is called hard clipping and it will destroy your subs in minutes. depending on what model JL subs you have I can sell you a better amp.
Dec 30, 2008 | Planet Audio VX602 Car Audio Amplifier
Kicker KX400.2 Car Audio Amplifier Logo
51 people viewed this question
Top Kicker Car Audio & Video Experts
Professor_V
Professor_V
Tygh Duval
Tygh Duval
Are you a Kicker Car Audio and Video Expert? Answer questions, earn points and help others
