Question about Kenmore Dehumidifiers
Kenmore elite 70 pint dehumidifier not pumping
Hello, my kenmore elite 70 pint dehumidifier does not seem to be pumping the water out as it should. Sometimes it works as it should. Other times I get the E3 error code, indicating that the pump is not working.
  • 3 Answers
SOURCE: kenmore model 580.54701 70 Pint dehumidifier
Evaporator fan is not turning on - a problem with almost all dehumidifiers... probably on this unit (being so new) it's the control circuitry (in the circuit board) which switches the fan on...
I have the same unit with the same problem)
Posted on Dec 04, 2007
SOURCE: kENMORE 70 PINT DEHUMIDIFIER
4681A20040R is the fan part #. Bought one on e-bay. Fixed the same problem.
Posted on Sep 06, 2008
SOURCE: Kenmore model # 25800-25801 Error code E3 ?
You can try cleaning the humidity sensor, which is on a circuit board
housed in a nylon clip attached to the cooling coils.
The sensor is in a plastic clip, which can be opened up and cleaned.
Some report success. Didn't work for me.
I ended up rewiring the unit so that a 5v control
line from the lower relay board goes through the SPDT bucket full switch,
turning on the control board when full (so it beeps), but otherwise
enabling the compressor and fan. The fan and compressor
are controlled by relays, which are driven by a ULN2003AN
relay driver. I fed the empty side of the full bucket switch back into
the relay driver to turn on the compress and the fan on high.
I plan to put a dehumidistat in series with this control line;
now it just runs till the bucket is full. A Broan DH100W dehumidistat
is 20 bucks. Could also put in a rotary switch to control the fan speed,
but for me high is enough.
I think this machine is made by Goldstar for Kenmore and Delonghi.
Stuff is just made to break and through away these days, which is a shame.
Posted on Oct 13, 2008
SOURCE: I need a manual for the Kenmore #54701
Here is a link for the manual. You can download it and save it or print it.
http://www.managemyhome.com/mmh/lis_pdf/OWNM/L0406271.pdf
Hope this helps, it's from www.managemyhome.com
Maryanne
Posted on Jun 17, 2009
Dittoz
  • 3 Answers
SOURCE: my kenmore 50 pint dehumidifier 54501 runs but it
You need to determine what's "running". Here's why: There are three things that must be working to extract water. The 'coil' (a finned metal part that needs air to flow across its surface) may be filled with dust and obstructions, so no air can move...then no water. There is a blower motor that must move the air. If it is seized up and not blowing air...very little or no water. The compressor creates condensation from air moving across the coil (like the moisture than forms on an ice filled glass on a humid day) to extract the water from the air. If it's not working then no water.
So, if there is air blowing out of the dehumidifier the blower is working. If the air is room temp the compressor is not working. If it's real hot air, and the humidifier keeps cycling on and off quickly, the coil is dirty. Those are the 3 things that need to be working.
Posted on Jul 31, 2009
Dehumidifier leaks
One open, other closed.
Also, make sure the unit is higher than the drain and that the hose is not kinked or clogged.
Please rate 4 stars if this is helpful. Thanks and good luck!
Jan 16, 2014 | Kenmore Dehumidifiers
Kenmore 407 50 pint dehumidifier won't drain through hose
Did you punch out (or cut) the plug that the hose connects to? If not, its blocking the water from draining to the hose.
Oct 13, 2012 | Kenmore 90701 70 Pint Dehumidifier With...
I have a whirlpool dehumidifier 70 pint and the fan runs but no longer collection of water...we have had it about 4 years.
There are many reasons why a dehumidifier will not work or collect water.
Here is a tip that I wrote to help people to figure out what is going wrong with their dehumidifier
Dehumidifier is running but no water is in bucket
heatman101
Oct 04, 2010 | Whirlpool Gold AD70USS 70 Pint Per Day...
Kenmore Elite 70 pint unit. Compressor appears to be frozen. Fan runs and compressor attempts to engage but immediately shuts down. Any suggestions. Unit is only about 2 years old.
Hi, I think you got it figured out...
There can be many reasons why a dehumidifier willnot work or collect water.
Here is a tip that I wrote to help people to figure out what is going wrongwith their dehumidifier
http://www.fixya.com/support/r4662409-dehumidifier_running_but_no_water_in
heatman101
Sep 15, 2010 | Kenmore 54501 Dehumidifier
My kenmore 70 pint dehumidifier turns on but will run for two to three minutes and then it turns itself off. Is there a sensor that would have stopped working? My email is mkemusic@sunlink.net
heatman101
Aug 24, 2010 | Kenmore 54501 Dehumidifier
I have 2 kenmore 70 pint dehumidifiers. Neither one is collecting water in the pan when running (therefore neither is running). Is there a reset button?
There are many reasons for a dehumidifier2_bing.gif to not work or collect water.
Here is a tip that I wrote to help people to figure out what is going wrong with their dehumidifier2_bing.gif.
heatman101
Feb 17, 2010 | Kenmore 54701 Dehumidifier
Kenmore 580.53701300 dehumidifier freezing cooling fins
Yes, it is a sealed system and it seems as though you may have a leak....unfortunately it will be cheaper to buy new then to fix.
heatman101
Oct 12, 2009 | Kenmore 53701 Dehumidifier
I have a Kenmore 580.53701300 dehumidifier (70
Jim,
I have this dehumidifier and the owner's and parts manuals to go with it.
I will scan them and email them to you.
Hope this helps!
Jamie
Jul 31, 2009 | Kenmore 53701 Dehumidifier
Auto-defrost not working at all
Unless equipped with special equipment most dehumidifiers will produce little if any water under 65-70 degrees. Many state operation down to 50-60 degrees but this was under lab conditions and therefore a marketing tool. The best performance is gained when the air temperature is above 70 degrees. The water you are finding is from melting frost, if you have a humidity problem you should be adding heat to the area to be dried, warm air holds much more moisture than cold and drying is much more effective if you can heat the area to around 80 degrees.
Mar 05, 2017 | Kenmore Dehumidifiers
Dehumidifiers Logo
155 people viewed this question
Top Kenmore Dehumidifiers Experts
Bill Long
Mike Squire
Are you a Kenmore Dehumidifier Expert? Answer questions, earn points and help others
