Question about Oreck XL2200 Bagged Upright Vacuum
MY oreck will not move forward.
I changed the bag and belt. Checked for clogs and nothing., Don't know what to do.
  • stanlaskowsk May 11, 2010
    I have this same problem with my XL platinum upright. I took it apart recently to remove a clog in the air intake. When I reassembled the unit & tested it, it no longer has the auto forward roll function. Changed the belt to see if that was the problem, it wasnt. Both ends of brush roll are set to normal & are free of hair & dirt. I also tried setting the brush roll to special to see if that was it, it wasnt. Help.
SOURCE: Oreck Vacuum Cleaner problem (upright)
To jrican-80,
My new upright(NOT an Oreck) is over three years old and hasn't needed a new belt so far. Orecks clog very easily, and when you bring it in for repairs, or for the yearly "tuneup", what the store manager wants you to do is spend more money on the existing sweeper, new roller brush, for example. That's the reason for the yearly checkup, to BRING you back into the store so you can spend more to help Mr Oreck make more money.
Seems like you either have a connection to Oreck or simply think that an overpriced, cheaply built vacuum cleaner is actually a good machine.
Posted on Sep 16, 2008
#1 Taper
  • 1041 Answers
SOURCE: My Oreck XL was working fine, then when I vacuumed a shag rug is started smoking and smelled like something is burning. (I changed the bag, checked for clogs--none found, and roller brush is turning.
Even though the brush is spinning, the belt is probably worn out and stretched. when you vacuum the shag carpet, it puts more drag on the brush. try running it on a shorter carpet or hard floor for a few minutes. if it doesn't smoke, then you know it's your belt. if it does smoke, then it's probably the motor burning up.
Jim
Posted on Jun 03, 2009
  • 7 Answers
SOURCE: Dirty Oreck bag
yes but separately from other clothes
Posted on Aug 09, 2009
  • 36 Answers
SOURCE: Oreck vacuum blows air does not **** air. The bag
you have an obstruction in the intake pipe
Posted on Nov 20, 2009
  • 85 Answers
SOURCE: Oreck XL intellashield smells hot and smoky when
If it smells like burning rubber with white smoke its the belt make sure the brush spins freely. If its a electrical burning it will smell real bad you WILL be able to tell which then its a motor issue you can remove the bottom plate 5 phillips head screws opposite the motor youll see 1 screw remove it pry the duct out and look to see if there's anything stuck in the fan if not its the motor its self
Posted on Dec 17, 2009
Suction problem
Probably have a clog some where in the base and that is what causes it to throw stuff back out.
Apr 04, 2014 | Oreck XL Ultra Bagged Upright Vacuum
Oreck
Dear Sir>
Please see if the belt is o.k replace if necessary
2) bloked hose + clogged bag , this is very important
3) Motor need maintenance, lube, change the brush, or winding overheating, and need replace.
God bless you
May 26, 2012 | Vacuums
Oreck airhgq motor not working
Dear Sir:
1) See if some objets is inscruted in the belt.
2) Blocked hose, cleane
3) Clogged bag, clean.
4) Motor need lube, or change brush, test it for oveheating winding may be need replace.
5) Before to do that replace or retight a little the belt or replace.
God bless you
My Oreck is hopping on my carpet while vacuuming. It is fine when pushed away - it hops and leaves marks on my carpet when I pull it back. I have changed the bag and cleaned off the roller and checked...
My first thought is to change the belt.If it is stretched this is a common symptom.You can go to youtube and my chanell is sewvacmd.Their is a video on how to change it.Hope this helps. www.sewvac.com
Feb 10, 2011 | Oreck XL2200 Bagged Upright Vacuum
My Oreck XL was working fine, then when I vacuumed a shag rug is started smoking and smelled like something is burning. (I changed the bag, checked for clogs--none found, and roller brush is turning. It...
Jim
Jun 02, 2009 | Oreck XL2000 Bagged Upright Vacuum
Dirt smell
If this thing has a fast-spinning belt in the "head" of the unit, you are smelling the dust that is being collected in the back of the little drive "chamber" and is being heated up by the motor and the friction of the belt. This is a pretty common thing on vacuum cleaners designed like the Oreck. If it is huge bunnies of dust, well then that means there is a leak somewhere...
Mar 11, 2009 | Oreck XL Ultra Bagged Upright Vacuum
ORECK VACCUM
http://geeksquad.fixya.com/ThreadView.aspx?prdid=0&thid=747767
Generic problem for all Vacuums
ORECK VACCUM
Posted by FISHERMAN928 on Jul 06, 2008
Older Oreck XL, new belt, new bag, checked for clogs, does not pick up
as it used to, and, much harder to push, seems to grab or drag, why????
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. There are a couple of things that may work. Depending on if you have the old style brushroll you can upgrade to a new style Oreck brushroll that has twice the brushes and will a work a lot smoother. Also, clean the bottom plate – get rid of any dust and dirt build up and then spray the bottom with silicone and let it dry after you have totally cleaned it. Always use Oreck genuine belts and to change the belt every 4 to 6 months for the best cleaning and store the extra Oreck belts in a Ziploc bag in the refrigerator, other wise if you have a new belt, gag, you have checked for clogs there is no reason why it should be hard to push, if the silicone does not work replace the bottom plate.
http://www.oreck.com/ Customer Service 1-800-989-3535
Monday thru Friday Hours are: 7:00 am to 7:00 pm CST
Saturday and Sunday Hours Are; 8:00 am to 4:30 pm CST
Thanks, Don the Vac Man
Go Ahead. Use Us.
Jul 06, 2008 | Vacuums
Oreck XL Classic
http://geeksquad.fixya.com/ThreadView.aspx?prdid=19810&thid=703827
Oreck XL Classic
posted by balis on Jun 24, 2008
The belt is on properly, however the brush will spin, then stop.
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. Oreck XL Classic. It sounds like the belt may be stretched out and my needs replacing. The average belt change is every 4 to 6 months and to store the extra belts in a Ziploc bag in the refrigerator. Also check the brushroll, the gray bearing ends with say on either side the words NEW or OLD and both ends need to be identical – new/new and old/old NOT new/old, if the belt and the brushroll are OK then it may be the motor but I don’t think so. So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
Go Ahead. Use Us.
Jun 24, 2008 | Oreck XL Ultra Bagged Upright Vacuum
The best solution to any Oreck vacuum problem is to replace it with another brand. You are going to continue having problems with the Oreck..Not that other brands don't have problems. But, at least with
other brands the problems don't occur as often. Belt burning up. clogs, roller brush bristle wearing down prematurely, cord breaking internally, etc.
P.S. Oreck is good at one thing. Marketing!
Aug 30, 2007 | Oreck XL2200 Bagged Upright Vacuum
Oreck XL2200 Bagged Upright Vacuum Logo
46 people viewed this question
Top Oreck Vacuums Experts
Jim Parker
Jim Parker
xalint1
xalint1
Are you an Oreck Vacuum Expert? Answer questions, earn points and help others
