Question about National Little Tikes Hummer Yellow
My little tykes hummer will not go-no power ever since i turned it upside down to empty the dirt my son put in there-reverse started to go but now i have no power whatso ever
  • 1,284 Answers
Hi, first, I replaced the battery. No need to buy the expensive branded battery - in the case of the Hummer H2, just get a standard 12v 12mAh battery and attach the special wiring harness from the old one to it.
I then de-soldered and re-soldered a bad connection on the battery cable.
Then, I took apart the gear shifter and used contact cleaner on all the switches.
Finally, the jeep works!!!
Take care
Posted on Apr 27, 2010
The directions say that the bottom filter should be cleaned every six weeks or so. It becomes clogged each time we vacuum
Your seal on the bottom door that dumps the dirt is not properly seated. It is possible it got bumped when you emptied the dirt one time. Take it off the center tube in the dirt canister, clean everything and put it back on. It can be put on upside down so in the event you took it off once, it is possible you put it on upside down.
Mar 06, 2011 | Dyson DC17 Animal Bagless Upright Cyclonic...
Mykeyboardisnotworkingeverytimeiclickitnothinghappentellmewhattodo
dirt between the buttons can be one reason, another is wear between the contacts, keyboard is easy cleaned, just put it upside down and use stiff brush to clean between the buttons.
if contacts are dirty, usually caused by spill (my son spill coffe at least twice a year on keyboard during last 10 years of his programming...). easy way is to if use corded keyboard (if wireless start from step3)
1. switch off the computer
2. remove keyboard cable from socket
3. remove batteries if installed
4. turn keyboard upside down
5. remove all screws
6. turn back to correct position
7. remove top frame (with keys)
8. check for any physical debris and remove if any
9. lift rubberised pad and whipe bottom of it with methylated spirit, allow to dry
10. check if plastic film can be separated, if so, whipe each layer with methylated spirit, do not under any circumstances break any of printed conduit lines.
11. when all is dry, put all back together in reverse order. watch for little springs present in some models.
12. go to shop and buy new keyboard... they are about $5.00 to $250.00 in that broad range you can find something suitable and affordable...
this is general description of the keyboard "gizzards", they vary slightly between the brands but principle is this same. if you have keyboard made before 1994, it will be electro-mechanical switches and that will cause more trouble...
Jul 29, 2010 | Computers & Internet
Little tykes hummer how to remove gearbox
You have to take off the push nuts, but you will have to replace them.
The little tikes gearbox assembly can be purchased at this site http://www.shopjandl.com/
but if you just need the push nuts like I did you get them here http://www.shopjandl.com/0801-0226.html.
I had the same problem, so all I had to do has tighten up those screws and replace the push nuts.
Hope this helps
May 07, 2009 | National Little Tikes Hummer Yellow
Little tykes power wheels - only one wheel spins
Does it do it only in one speed, or both high/low and reverse?
Try to put weight on the one side that is spinning and see if power transfers to the other side.
The little tikes hummer batteries tend to go weak if they are not charged up on a regular basis.
If there is a grinding noise in the gearbox you can find them at this website http://www.shopjandl.com/884931300.html but I would check the connections under the seat before I purchased the gearbox.
Hope this helps
Apr 23, 2009 | Toys
Hummer tire not rollin
The Little Tikes Gearbox might be bad.
The motor came loose from the gearbox on my kids hummer, so the gears were not turning right.
You can also contact this website. http://www.shopjandl.com/kids---baby-ride-on-toys-little-tikes.html
I got my parts from them and they helped me figure out what was wrong.
Apr 22, 2009 | National Little Tikes Hummer Yellow
Where do you plug the charger on little tykes H2?
The charger will plug directly into the battery, but it must be a specific little tikes battery charger because the connectors are slightly different than other battery connections.
The battery is usually located under the hood in front. I try to charge my batteries up at least 18 hours.
Hope this helps.
Apr 20, 2009 | National Little Tikes Hummer Yellow
Little tykes 12v hummer needs new accelator switch
i would take it to a radio shack to match it to another
Mar 28, 2009 | Toys
National Little Tikes Hummer Yellow Logo
195 people viewed this question
Top National Toys Experts
Joseph Hoffmann
Adam Fjeld
Adam Fjeld
Vernon Taylor
Are you a National Toy Expert? Answer questions, earn points and help others
