Question about Canon PIXMA MP760 All-In-One InkJet Printer
The black ink 3Be isn't printing fully. I have cleaned the nozzle 5 times and done a regular cleaning as well. And it still is not printing fully.
  • 4,041 Answers
Summary
Usage of compatible ink and leave the printer idle too long may cause printhead clogging
What should you do if you get this problem. Relax; you may recover the printhead by unclogging it. Follow these steps to unclog the printhead
1. Right click in the printer driver name
2. Select Properties menu
3. Click Maintenance tab
4. Click on cleaning sign for regular cleaning. Perform this up to 3 times.
5. If this does not work, perform Deep Cleaning
And if that not work
Some times it needs a good clean up but this is up to you if you want to do this,
But after you done this prime the printer so it gets the inks back in the heads, it may take a little time for the inks to work.
Ok.
There is fluid cleaner for this but I can never find any in the shops the only ones I seen is when they sell them in Tesco but they come in with the ink refill bottles so I just use worm water by it self on a cloth and dabbing on the heads to clean them, it will not harm the heads but not to much water.
Some heads are on the inks them self but some have them inside the printer so I not know your printer so if the heads are inside you need to get them out you may find that some heads will just clip out put some need to be unscrewed so you got to know how they come out so be careful and not push to hard on them, if the heads are on the ink then it is a easy job to clean them,
It worth a try it worked for me more than ones.
Please all I ask is call back and just gave a vote, it will gave me some satisfaction to know am helping some one, so I will keep on helping.
All The Best: Pineworks
Posted on Apr 27, 2010
My black ink is not working please tell me how to clean it
Hi
To clean it, remove the ink cartridge and rub the print head into a plain paper with rubbing alcohol until ink flows. Then run the print nozzle for 2 time for further cleaning the print head. Then try to print again.
Another way is to soak the print head only into a how water for 5 minutes until ink loose up and ink flows, rub the print head into a plain paper with rubbing alcohol until ink flows. Run the print nozzle and then try to print again
Post comment for more help
Mar 18, 2011 | Office Equipment & Supplies
Hi my printer won't print black, test colour work but no black, therefore all text to print is blank. I have replaced the ink with a new one and cleaned it 5 times, still no black ink. Thanks
Hi
Clean it manually by removing the black ink cartridge and rub the print head into a paper with rubbing alcohol until ink flows more. Then run the print nozzle to clean the print head thoroughly. After, try to print again.
If not, dip the print head only into hot water for 5 minutes and then run the print nozzle.
Let me know if you need more help
Mar 08, 2011 | Brother MFC 420CN All-In-One InkJet...
I've just replaced the black ink cartridge for my Epson Stylus TX100, ink level is ok as the indicator shows. But i get blank prints for black, other colors are fine. What's wrong with the black ink...
There is nothing wrong with the black ink. Just run the head cleaning for better printing.
1. Go to printer and faxes
2. Right click your printer ( Epson Stylus Multifunction Printer/ Copier/ Scanner InkJet)
3. Click printing preferences
4. Click Maintenance Tab
5. Click Head Cleaning
6. Run head cleaning for 5 times then try printing.
Nov 15, 2010 | Epson Stylus Multifunction Inkjet Printer/...
I have an HP Photosmart D7560 printer. It worked fine until it was left with no cartridges in it for a few weeks. Put in 5 new cartridges and it would only print black. Tried various head cleaning and...
You may need to clean them manually. Take out each cartridge, clean its electronic panel with tissue soaked in a bit of methylated spirit. Also clean the area of contact in the carriage for each cartridge.
If patiently and carefully done all the colours will begin to print; so long as they are still flowing at the nozzle (not dried at the nozzle). To check if they are not dried at the nozzles, apply folded tissue to each cartridge nozzle and press gently, upon removing it, it should come out well/stained with the respective colour. If not you should place in a saucer or plate with a bit of water. Leave for about ten minutes. Then apply the folded tissue again. Ink should blot it well now. If not it means your ink is dried out and you may need to replace that cartridge.
Good luck and God bless!
Nov 13, 2010 | HP Photosmart D7560 InkJet Printer
Will no print black color doc if any other color ink is empty
actually, its not. the reason is, there is a small resovoire (sp?) in the ink cartridges. if you continue to print, the nozzles will clog up, and can cause all the nozzles not to work. even when you do just black, the printer has to clean at times all the nozzles and if your nozzles are empty, air will go into the deep and dry up the excess ink.
if you are going to do primarily black prints, you should get a black and white laser for those uses only.
Jun 13, 2009 | Brother MFC 420CN All-In-One InkJet...
New ink cartrage
Print Nozzle Check Pattern
  1. Press the Open button to open the output tray.
  2. Load letter-sized plain paper in the auto sheet feeder (ASF) or the cassette.
  3. Display the Maintenance screen on the printer.
  4. Press the up or down cursor to select [Nozzle check], then press the <OK>.
  5. Press the up or down cursor to select [Yes], then press <OK>. (The nozzle check pattern is printed.)
  6. Confirm the nozzle check pattern.
05sj00160_03a.gif 05sj00160_03b.gif < 1 > The normal nozzle check pattern
< 2 > The abnormal nozzle check pattern
< 3 > Some black ink lines are broken.
< 4 > White lines are present in the color ink pattern.
< 5 > Both black and color inks are not present.
Note:
  1. When all patterns are printed normally, press the up / down cursor button to select "All A" and press the OK button.
  2. When any patterns are printed abnormally, press the up / down cursor button to select "Also B" and press the OK button.
Print Head Cleaning:
  1. Display the Maintenance screen on the printer.
  2. Press the up or down cursor to select [Cleaning], then press <OK>.
  3. Press the up or down cursor to select [Yes], then press <OK> to start print head cleaning.
    Note:
    Do not do any other operations until print head cleaning is completed.
  4. Print the nozzle check pattern and check the print head status.
Deep (Print Head) cleaning:
  1. Display the Maintenance screen.
  2. Press the up or down cursor to select [Deep cleaning], then press <OK>.
  3. Press the up or down cursor to select [Yes], then press <OK> to start print head deep cleaning.
    Note:
    Do not do any other operations until print head deep cleaning is completed.
    Note:
    Ifthe printed result does not improve even after doing print head deepcleaning, turn off the printer. Then, after 24 hours or later, do printhead deep cleaning again. (After a given time interval, ink coulddissolve itself, resulting in ink unclogging.
Jan 08, 2009 | Canon PIXMA MP830 All-In-One InkJet...
There is no ink on the paper
Hi Kontiki28. It seems you either have seriously blocked black ink nozzles, or you have faulty black ink nozzles. You can try the nozzle cleaning method described below, but remember it can take quite a while.
Turn the printer on, and as soon as the print head moves out of its parking position, pull the power cord out of the back, or turn the printer off at the mains. You may now carefully move the print head by hand over to the left hand side out of the way. Look inside the print head parking area on the right and you will see a small rubber cup that comes up to cover the print nozzles when the head is parked (to stop it drying out). Use a syringe or dropper to fill this cup with head cleaning fluid or distilled water. DO NOT USE TAP WATER. Carefully push the print head by hand fully into its parking position so that the cup full of fluid comes up over the print head. Do not turn the printer on at any stage in this process. Leave this for at least 24 hours, then turn the printer on and try a head clean/nozzle check again. If you get any black ink on the nozzle check, then there is hope! Repeat the process until you get a full black nozzle check.
If nothing, repeat the process once more. If still nothing, post a new comment detailing what you have done and the results.
Jan 08, 2009 | Epson Stylus C88 InkJet Photo Printer
Black not printing about every 3rd line
You have the classic single nozzle failure it appears. You say you have done a nozzle check. This should reveal that one of the black nozzles is not working i.e. there is a single gap in your nozzle check printout for the black nozzles. Now, this may be due to a blocked nozzle. Try the following print head soak process.
Turn the printer on, and as soon as the print head moves pull the power cord out of the back, or turn the printer off at the mains. You may now carefully move the print head by hand over to the left hand side out of the way. Look inside the print head parking area on the right and you will see a small rubber cup that comes up to cover the print nozzles when the head is parked (to stop it drying out). Use a syringe or dropper to fill this cup with head cleaning fluid or distilled water. DO NOT USE TAP WATER. Carefully push the print head fully into its parking position so that the cup full of fluid comes up over the print head. Leave this for at least 24 hours, then try a head clean again. If still nothing, report back
Dec 08, 2008 | Epson Stylus C84 InkJet Printer
Black ink not working
Have you carried out any head cleaning cycles. If not, do it, then a nozzle check. Any sign of ink? If so do a couple more nozzle checks. If still not perfect, let it rest for 24 hours to disperse air bubbles. Then repeat. If you already have done lots of head cleans with no result, and you're sure you have a good ink cartridge in, then you can try soaking the print heads for 24 hours (or more), as follows.
Aug 06, 2008 | Epson Stylus Photo 820 InkJet Printer
Canon iP90 Printer Ink Issue
I have had the same issue with my iP90.  I think this results from the black ink nozzle becoming clogged.  I was able to get mine to print by cleaning the nozzles.To clean the print nozzles open the Canon IJ Printer Utility, select the printer from the list of available printers and click the maintenance button.  Then, select a cleaning or deep cleaning cycle.
Jan 02, 2008 | Canon S 330 InkJet Printer
Open Questions:
See all Canon PIXMA MP760 All-In-One InkJet Printer Questions
Canon PIXMA MP760 All-In-One InkJet Printer Logo
421 people viewed this question
old marine
old marine
