Question about Whirlpool GS5SHAXN Side by Side Refrigerator
Model # ETOWSRXMQ00 has not been used for at least a year. light is working and I hear a humming sound, but unit is not cooling.
  • Whirlpool Master
  • 43,501 Answers
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing then check out thelast two tips.
If your refrigerator is running but warm, then...
Check out this tip that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
sdfartyuk
Posted on Sep 29, 2010
LG window air unit. Been having trouble with control panel for months, but unit cooled. Now it will light up and fan will blow, but compressor does not kick in. Unit about 4 years old.
Possibly a faulty run capacitor in the control box. This is fairly common to LG. the fan motor and compressor use them to start and run more efficiently and when they fail the fan or compressor either don't start at all or run poorly. You can usually tell if you can hear the compressor 'hum' briefly then stop every 10 - 30 secs. this is the compressor trying to start but unable due to the faulty part. LG often have a dual capacitor (two capacitors in one case) so the fan may stop working also or at least run slower. They are common parts available at most electrical wholesalers although the genuine LG parts are normally dirt cheap. Need a model to check the circuit diagram to be more certain.
Aug 24, 2017 | LG Heating & Cooling
Rudd model ukab-030jaz
You most likely have a small 3 or 5 amp fuse on the circuit board on the indoor unit that has blown. You should turn the power off at the main breaker panel and open the cover and very carefully look for a small blown fuse. It will look like one that you use in your car. Then if it is blown, replace it with the exact same size and rating.
Aug 17, 2017 | Heating & Cooling
PTC073E35AXXX humming
sounds like a control transformer . No danger.
Nov 20, 2012 | Amana PTH123B25AJ Heat Pump Air...
Frigidaire refrigerator/freezer side by side not kicking on. Both freezer and refrigerator not cooling.
If the unit is not cooling in either section of the appliance, you are experiencing some form of sealed system issue. This can include the compressor not working correctly, the evaporator fan not turning, or even coolant in the lines not at the correct levels to properly cool. If the compressor is running, humming, or even a little warm then that is typically normal. However if the compressor is running hot, then it is over working and the issue could be before the compressor in the evap fan, coil or coolant lines. Unless the unit is displaying an error code, often alpha-numeric, then you would need to contact your manufacturer and then a professional to move forward accurately.
Sep 03, 2012 | Frigidaire Refrigerators
I bought a used True commercial refrigerator model GDM-41 the temp. remains at 60* no matter if i move the thermostat up or down it remains at 60* I noticed that the thermostat was replaced and has a...
Hello Margarito539,
I understand that you purchased a True GDM-41 merchandise refrigerator and you are having a problem with the temperature. The thermostat you are currently using is an in-line thermostat and is not the proper thermostat for the unit I would suggest that you follow the below link and purchase the proper thermostat for the unit. http://restaurant-equipment-parts.com/part/true/800393 the cost is $36.98 and is an OEM part.
You also may need a service tech to check out the freon in the unit. The unit uses 134A freon and must be within a few ounces of charge other wise it will not work properly. As the unit is keeping it 60 degrees, before you do anything make sure that you can hear the compressor running as this is not a cheap fix, however may be worth the cost for the unit you have. The compressor should be humming if it is not and the unit has been plugged in for a while, unplug for about thirty minutes and let the compressor cool. Once thirty minutes has passed plug in and see if the compressor is humming.
After checking the compressor you have two choices if it is humming call a service tech and have them check the freon charge and thermostat or change the thermostat and see if the compressor starts cooling the unit. If the compressor is working then the box is well worth fixing, if the compressor is not working you need to decide if it is worth fixing. A used unit with a one year parts and labor warranty costs $2100 so the repair should not cost over $1000 to be economical.
Thank you for choosing FixYa.com
Justin
Apr 20, 2011 | True GDM-41 Refrigerator
Our wall unit just quit working. we moved in four years ago so i'm not sure how old the unit is and don't have a manual. from my research, the product matches the Carrier XQB153D. We have never serviced...
Would you be using this Air Conditioner, as Heat Pump--
and so, when you say it just stopped---
Is that meaning that it stopped supplying HEAT?
Or are you using for cooling purposes?
Thanks for telling us that yo have NOT serviced it in 4 years!
You could pull the front cover off, and clean the filters--
Possibly a mouse or a bird or ?-- has built a nest in a wrong spot, and caused problems.
Give us some clues as to alarm lights, or sounds it used to make when you turned it on, versus what you hear now when you turn it on?-- any humming?-- clicking, etc.?
Tell us more, and we'll try to help to the next step.
Mack B
Jan 25, 2011 | Carrier XQB153D Air Conditioner
Whirlpool Gold GB2SHDXPS fridge/freezer has stopped working. It is not cold and food is thawing. The light in the fridge and the freezer is still on but it is not cooling.
can you hear a humming sound coming from the back of the refrigerator, if so that means your compressor is running, if you are hearing a buzz or clicking sound your compressor is trying to start, you may need a compressor. Some whirlpools have a 5 year sealed system warranty that would cover the repair.
Aug 22, 2010 | Whirlpool Gold GB2SHDXPS Stainless Steel
Timer going but no heat less than a year old
To allow us to help you effectively (at no charge), please post a NEW problem to FixYa, and please include your brand name and the full model number from the tag in or on the unit, your exact symptoms, as well as the answers to these questions:
- When you try to microwave are the inside light, internal cooling fan and turntable all working?
- Is there any unusual noise or is it louder or quieter than normal?
(A loud buzz, hum, or groan is usually a shorted high voltage rectifier diode, but a sound like gurgling into an empty coffee mug is one symptom of a failed magnetron, and yet the mag can be bad without that sound.)
We have a sound clip here of what a microwave should sound like when the cooling fan and high voltage section are working.
Nov 23, 2009 | GE JES1358 Microwave Oven
Door opener looses power
Motor has a thermal sensor if it gets too hot it trips the sensor till it cools down. Motor may be going bad, or door may have gottin to heavy ( spring loose tension over time) disconnect door from operator. You should be able to raise it easily manually.
Oct 03, 2009 | Sears Craftsman LiftMaster Chamberlain...
Whirlpool GS5SHAXN Side by Side Refrigerator Logo
99 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
