Question about Sony Playstation 3 (PS3) Console
PS3 conection cables
I have been using my PS3 w/ HDMI cable and works great. I need to move it to a different room and the TV does not have an HDMI connection so I tried the other cable (just thr standard yellow red white RCA's), just like the one for the PS2 and I get nothing? MUst the TV have an HDMI or Compnonet connections to operate?
  • 1 more comment
  • Anonymous Mar 24, 2008
    Interesting, I have EXACTLY the same problem. I moved the PS3 to a TV with no HDMI and got NO SIGNAL out of the video/audio cable.
    Took it back to my HD tv and used the same video/audio cable and NOTHING. Then plugged the HDMI cable in and viola! Everything worked.
    Is there a setup that we are missing to get the Video/audio cable to work?
  • SweetSykotic Aug 11, 2008
    I am in the same situation as these other users above. Whoever this was responding to the problem I feel wasn't very knowledgeable in this matter at all being that the "answer" that was posted was most definately not helpful to say the least. I believe someone who is experienced and genuinely informative about this subject should at least view this question not someone with a useless, quick fix response. I would rate this response but there isn't an option for extremely dissatisfied.
  • mike335 May 16, 2009
    Same issue, only HDMI works no matter what TV I put it on RCA, Video/Audio and RCA, Hi Def does not work only HDMI, I have gone to the settings of the PS3 and switched it using HDMI put it on the other TV and it does not work. It is like Once the HDMI output gets a signal it will always look for that and not switch back. Maybe a full reboot with it hooked up to the RCA Blind? anybody know how?
  • 99 Answers
Suggest using HDMI or Component Video if you can. They provide the best picture quality. Should be able to use RCAs if need to.
Try switching the TV Mode. TV may have multiple modes if you have multiple connections.
Posted on Mar 24, 2008
6ya staff
SOURCE:
How to fix issues whith component outputs on haier hlh26atbb 26 in. lcd ?
When you make the connection with HDMI are you changing the source or input key on the television to activate HDMI port? If you don't activate the corresponding source you connect to and leave the TV in the TV mode, you won't actually see the device you are connecting. It's possible the TV does not support the 1080P from your PS3.
Apr 17, 2015 | Haier HLH26ATBB 26 in. LCD Television
No PS3 signal on TV using HMDI or Component Parts
It could be that either HDMI port could be bad or you might want to try a different hdmi cable. The cable could be bad.
Jun 24, 2012 | Sony Playstation 3 (PS3) Console
Cant get output ps3 on hdmi cable
  • Make sure the system is off.
  • Hold down the Power Button for 5-6 seconds - until you hear the second beep.
    This resets the video settings to defaults (standard video output).
    Power up the PS3 again and it should auto-detect the hdmi at this point.
    If that does not work use the original audio/video cable that came with the system, power it on, then adjust the video settings and try the hdmi cable again.
  • May 18, 2012 | Video Game Consoles & Games
    Connecting Ps3 with philips tv (full hd) when i got hd cable in, and click to switch so the ps3 uses hd to show things and i than switch over to the channel i plugin the hdmi cabel it gives blac kscreen
    If it's the first time using your PS3, use the composite cables that came with it. Turn on the PS3 go to video settings and switch the input to HDMI. After you've switched to HDMI, turn the PS3 off and connect your HDMI cable, go back to video settings and change the resolution to 1080p. If this isn't the first time you've used HDMI for your PS3, make sure your T.V. is on the correct input. If the T.V. is on the correct input, try switching the HDMI cable to a different input. If that doesn't work try using a different HDMI cable, testing different HDMI connections if you're still getting the black screen. If none of those work then it's probably a problem with the PS3, but just to make sure try plugging something else with HDMI to see if that works. If another HDMI device works, then it's your PS3, if it doesn't then it could be a problem with your HDMI connections on the T.V.
    May 04, 2011 | Philips 52 In. LCD HDTV
    Sony Playstation 3 + HDMI + Samsung Series 5 47"LCD Problems (tried all solutions i found) OK at my wits end now. Heres the testing I have done. Have the ps3 connected to the set using the av...
    make sure ur not using both the av cable and the hdmi on some models it causes conflict although they are on different inputs. also did you try using a blu ray player or another ps3 on that hdmi port using the same cables or different cables? if another equipment work/don't work u can at least start to narrow down your problem..
    Apr 27, 2010 | Sony Playstation 3 (PS3) Console
    I have the same problem with my Samsung LE46A656 A1F Full HD
    If it was doing it on your old console then its the TV not the PS3.
    Causes: HDMI cable (Replace cable), HDMI socket on TV (Get it repaired), If it happens on all HDMI inputs then the video board maybe faulty, Interference - location of PS3 to other equipment.
    The first thing to do is move everything else away from your TV except for the PS3, now factory reset the Samsung TV and make sure your firmware is up to date my records show that an update came out in May for your TV, also factory reset the PS3 and setup the HDMI video settings using the wizrad in the PS3, now connect the PS3 through all HDMI inputs to see if its one input or all, if all inputs are the same then the TV maybe faulty.
    Let me know how you get on.
    Thanks
    Sep 05, 2009 | Sony Playstation 3 (PS3) Console
    I have just bought a Sony DAV-dz260 home theatre system. I connected it viz HDMI to my 1080p tv and it works fine. I also have a Sony PS3 connected via HDMI to my TV and this works fine too. I have...
    i have the same dav dz260 and all my stuff works on mine. this is how i set it up i have conected y dz to the tv via scart and my sky and ps3 via hdmi cable. to get sound from sky and ps3 i conected a optical cable from the dz260 to the tv and when i want sound for sky or ps3 all i did was change the function on the dz260 to tv and the tv setting to the hdmi im using and hey presto sound hope it helps
    Nov 11, 2008 | Televison & Video
    My ps3 only works with hdmi cables?
    Did you try holding down the Power button until you heard 3 beeps? It is not uncommon for the video output to exceed the resolution of different television. This hard reset feature was added to troubleshoot such a problem, factory resetting the video settings.
    Apr 02, 2017 | Sony Playstation 3 (PS3) Console
    Hdmi connection doesnt work on ps3
    By you saying that you have a new cable & tv, I assume you had the console conected tru composite before (red, white & yellow rca cable). This is what you need to do: Connect the PS3 to the tv with HDMI cable only, do not use the composite cable at the same time, reset your PS3 by pressing and holding the power button, when the power is off, for about 7 to 10 secconds, it would cicle from power off, on, then off again, it would also give you 2 sets of beeps, after the power is off, turn your tv on, make sure you select HDMI input on it, then turn your PS3 on, the console would set itself to the best resolution available on your tv. Give it a try!
    May 22, 2008 | Sony Playstation 3 (PS3) Console
    Sony Playstation 3 (PS3) Console Logo
    91 people viewed this question
    Top Sony Video Game Consoles & Games Experts
    Ekse
    shevantha perera
    Damen Wong
    Damen Wong
    Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
