Question about Hitachi NV45AB2S Coil Roofing Nailer
Air leaking aroung the trigger assembly from my Hitachi NR83A
I have replaced the trigger assembly from a working Hitachi Framing nail gun and it still leaks air. I have replaced all of the o-rings.
    Problem Solver:
  • 5 Answers
If you took the trigger apart the part that you unscrew has a nylon ball and a black rubber ring you should check them and make sure that you didn't loose them when you took it apart,if they are there, then you need to service the gun, and after you clean all the moving part and you put it back together, it may still leak from the top,Take a rubber hammer and give it a good hit,now not to hard, and it should seal
Posted on May 04, 2010
I have a Hitachi NR83A3 framing nail gun. It won't drive nails flush. Adjusting the depth screw from one extreme to the other doesn't appear to help or change the driven nail depth. Any ideas?
Easy to check. Remove nails from gun and connect to air supply. Using hard rubber pad or soft wood depress and hold trigger and push nailer safety against pad and hold there. The gun will fire but the driver will stay down until you pull back on the gun and relieve pressure on the safety foot. With driver down examine the tip of the driver. It should look square and should extend about 1/4 inch or more past the nose. If tip is broken replace driver. If lots of air is leaking past the nose during test, also replace the lower bumper. Good luck
Dec 23, 2014 | Hitachi Air Tools & Compressors
Hitachi framing gun leaks air from trigger when pulled
use the lube that came with the kit, you can replace everything correctly but if oring gets pinched it will still leak
Aug 14, 2012 | Hitachi NR90AE Full Round Head Framing...
I have a framing nail gun and air is leaking around the trigger. How do I get the trigger off to replace it or replace the rings?
in the tip section I have detailed instructions on how to remove the trigger valve assembly. You might be able to click on my icon to get to the page, let me know if you need more assistance.
Sep 06, 2011 | Stanley Bostitch Nail Gun
All the sudden the nail gun stop working, pull the trigger air leaks out at trigger area
I had a similar problem with one of my nail guns. What I found was a small rubber o-ring in the trigger mechanism had split. Once I replaced this the problem was corrected and the unit functioned fine.
You could replace the whole trigger assembly for about $35. But if you remove the assemble and replace the split-ring this would only cost a couple of bucks at most.
Trigger assembly shown below. ereplacementparts.com is one possible source for the trigger assembly others can be found on the Internet.
Aug 21, 2011 | Dewalt Heavy - Duty 31° Clipped Head...
I have the 2 1/2 Hitachi for nailing siding. The nail gun had not been used for a couple of years, but now will only drive the nail half way in. Sounds like an air leak when driving the nail. I have...
Remove the nails and air supply. With side door open notice position of driver. Driver should be at top position with tip not visible. If driver is down and it moves within cylinder when you tilt nose up then down again, time to replace orings. If driver is down, it should extend past the nose about 1/4 inch (if driver is broken at the tip the end will look rough and nail will not drive in all the way). If driver extends past the nose more than 1/4 inch then lower bumper may be breaking up /cracked. Easy test for proper function. With nails removed and side door open, connect air to gun and dry fire gun against hard rubber or old coiled air-hose (with air connected and trigger depressed, no air should leak from trigger area, if air leaks when trigger is depressed, look for fault at trigger pin). Feeder should move back then forward in quick motion almost matching speed of driver and driver should not creep down between shots. No air should leak from nose of the gun (push nose against hard rubber and depress trigger and hold in this position, driver should stay down with very little or no air leaking out of nose, when you release trigger, driver will return). If air leaks out of nose while holding in this position, replace lower bumper. If a quantity of air leaks from valve in front of trigger, cylinder orings may need replacing or outer part of cylinder has fine scratches (remove scratches with 400 grit paper). Parts are available at www.toolpartsdirect.com. Good lucki
Apr 16, 2011 | Nailers Hitachi Nv83a2 3 14" Coil Framing...
Air leak
My Guess is that it needs a new "O " ring or some other form of seal some where round the trigger actuating spindle. Should be quite easy to fit if you can get one the right size
Jun 05, 2010 | Hitachi NR83A2S Framing Nailer, Full Head,...
My dewalt framing nail gun was hooked to the air compressor, but was not being used when it began leaking air which you could hear and got louder. It sounded like it was leaking around the trigger area....
There are O-ring seals around the trigger that are probably leaking. You can try to lubricate the gun by adding the pneumatic oil to the air supply. That may be enough to seal it back up. Otherwise the seals and/or the trigger assembly will need to be replaced.
Dan
Mar 29, 2010 | Dewalt Round Head Framing Nailer D51845
Hitachi NR 83A2S, Nail wont fire properly
The NR83a has an adjustment just below the triggering plunger. It is a 6mm hex head bolt with a locking nut. Loosen the nut and adjust screw out several turns and re-test. Make adjustment as necessary. I have seen many of these gun without the locking nut which allows the bolt the adjust itself all the way down. AS parts wear this screw needs to be adjusted. The pushing lever and the plunger are wearing smaller/shorter, that is unless the locking nut was missing. Remove gun from air supply for safety when making adjustments. Good Luck an email if you have other qustion about this gun.
Apr 27, 2009 | Hitachi NR83A2S Framing Nailer, Full Head,...
Hitachi NV45AB2S Coil Roofing Nailer Logo
448 people viewed this question
Top Hitachi Tools & Hardware - Others Experts
John Trevino
yoopertech
Joe Garcia
Joe Garcia
Are you a Hitachi Tool and Hardware - Other Expert? Answer questions, earn points and help others
