Question about SmartDisk FireLite 80 GB Hard Drive
I have a SmartDisk Firelite 80 GB hard drive that appears to not have any more power. (no light or spinning). What is the best way to proceed to recover my data ?
    Sergeant:
    Novelist:
  • 172 Answers
Hi jspurrple. It sounds the board on the external casing. So remove the hard drive from it, and connect it to another computer as a "slave". Then proceed to move your data. In case it's the actual hard drive, it's the voltage regulator ON the logic board. It's a transistor around where you connect the power cable, you just rip it off and it will turn on, but BE **CAREFUL** I do not recommend you doing that if you are not an IT tech. I hope this helps.
Posted on Apr 27, 2010
How to transfer 57 gigs from a mac to firelite xp.
The hard drive maybe formatted in Windows NTFS format and the MAC cannot see this formatted hard drive.
If you only wanr to use this hard drive on a MAN then you need to format this hard drive with your MAC.
If you want to exchange files between your MAC and a PC then you need to format the hard drive on a PC in FAT32. The MAC can read and write to a FAT32 formatted hard disk.
May 30, 2012 | SmartDisk FireLite 80 GB Hard Drive
I have firelite external and it's not working. There's light but no spinning sound. what can I do?
This a firewire drive and needs to plugged into a firewire port to spin up. If you do not have a firewire port on your computer (most PC's don't) it will not work. I don't believe a firewire to USB connector will pass enough power to the drive to spin it up.
Mar 12, 2012 | SmartDisk FireLite 60 GB Hard Drive
On my smartdisk firelite the conection that excepts the usb cable has broken. I need data thats on the hard drive how would I get this info off the firelite?
you can open the case and remove the hard drive and install it in a new external usb case for it.
you can find out what type of case you need after you open it. it could be either a SATA connection or IDE.
If it is a SATA and you got a SATA cable/power you could also just install it directly into your computer and grab the files you need.
Mar 11, 2011 | SmartDisk FireLite - 80GB - 5400rpm - USB...
My USB smartdisk firelite is not recogniced by any laptop, regards
Connect it to a different DESKTOP computer. If it still is not detected, then there is a hardware problem. Exercise the warranty to get it repaired/replaced.
Oct 29, 2010 | SmartDisk 80GB FireLite USB Bus-Powered 80...
I need to reformat my 80 GB Firelite
whats the OS you are using? if you are on Xp. go in to my computer. right click on the external drive ( the drive name will depend on you device) click format.
May 04, 2010 | SmartDisk FireLite 80 GB Hard Drive
Not showing any signs of power, and computer not seeing new hardw
Try using a different power cord because if there is no power nothing will happen on the computer
Dec 11, 2009 | SmartDisk FireLite 80 GB Hard Drive
THE SMARTDISK 80 GB MODELUSBFLB80-C WILL NOT WORK WITH USB.THERE WASN'T A 5 VDC POWER ADAPTER. wHAT IS THE SPECS FOR THE 5 VDC APAPTER
Make sure you are connecting it to a usb 2.0 port. Usb 2.0 will supply the 5v power the device needs. also use the cable that came with the drive. some drives plug into 2 usb ports.
Nov 30, 2009 | SmartDisk FireLite 80 GB Hard Drive
External smartdisk firelite
It seems that you will lose your files. These file already
infected with virus, and corrupted it. There's no other
way but to reformat your smartdisk.
Oct 08, 2009 | SmartDisk FireLite - 80GB - 5400rpm - USB...
Dropped firelite: still spins but is not recognized
Ok same situation happened to me i dropped my Firelite 80Gig, drive would spin no light and the computer would not recognize the drive. All I did was open the case an saw the the internal hardrive had come loose from its pin connection. So all i did was pushed it back in and BAM now it works, hope this helps other people. Thanks C.J.
Mar 20, 2008 | SmartDisk FireLite 40 GB Hard Drive
SmartDisk FireLite 80 GB Hard Drive Logo
109 people viewed this question
Top SmartDisk Computers & Internet Experts
Sunday Ojelabi
Sunday Ojelabi
 Ian Kayhan
Ian Kayhan
Are you a SmartDisk Computer and Internet Expert? Answer questions, earn points and help others
