Question about Lexmark X7675 Wireless All-in-One Printer
My lexmark x7675 says i need a net framework 2.0 to work with my computers, and sometimes it say that it is not compatible, but the box say it is compatible with a 64bit computer. IS it compatible?? I download the 2.0 but it is still not working..
  • LXK Chris
    LXK Chris Apr 27, 2010
    Is your computer running on Windows 7 64-bit operating system? Are you using the installation cd that came with the printer to install the software in your computer?
  • LXK Chris
    LXK Chris May 11, 2010
  • 460 Answers
SOURCE: Cannot install Lexmark productivity Centre for X4650 printer.
hardware that worked on older versions of windows will not work with win.7 i found that out with a canon multipass all in 1
Posted on Nov 09, 2009
luciana44
  • 292 Answers
SOURCE: Lexmark X7675 error: Paper Jam (on printer control
Remove the cartridges. see any bits of paper left behind. Replace the cartridges. You will be asked to align again. Do this.
Hopefully, this will work
Good luck
luciana44
Posted on Feb 17, 2010
pineworks
  • 4041 Answers
SOURCE: Print spooler problem cannot delete printer jobs
Hi there
You can try see if this may do it.
Go to Start / Run and type in "services.msc" without quotation marks, then press Enter or click OK.
In the window that opens (Services) look for "Print Spooler" on the right
Right-click "Print Spooler" and select "Properties".
Click on the "Recovery" tab and change all 3 drop-down boxes to "Restart The Service".
Make sure the 2 text boxes underneath say "1" in them.
Click Ok until you are back at the Services window, close it and you're good to go.
Go back into the properties of the "Print Spooler" tab and be sure to click Start to restart the Print Spooler service and it will restart the service immediately.
The Print spooler depends on the Remote Procedure Call (RPC) service. Is this service disabled? Go to services.msc look for RPC. Check state: Automatic
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Posted on Mar 02, 2010
Printtech
  • 1087 Answers
SOURCE: productivity studio wants Msofts .NET Framework
I suggest you install the Lexmark software using the driver from the Lexmark website. First, check if your Windows 7 is running on 32-bit or 64-bit operating system by going the Start menu > right click on Computer > Properties. Then, download the driver using this link: http://bit.ly/dmlCyX (for 32-bit) or this link: http://bit.ly/9drb4y (for 64-bit). Execute the file and follow the instructions on the software. Thanks.
Posted on Aug 20, 2010
SOURCE: No support for Lexmark X7675 on linux (ubuntu 9.04)
http://support.lexmark.com/index?locale=en&userlocale=EN_US&productCode=LEXMARK_X7675&page=recommendedDownloads&segment=DOWNLOAD#2
Posted on Aug 28, 2010
Installing print shop 23 on windows 8.1 get framework incompatibility error. what should i do?
I now have PrintShop 23.1 up and running on my Windows 8.1. This is what worked for me:
1. First, RIGHT CLICK on the Printshop icon on your desktop, select Properties, click on Compatibility, and make the selection to run the program in Compatibility Mode for Windows 8. Click Apply, then OK to exit.
2. Double click the Printshop icon on your desk top to open Printshop. If it works - great! However, if it does NOT work, it means the .NET framework required to run the program was uninstalled or corrupted by the Windows 8.1 upgrade and needs to be reinstalled, so please do the following.
3. From your Control Panel, select Programs and Features; in Programs and Features, uninstall Printshop. (You get to the Control Panel by clicking on Settings in your desktop popout taskbar, usually on the right side.) 4. Check to make sure the Microsoft .NET framework is also uninstalled. If not, attempt to uninstall. If you have recently gone to Windows 8.1, it may be partly or fully uninstalled because the 8.1 upgrade might have removed (or damaged) part of it. If it will not uninstall, don't worry! Proceed . . . 5. Follow this step even if you see no sign of the .NET framework in Programs and Features. It is almost certain that you have debris from it on your computer because this is a known problem, and Printshop will not reinstall unless the debris is removed. THEREFORE, clean your computer by using the Microsoft .NET Framework Cleanup Tool found at the following link:
.NET Framework Cleanup Tool http://blogs.msdn.com/b/astebner/archive/2008/08/28/8904493.aspx
6. AFTER Printshop is once again installed, it will very likely NOT RUN unless you follow Step #1, above, to run it in Windows 8 Compatibility Mode.
Dec 20, 2013 | Broderbund The Print Shop 23 Deluxe
Updating .net framework
The Microsoft .NET framework, sometimes called dotnet, is a collection of software libraries and assemblies installed on the Windows operating system.
Software languages that are .NET compatible will take programmer code and construct it into a language, called bytecode, which the .NET framework is able to load and utilize.
You will need to update your .NET framework if the application you want to use was built with a more recent edition.
Open your web browser and visit the .NET framework downloads page on the Microsoft website (See "Below").
http://msdn.microsoft.com/en-us/netframework/aa569263.aspx
Click "Install It Now" and click "Download" to obtain the framework installer.
Save the file to your desktop, then double-click it to open the installation.
Review the software license at the top of the page, then place a check mark next to "I Have Read and Accept the License Terms." Click "Install" to proceed.
Click "Finish" when the "Installation Is Complete" window appears.
You have now updated the .NET framework.
Jul 13, 2013 | Iolo Technologies System Mechanic: Windows
Error code 0x800B010E wont connect wireless to internet, trouble shoot wont work. path c:\windows\diagnostics\system\networking. content restricted. please help......
I am assuming you are running Vista or Windows 7. According to Microsoft this error is an issue with .NET framework. They suggest you turn off .Net, restart your computer, then turn .NET back on. Here are the instructions they give you.
Error code 0x80131700 is usually relevant to the old version of .NETFramework installed on your system. By default, the built-in version ofMicorosoft .NET Framework is 3.5.1. You can reinstall Microsoft .NETFramework 3.5 Service Pack 1 through the following steps:
Step 1:
a) Click the Start and type: "features" in the Search box.
b) Select "Turn Windows Features on or off " and click Enter.
c) Find Microsoft .NET Framework 3.5.1 and uncheck the box.
d) Restart the computer.
e) Repeat the step 1) to step 2.
f) Check the box before Microsoft .NET Framework 3.5.1.
g) Restart the computer.
Step 2:
If the issue persists, then I suggest you to perform the process by booting the computer in Clean Boot and check.
http://support.microsoft.com/?id=929135
Note: Follow the step 7 to restart your computer as usual.
Jul 02, 2011 | D-Link Computers & Internet
.Net Framework v.2
I presume your printer is the Lexmark X4650 since your post is under this printer model. You will need to use the Lexmark X4650 driver available for download in the Lexmark website instead of using the installation cd. Don't connect the printer to computer yet with the usb cable. First, check if your Windows 7 is running on 32-bit or 64-bit by clicking on the Windows logo Start menu > right click on Computer > Properties. For the software, click on this link: http://bit.ly/cdyD9A (for 32-bit) or this link: http://bit.ly/ciegdd (for 64-bit). Download and install. Just follow the instructions. Hope this helps. If you need more assistance, leave a comment and I'll get back to it. Thanks.
May 19, 2010 | Lexmark X4650 InkJet Printer
I WANT DRIVERS FOR LEXMARK Z100
It would have been better if you posted the exact model number of your printer (e.g. Z2420, Z1300, X7675, etc.) and the operating system of your computer. But here's a link to the Lexmark website where you can download the drivers. Just click on the link: http://bit.ly/aiWCx4 . Type the exact model number (e.g. Lexmark Z2420, Z1300, X7675, etc.) on the bar just below the images of some of Lexmark's printers then hit Select. On the next page, choose the correct driver compatible for your computer's operating system. Download and install the driver. Hope this helps.
Mar 31, 2010 | Lexmark Z1300 InkJet Photo Printer
Device monitor application has stopped working
First thing, update Windows. The error occurs from Microsoft .NET Framework. Lexmark could have made their application a bit more compatible with framework, but they didn't.
Sometimes the updates still don't fix the problem. Lexmark has a patch for it on their support site depending on your model of printer.
I also heard rumors in other forums that microsoft has .net framework patches that fix the problem.
Hope this helps.
Apr 12, 2009 | Lexmark Forms Printer 2580 Matrix
Lexmark X7675 Wireless All-in-One Printer Logo
365 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
