Question about Samsung SyncMaster 930B 19" LCD Flat Panel Monitor
My Samsung SyncMaster 930b monitor will randomly black out and display the white and blue "Analog" then "Digital" 2 inch box on the upper left corner of the black screen a few times then go completely black. I've had my monitor for a number of years now. I'm assuming it's just its time to go. This typically seems to happen when I've had my computer on for long periods of time and usually resolves itself after I shut down the computer for an hour or so. Any ideas? If it's on its way out, is there any way I could try to fix it?
  • jmaurer32 Apr 27, 2010
    I do believe dhecom answered my question here. If this isn't the solution to my particular problem, I'd still like to know. Thanks.
    Problem Solver:
  • 5 Answers
It is probably NOT the picture board, it is VERY simple to decide what is wrong... There are about 4 or five screws on the back that will allow you to pry the back cover off. When you get that off look at the LARGER of the two printed circuit boards. THat is the POWER supply board. There are usually thee screws and a couple of little wire clips holding it on. Pop the clips off (NOTE! I use a sharpie marker to give each one a number so I can match them up later. Take the board off and look for three capacitors in a row.. Look like little silver beer cans standing on their ends. They should have some marking similar to: 820uF 25v 105c on them. Look at the top of the little cans (They have a little X on them). Do the cans look like they are flat on the top or are they about to explode?? ;)
If they are curved out like a beer can that wants to pop, they are bad. I would now go to newark.com and look up an 820mf 25v 105c capacitor and order 3 or 4 of them.. They cost < $1 each...
I found them HERE:
http://www.newark.com/panasonic/eeufc1e821/capacitor-820uf-25v-capacitor-820uf/dp/25M9172
Get them in, and take the bard to ANY electronics repair store (local PC repair shops probably have someone that can replace them. Once replaced, simply put the board back in, hook up the connectors, close the case and try it out.. Probably will work for another 5 years now.
Posted on Jun 18, 2010
    President:
  • 1,561 Answers
There is very much hope if you are still very much in need of it.
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} The problem with your monitor is the picture board, the picture board of your monitor is bad, since the power led or button is on, it means the picture board of your monitor has developed fault.
The best thing for you to do now is to take the monitor to a local repairer within your vicinity or any service center to help with the replacement of the picture board because the fault is not something you can fix yourself, in order not to complicate issues.
Take care.
Posted on Apr 27, 2010
  • Sulaimon Jimoh Olayemi Apr 27, 2010
    Please this is the original message sent to you here, the problem with your monitor is that the picture board has started malfunctioning .
    Normal
    0
    false
    false
    false
    font-size:10.0pt;
    The picture board on your monitor is bad, since the power led or button is on, it means the picture board
    within your vicinity or service center to help with the replacement of the picture board because
    issues.
    Take care.
    The problem with your monitor is that the picture board of your monitor has started
    malfunctioning, since the power led or button is on, it just go to blank gradually through series of steps. it means the
    to
    complicate issues.
    Take care.
Samsung syncmaster 930b 19inch: blinking green light on startup screen does not respond turn off or on after a random time period it usually works once screen goes from black to windows it stays...
<P>If you try new cable, try with another PC and still have the same problem, then you need to inspect the inside for bad caps first just like all the SAMSUNG as shown.</P><P style="tab-stops: center 3.25in left 255.75pt"><SPAN style="FONT-SIZE: 10pt; FONT-FAMILY: 'Arial','sans-serif'"><A href="http://s807.photobucket.com/home/budm/allalbums"><FONT color=#800080>http://s807.photobucket.com/home/budm/allalbums</FONT></A><?xml:namespace prefix = o ns = "urn:schemas-microsoft-com:office:office" /><o:p></o:p></SPAN></P><P><SPAN style="FONT-SIZE: 10pt; FONT-FAMILY: 'Arial','sans-serif'"><A href="http://en.wikipedia.org/wiki/Capacitor_plague">http://en.wikipedia.org/wiki/Capacitor_plague</A><o:p></o:p></SPAN></P><P><SPAN style="FONT-SIZE: 10pt; FONT-FAMILY: 'Arial','sans-serif'">Capacitors kit: <A href="http://lcdalternatives.auctivacommerce.com/Viewsonic-C196320.aspx"><SPAN style="mso-spacerun: yes">&nbsp;</SPAN>http://lcdalternatives.auctivacommerce.com/</A><SPAN style="mso-spacerun: yes">&nbsp; </SPAN>he can make you a set of caps for you.<o:p></o:p></SPAN></P><P>&nbsp;</P>
Aug 25, 2010 | Samsung SyncMaster 930B 19" LCD Flat Panel...
Monitor will flash the display for a second then go black again.
Most common failure in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed SAMSUNG monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further and it will help out other people in the future also.
http://www.badcaps.net
Apr 12, 2010 | Samsung SyncMaster 930B 19" LCD Flat Panel...
Samsung syncmaster713bm not optimum mode
try to adjust resolution you monitor may not support higher resolution change it in the display properties
Mar 13, 2010 | Computers & Internet
My Samsung Syncmaster 930B was working fine unti I disconnected and then reconnected it to my computer. Now I get a black screen with a roaming box that says, "check signal cable".
Hello
1st Pull all power from pc from the wall.Plug back in and start pc up.
While starting hold down the f8 key and select safe mode.
once in go to control panel and select display.
set resoulution to default 60 hz and screen size to 800 by 600.
Reboot.
You may need to readjust your screen again.
Hope this helps.
Jan 14, 2010 | Samsung SyncMaster 930B 19" LCD Flat Panel...
My Monitor, which had never been used but been in storage for about 1 year, has a 2 inch translucent vertical pink stripe down the left hand side. Rest of image is perfect. Any idea how to make this go...
Check the RGB settings from the monitor panel.... Plus try moving the neck of the monitor left and right a couple of times.... Sometimes, the picture tube displays illegitimate pictures with some twisted cables or so...
Jan 09, 2010 | Samsung SyncMaster 930B 19" LCD Flat Panel...
After starting the computer the screen is black and only displays digital analog on screen and the blue light is flashing. It then displays a box say "check signal digital analog." please help me. Thanx.
This blue light flashing means there is power to monitor bu NO video signal. No Analog or digital Video . analog is the regular plug for PC to Monitor, the other is HDMI digital or other digital. Check signal digital/analog means again: No video signal from PC detected.
Daddy
Dec 02, 2009 | Samsung Syncmaster 940BW LCD Monitor
Samsung syncmaster 931a... connected to computer
Hi, its unlikely to be the cable. Most likely cause of this is a faulty inverter board. If you are lucky it will only be 1 or 2 blown capacitors which are easily identifiable and replaceable once you have got inside it. it could however, be almost any of the components on the inverter board or even a failed backlight but this will require further testing and a knowledge of LCD monitor workings.
Nov 03, 2009 | Computers & Internet
A box stating not optimum mode-get distorted internet images
Sounds like your resolution is not set correctly.
Try going to Start-->Control Panel-->Display and choose the Settings Tab
Under there change the resolution slider bar to 1280x1024
Should do the trick!
Jul 11, 2009 | Samsung SyncMaster 913V 19" Flat Panel LCD...
I have a Samsung Syncmaster 2053bw. Screen
First of all plug another monitor to the VC on your PC and do the same for the SamSung"I over heat"SyncMaster2 053BW. Reply!
Jul 07, 2009 | Samsung Computers & Internet
Samsung 930b analog to digital input
Did you check for new drivers to both vid card and display? That'd be the first thing to try.
May 30, 2008 | Samsung SyncMaster 930B 19" LCD Flat Panel...
Samsung SyncMaster 930B 19" LCD Flat Panel Monitor Logo
247 people viewed this question
Top Samsung Computers & Internet Experts
Computer Repairing
Computer Repairing
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
