Question about Samsung HCM4215W 42" Rear Projection Television
My Samsung hdtv rear projection tv model#HCM4216W doesn't have any sound good picture though but does have some light waves in picture
  • hog_mater_07 May 03, 2010
    ok i got a surround sound i was fixing to hook up to the tv, and now the tv won't even power on.
    When i do turn on the tv the red light in the front by the power button blinks about 9 times, and nothing.
  • 438 Answers
The lack of sound is likely due to a defective audio output amplifier integrated circuit or IC for short, it needs replacing, the wavy lines through you picture is due to a defective filter capacitor in your power supply circuit, or may be due to the audio amplifier I.C drawing more current from your power supply causing a non clean power to be supplied to the video circuits, have the audio amp replaced first and note if the wavy lines are still present if so it is likely that some filter capacitors need replacing, to obtain sound you might be able to connect a external amplifier like your home stereo using the aux input and the sound output from your TV`s RCA jacks, this works well, let me know if you need further assistance good luck
Posted on Apr 27, 2010
  • Fal Mueller
    Fal Mueller May 03, 2010
    projection TV`s have integrated protection circuits
    built into the circuit design, these circuits turn the
    power off automatically when a fault has bin detected this
    is in order to prevent a more costly repair, these circuits monitor
    power supply , vertical and horizontal deflection
    over voltage, or x ray, and also faults with convergence circuits.
    Diagnosing these faults require test equipment and a good knowledge of
    electronic repair techniques, and also a repair manual.
    This is the speel i provide for any person asking about things they know not match about,,,, have you explored the inside of your television ?, are you able to identify the audio amplifier output IC ? if so, unsolder and remove it, power the TV on and test to verify your unit is powering up again, It is possible your amp IC has given up and shorted or overloaded the power supply causing the protection curcit to activate shutting your system down and protecting your unit from any further damage it is also posible that there is a fault in the power supply delivering power to your amp IC...
    regarding trying to service the unit by yourself, are you prepaird to get your hands dirty ?
  • Fal Mueller
    if your TV is powering up again , connect your audio device to your TV and enjoy, if not ,,,Brake out the test equipment and contact me again...
Samsung hcm4216W turned off by itself loops.
Instead of typing model number of your TV (that located on right hand side and on the back of TV) you published here part number of your TV's remote control. LOL.
Anyway... If it is LCD/plasma panel that you talking about - than power supply have bad electrolytic capacitors that have to be replaced. You can recognize 'em by bulged/swollen tops (instead of flat tops of good capacitors).
This repair required soldering skills.
Mar 09, 2010 | Samsung HCM4216W 42" Rear Projection...
TV Powers on and then shuts down and attempts to start again
Remove all connections from the tv other than rf cable. This is an hdmi lockup problem sometimes related to component video inputs depending on firmware version.
Jun 21, 2009 | Samsung HCM4216W 42" Rear Projection...
Turns on, no picture or sound, light blinks 5X, reboots itself
First thing is to check the lamp. you can easily change this yourself.
May 26, 2009 | Samsung HCM4216W 42" Rear Projection...
Samsung hc-p4241w - No picture
samsung tv model hc-p4241w good picture no sound
May 22, 2009 | Samsung HC-P4241W 42" Rear Projection...
The screen has a wave across it you can see two of everything.
The convergence is out . There are big ICs in the tv that go bad or get bad solder connections, that control each CRT to focus the picture one on top of the other. DO NOT move or try to adjust lens. The fluid is a coolant like in your car to keep the tubes cool.
Nov 25, 2008 | Samsung HCM4216W 42" Rear Projection...
Studioseries (samsung) 42" rear projection tv red duoble outline of picture
sounds like the red convergence Ic is weak ready to go out. try replacing the ICs around 10.00 do the blue as well as that will be next.
Mar 18, 2008 | Samsung HCM4216W 42" Rear Projection...
TV won't turn on.
Samsung Projection TV Model # is PCK5315R. It displays a light on the "timer" indicator on front of the TV but the TV doesn't respond, no picture or sound.
Mar 02, 2008 | RCA HD52W56 52" Rear Projection HDTV
Samsung hcm4216w
The most common problem for those symptoms are convergence amps. That unit takes two stk392-040 Sanyo Ics and will most likely require that several low ohm resistors (3.9 ohm-2w) be tested and possibly replaced.. There is one last thing also, a pico fuse at Fd102 (3.5a) that sometimes opens and would need to be replaced..
The convergence board in these is easily removed, so an in-house service call could be done...
Hope this helps
Jan 09, 2008 | Samsung HCM4216W 42" Rear Projection...
Samsung sp47Q5 rear projection
when you turn on the tv you should get that static feeling when you toch the srcreen. if not then there is no high voltage
Dec 27, 2007 | Samsung HCM4216W 42" Rear Projection...
TV turns on with no picture or sound
atechnichian advised me that when that happens it means that one of the projection tubes overheated from leaving the tv on too long and leaked on to a pc board he said the tv is not worth fixing
Sep 30, 2006 | Samsung HCM4216W 42" Rear Projection...
Samsung HCM4215W 42" Rear Projection Television Logo
188 people viewed this question
Henry  Thomas
Henry Thomas
Jerry Greenberg
Jerry Greenberg
