Question about Roper RAS8244LQ Washer
Washer fills with water, but will not agitate. the bottom part spins in one direction the top feels loose. What do I d?
    President:
  • 1,218 Answers
Good day,
If it's a split agitator, then the dogs on the top part have failed.
Here is an excellent tutorial on replacing them. You will need ordinary hand tools and a rachet with at least one long extension.
"Dogs are the term used by Whirlpool for the brands it makes including Roper".
http://www.youtube.com/watch?v=V5wIN1J70-Y&feature=player_embedded#
Posted on Apr 27, 2010
Testimonial: "That was just what I needed, thanks for your help. I remember this sit."
My WHDSR109J8WW Top Load Washer will not agitate or spin. When to the spin cycle something clicks as if trying to spin but does not. Checked belt...fine. Did the reset motor troubleshoot...did not help....
hi Jlove.
Washer Fills but Does Not Agitate. If your washer fills with water but doesn't agitate, the problem is likely to be a faulty lid switch, a broken belt, or a problem with the motor. (Note: Direct-drive washing machines do not have belts..
Washer Doesnt Agitate or Spin
Top Load Washer will not agitate or spin Google Search
Dec 13, 2017 | GE Washing Machines
Fills with water..doesn't wash..drains and spins..does the transmission spin in direction and wash in the other? in other words does the motor run one direction to spin and rev. to agg/
Yes it does reverse. If the motor is running in agitate pull off the agitator and check the agitator drive (bell) (white plastic bell shaped) on top of the agitate shaft is not stripped. You should not be able to turn. To remove the agitator fill first about 8 in of hot water, drain and pull up on agitator with fingers under the bottom or a belt.
Nov 22, 2010 | Hotpoint -Ariston VVSR1030HWO Top Load...
Washer fills but will not agitate
When you say the rest of the cycles. make sure it is spinning. That washer will fill up and drain and not agitate or spin if you have broken the couplier between the motor and transmission the motor reverses. tip the machine back and feel right behind the motor for a plastic coupler. In wash check the bottom part of the agitator if its moving and the top is not you will have to replace the doggets in the agittator.
Apr 26, 2010 | Whirlpool LSR5132PQ Top Load Washer
Washer fills with water but then nothing, put on spin cycle water empties. The agitator does nothing
the agitator is not on properly due to worn parts under it. remove the top cap, then use needlenose to remove the cap underneath it. lift up from very bottom of agitator. look for worn areas
Oct 07, 2009 | General Electric WHDSR209DWW Top Load...
Not sure if manifold is leaking
Leaks water...check the pump first. The fill valve and hoses may be the next step. See how to take apart info. With the use of plastic drain hoses on many machines today, this has become a common leak trouble maker. The drain hose can rub the wall or a pipe and this will rub a hole in the drain hose.
  1. Agitation problems and agitator dog repair aid info
  2. Automatic dispenser information
  3. Common problems with Inglis, Whirlpool, Kenmore direct drive style of washers
  4. Diagnostic Direct Drive washer chart from American appliance
  5. How a washer works, good to read this first
  6. Help for storing an appliance
  7. How does the agitator come off my washer ??
  8. How to prevent socks from getting into your pump
  9. Ohm test a common direct drive motor
  10. How to by-pass a lid switch for testing the washer
  11. Basic information: Inglis, Whirlpool, Kenmore Direct drive washers
  12. Inglis, Whirlpool, Kenmore Direct drive washers - How to take apart - Cabinet off, cabinet on, checking or replacing a lid switch, replace the pump, replace motor coupling or motor.
  13. Inglis, Whirlpool and Kenmore direct drive washer- useful parts breakdowns
  14. Important disclaimer
  15. My direct drive washer will fill ok, agitates ok but when it comes to the spin and drain cycle the washer comes to a screeching halt...no spin, no draining and the timer stops, what's up?
  16. My clothes have a whiting on them that looks like lint.
  17. My washer has a funky odor
  18. Noises
  19. Ohm meter testing a motor capacitor
  20. Slow water fills
  21. The wash tubs on my direct drive washer are leaning to the right...why?
  22. Timer stalls or missing cycles
  23. Timer will not advance
  24. Tips on changing a common washer fill valve
  25. To learn more about washing machines, click here
  26. Washer Basics: Filling with water
  27. Washer leaks water
  28. Washer moves around to much
  29. Washer will not spin
  30. Washer sample wiring diagrams
  31. Washer spins and agitates at the same time
  32. Washer belts: If your belt on any washer looks like these, replace the belt(s).
  33. Washer runs but wont agitate or spin
  34. Washer won't run, agitate or spin
  35. What is that black power powder or filings under my washer??
Apr 01, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Washer will not dash during use after clothes are added
Check to make sure your agitator is working. The agitator comes in 2 sections, a top (#3) and a bottom (#4). Spin the top section clockwise and than the opposite direction. It should spin free from the bottom section in one direction but when turned the opposite direction it should spin the bottom with it. Hopefully that makes sense. If it doesnt, you need to replace the agitator dogs (#10). Very simple to do. the part # is 80040 and theyre about 8.00. Hope that helps. Let me know if you need help with the install or the par itself. dave www.washermd.com
Oct 23, 2008 | Whirlpool LSR5132PQ Top Load Washer
Ge adora top load washer won't spin,
the water in my washer will not empty, and it keeps pausing its self.
Jun 03, 2008 | Washing Machines
Washer fills and spins but does not agitate
Im sorry to say, it sounds like the transmission in the washer may have gone out, the unit it self sits at the bottem of the main agitator shaft under the the tub, you may be able to have this replaced, but shop around for the right price.
Jan 26, 2008 | Washing Machines
Won't agitate!
does your model have a drive coupling its between the motor and gearcase,when they brake the machine wont wash or spin and makes a wierd noise
Jan 12, 2008 | Whirlpool LSR6232J Top Load Washer
Washing Machines Logo
101 people viewed this question
Top Roper Washing Machines Experts
Mike
Are you a Roper Washing Machine Expert? Answer questions, earn points and help others
