Question about HP Deskjet F4140 All-In-One InkJet Printer
Only need to print selected pages in word document but printer wants to print entire document
  • 4,041 Answers
Hi there
Just copy and past to another word pade what you want then print out
Posted on Apr 27, 2010
Trying to print a 15 page word document but the printer keeps printing only one page repeatedly even though i have clicked print all as well as pages 1-15
I've had similar issues and here's what I found was the quickest and easiest solution. Select, cut and paste the entire document into a new document with a different a name. Sometimes the document format gets corrupted while typing.
Aug 06, 2014 | Canon Pixma MG5220 InkJet Printer
Not printing document in its entirety; only certain paragraphs
Have you tried to install the printers drivers again???? Also, sometimes who ever wrote the piece, may not want the info printed and has blocked it???? Good Luck
Feb 05, 2013 | Kodak ESP C315 Wireless All-in-One Printer
It prints only half a page.... how can i fix that???
Does the print fade out or is the printed page complete, just cropped down? If it is fading out then it is the cartridges running dry, or refilled using the incorrect ink. If it is printing the entire document, just smaller, then under printer properties you can set the page size. (control panel - printers and faxes - right click your printer and select printing preferences) I hope this helps Regards GM
Apr 13, 2011 | HP Photosmart C6180 All-In-One InkJet...
MX310 - faxes in memory. Cartridges have been replaced. Error of low ink remains. What is the key sequence to retrieve these faxes?
Press Fax then Menu. You should see Fax Settings across the top row. Use the left/right arrows to select Memory Reference and press OK. Again use the left/right arrows to select Print Document and press OK. Select the transaction (RX) number of the fax you want to print (received faxes start at 5001) and press OK. Then choose whether you want the first page or the entire fax (yes to first page only or no for the entire fax) and press OK. To print additional faxes repeat from the Select RX number. Print the Memory List to find out which fax is which (from the list that you see under Print Document.
Then you can delete these by selecting Delete Document instead of Print Document in the above directions. Then press OK followed by Yes or No for deleting the document.
Finally press Stop/Reset to leave the menu.
I hope this helps.
Sep 24, 2010 | Canon PIXMA MX310 All-In-One Printer
How do I change print sixe on Deskjet 722c?
usually you can change the print size in the print preview page setup menu.
in this menu you can scale your document down changing the print size.
otherwise, you can take your file in word or any document editing software and select all and change the font size for your entire document. These are two options for you which will change the print size on your printer.
Mar 26, 2010 | HP Office Equipment & Supplies
I have a Cannon i560 printer. The printer will
Check to make sure you're not adjusting it to fit the page. This can shrink the entire doc..
Look in the print dialog window when you select print from the file menu.
There should be options to select or deselect before clicking to print.
You may also check your page setup to make sure you are printing at 100%.
Let me know if you solve this one...
Oct 30, 2009 | Office Equipment & Supplies
I attempted to print a 25 page document, with reverse pages. Only 9 pages printed. I cannot print anything now. and the message on the printer reads, DATA REMAINING. I have pushed every button...
It seems the printer buffer memory has overflowed. Cancel the print from the print Que and switch off the printer. Give your PC a reboot too. Now switch on the printer and make sure that there is no document in the print Que. If its still there, disconnect the printer and delete the pending job, i.e. print Que. After the printer shows it ready for printing do not release the entire document for printing at one go. Breakup the print job in 3 parts and for each part manually enter the page numbers and then give the print command. Repeat this till the entire lot is over..........................sodeep
Apr 14, 2009 | Brother Office Equipment & Supplies
My Kodak ESP 5 Won't print entire documents, only first page
Scott,  If you are using Mac and Adobe 8 or 9, see solution from Kodak site at:
http://www.kodak.com/eknec/PageQuerier.jhtml?pq-path=12998/7269&pq-locale=en_US
Feb 03, 2009 | Kodak ESP 5 Printer
Can't print entire pdf documents only first page.
Try this
For Adobe Acrobat Professional 9:
  1. Choose File > Print.
  2. Click on Advanced.
  3. Choose Postcript Options.
  4. Under Font and Resource Policy, select "Send for Each Page".
  5. If "Print as Graphic" is checked, it must be unchecked, as well as "Send As Group" if it does not uncheck itself when you select "Send for Each Page"
  6. Save it as a custom configuration.
Jan 16, 2009 | Office Equipment & Supplies
Printer Problem
I would try to Highlight the entire page, then right click,
Select Print, and then select "entire selected section" and then Apply and print.
This should work.
Good luck.
Dec 18, 2007 | Canon BJC 2100 InkJet Printer
HP Deskjet F4140 All-In-One InkJet Printer Logo
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
