Question about Electrolux Guardian Bagged Canister Vacuum
Lux legacy canister vacuum - the top light on the canister went on. No power to the bottom of the roller. What does that light mean. Looks like a plug
  • 694 Answers
The "plug" light simply tells you the machine is plugged in and receiving power.
I'm not sure what you mean by "no power to the bottom of the roller". If the power nozzle motor isn't working, make sure nothing is wrapped around the brush, remove if there is, and press the reset switch.
If the power nozzle motor is running, but the brush isn't turning, then the belt must have broken, and needs to be replaced.
Considering your machine may still be under warranty, I suggest taking it to a local Aerus dealer and having it replaced.
You can find the store nearest you using the below site:
http://www.aerushome.com/shop/
Posted on Sep 05, 2010
What does the key light stand for on lux7000 canister vaccuum?
The light on the top of the 7000 that represents a "key" as you state it, is actually a "No Bag" light. That means to check the bag compartment for a bag. Replace if you do not see one. Close the door, push the start button, and voila....it will start. If it doesn't , make sure the bag top (cardboard) is flush inside. It may be missing the bag switch. Hope that helps!
Oct 11, 2014 | Electrolux Lux 7000 Bagged Canister Vacuum
What is the difference between the electrolux lux 7000 and the electrolux lux legacy
different motor,the legacy does not have a filter,but the same bag...one is made of a light metal [legacy] the other a polycarbonate plastic. Chris
Jun 24, 2014 | Electrolux Lux 7000 Bagged Canister Vacuum
Lux 7000 vacuum cleaner power cord light is on and it wont start
Best case scenerio....check and replace the bag...try it. If no bag, it won't start. If that's not it, could be the on/off button or rocker needs replaced and worse case scenerio, the motor is OUT!... I can help! amerivac4u@yahoo.com
Jun 06, 2014 | Electrolux Lux 7000 Bagged Canister Vacuum
Lux 5000 put in new bag but when i turn on the
It sounds like the valve assembly (full bag control) is faulty. Threr are two O rings inside of it and the plactic holding the bottom one has broken. You'll have to take it to the shop.
Oct 25, 2009 | Electrolux Lux 5500 Canister Vacuum
Vacuum cleaner Lux model motor fails to start
This vacuum has a 10 year warranty on the motor, and 5 years on everything else. Look in the yellow pages under vacuums, for the AERUS dealer, that is the new name for the traditional Electrolux company.....
Mar 23, 2009 | Electrolux Lux 7000 Bagged Canister Vacuum
Power Head doesn't work
Are you talking about the large power head (ised for floors) or the smaller power head (for upholstery)?
If you are talking about the large one the first thing I would check is the belt (accessed by turning the tiny lock knob on the bottom with a flathead screwdriver).
If the belt looks ok the next thing I would check is make sure an accumulation of hair hasn't built up on the ends of the roller....take the roller out and turn the roller by hand holding onto one of the ends...it shoudl move freely....
Jan 13, 2009 | Rainbow E series Canister Wet/Dry Vacuum
Lux legacy
Actually the problem is inside of the canister itself. You need to change a part called the control valve. Occaisonally when fine particles get inside of the valve it damages the inside of the valve, sending a false reading to the main motor, causing it to shut off. This is a relatively quick and easy repair and should be recieved on a same day basis.
Oct 20, 2008 | Electrolux Lux 7000 Bagged Canister Vacuum
Power light
i would call electrolux and ask them its free the number should be located on the vacuum some were.
hope this helps:)
Jul 27, 2008 | Electrolux Lux 7000 Bagged Canister Vacuum
Lux 7000 Power Nozzle bulb replacement
There should be some screws that you remove from the bottom. Then pry up from the back and the top should come off.
May 11, 2008 | Electrolux Lux 7000 Bagged Canister Vacuum
Lux Legacy - Cannister Model
If it is what I am thinking, that warning light is just telling you that the cord is plugged in. Alot of the Electrolux models had this warning light.
Jan 05, 2008 | Electrolux Lux 5500 Canister Vacuum
Electrolux Guardian Bagged Canister Vacuum Logo
284 people viewed this question
Top Electrolux Vacuums Experts
Mack Baxter
Are you an Electrolux Vacuum Expert? Answer questions, earn points and help others
