Question about Thetford Norcold RV Cooler/Freezer
I have a freezer that does not work it clicks on for a few sec then cuts off what could be wrong
  • 477 Answers
The clicking is the electronic ignitor trying to light the gas.
Either it's not getting any gas to light , or the flame sensor is not telling the computer that there is flame , so it shuts down the gas.
Most fridges have a small shut off right at the gas valve in the back of the fridge , it might be turned off. Put your ear up to the back cover of the fridge , if you hear it sparking and then you hear flame but it goes out after a few seconds , than it is the flame sensor. If you never hear the flame blowing , than it is not getting gas. Could be several different reasons. If you have disconected your tanks , maybe the gas has just not made it to the fridge yet. Newer ignitors try 3 times and then shut down if no flame is detected. Old ones only try once.
Posted on May 27, 2010
My freezer start only a few sec. After 10minutes start again
Roy,
Sounds like something is causing your compressor to kick the overload. It could be the overload itself or it could be the start relay or it could be a locked compressor. Probably best to call a service tech.
Apr 29, 2015 | Freezers
Compressor starts, then stops
Hi, this problem will be with either the starter for the compressor or could actually be the compresser itself. Both of these can be replaced but it is not something any one should do unless they have done this before and know what they are doing.
Apr 25, 2008 | Whirlpool 25.6 cu. ft. Side-by-Side...
Why does my panasic the gemius sensor 1300 if i set it for 29 sec. it cut off at 7 sec why
The microwave is defective. If you owned it less than 90 days, take it back to the store but get a different brand of microwave. A few people purchased the same one that you bought and in lasted less than 1 year. The problem. It does not work at all.
Jun 04, 2014 | Panasonic NN-SN657SMicrowave Oven
Compressor kicks/clicks out after approx 10 sec run time,fan runs normal,not froze up, freezer barely cools,negative frig, happened overnight to 6 yr old unit
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing thencheck out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Aug 13, 2011 | Refrigerators
L.comTrue model GDM-23 starts and stops(very short cycles10 sec. or so
. Cut everything off for a few minutes then turn it back on and listen for a click from the compressor relay as the compressor tries to start.
Is the compressor motor running.If no check starter/overload relay. The relay is a small usually black cube shaped electrical part plugged into the compressor or wired to it nearby. It may appear burnt or rattle when shaken if it's bad. The two connections should show continuity with an amp meter. If it's good then it's most likely the compressor causing the problem.
May 15, 2011 | True 23 cu. ft. Commercial Freezer...
Display says OF OF in the degree part and can't get rid of it and now it is defrosting. Freezer thawed.
Press and hold the POWER SAVER and FREEZE buttons at the same time for 3 sec. The display will cut off and a few moments later the frig will turn on the cooling system. Good Luck!!!!
Builders Construction of CA
Feb 25, 2010 | Samsung Refrigerators
Power mate cuts off after a few secs.
You have a short somewhere. They can be tricky to find. You might need to take it to a repairman.
Dec 14, 2009 | Vacuums
Compressor keeps clicking on then within 2 secs cuts off then on
sounds like you need to replace the relay/overload on the compressor.
Oct 13, 2009 | Frigidaire Freezers
Fisher & Paykel active smart E521T
I would reset the module. Open the fridge door, keep the freezer door closed, then press the mode button (located on the display panel. This will re initiate the electronics
Jun 07, 2008 | Fisher and Paykel Active Smart® E522BR...
Freezer problem
Not sure of what cut out refers to. If you mean the power supply is tripped out after twenty secs hen I would say there is a fair chance of the compressor being down to earth (ie broken). If you mean that the compressor tries to run and then stops after twenty secs then there is a fair chance the compressor is stalled (ie broken). There is also a chance that the relay (starting device) may be at fault failing to start the compressor. If it is the relay then the cost may be around £70 if its the compressor then you are lookin at a couple of hundred pounds approx. The buzzing sound does sound like the compressor trying to run but stalled and unfortunately compressors have no real average anymore and are prone to fail whenever they choose to. Sorry to sound negative and hope this helps.
Sep 03, 2007 | Freezers
Thetford Norcold RV Cooler/Freezer Logo
157 people viewed this question
Top Thetford Refrigerators Experts
John Tripp
John Tripp
4stevetaylor
Level 1 Expert
john h
Are you a Thetford Refrigerator Expert? Answer questions, earn points and help others
