Question about D-Link AirPlus Xtreme G DI-624 Wireless Router (DI624RE)
I've lost my key for wireless access. how do i reset
    Sergeant:
    Novelist:
  • 172 Answers
Hi, you have do a HARD RESET. Unplug your router (the power cable). Then you have find the reset button (a very tiny one behind the router) and once you find it, keep it pressed and while pressed you have to reconnect the power cable and wait for 10 seconds... then release the reset button and you will reset the router to factory default, so you will have probably to go to 192.168.0.1 (default ip) and type admin (as the user) and "blank" password (no password) and then you reconfigure your settings. I hope this helps
Posted on Apr 27, 2010
Testimonial: "thanks for your help. I was able to find my key and access my network"
I had lost the key number of linksys dsl router, so i need that key right now !
Just hold reset button in back for 30 secs small black hole then goto 192.168.1.1 in your web browser use password admin admin or admin password that should get you in to resetup you wirelss settings.
Jul 05, 2011 | Linksys Wireless-G WAP54G 802.11g/b...
What will i do if i forgot my security key???
All you have to do is connect to the router and change security key/ secure the connection. Just follow the following steps: -
First you have to access the router through web browser (Internet Explorer) by typing the IP address of your router in the address bar, which is 192.168.0.1 (Default router settings are written under the router)
(unless you've configured otherwise, the default username is admin and the password "leave it blank") and lookup for the options to do the following: -
Next step is to secure it:
1.On the left-hand side, under Setup, click "Wireless Setup" 2.Under "Wireless Security Mode", select your desired encryption method (preferably WPA2-PSK)
3.Choose a Network Key - it can be anything, as long as it's 8-63 characters in length
4. Click Save Settings.
1. Change the SSID (Name) of the router
2. Change the default administrative user name and password
(The above step would prevent unauthorized access to your router)
Now your router and your connection would become secure and the user has to provide the network key to access the internet.
In case you have forgotten the User Name/ Password of the router, there is no way to recover the lost password However, you can reset the router to factory defaults and re-configure settings like password, network key etc. First, to reset the router to factory default setting, press the reset button at the back of the router.
Please note that after RESETTING THE ROUTER to defaults, ALL SETTINGS WILL BE LOST AND YOU HAVE TO RECONFIGURE IT. Generally, after hard reset you get the connectivity, however, you have to make the connection secure etc.
Please, refer here to download the product guide/manual and make configurations as per the details provided by your Internet Service Provider (ISP).
Let me know if any further clarification/ assistance is required.
Hope it helps! Good Luck! Thanks for using Fixya!
CreativeTECH
Jul 01, 2011 | D-Link AirPlus DI-524 Wireless Router
I have a new lap top which is recognising the wireless network and then asking for a network security key. How do I find this?
The network security key is essentially a password that was setup to control access to your network. Presumably, when you set it up you gave it a password that you could remember, but not so obvious that people could easily guess. If you've forgotten or lost the password, you can reset the router by using a paperclip and holding the reset button for about 10-15 seconds. Once you reset the router, it will be restored to its original factory defaults and you can then setup again your wireless networking.
Jun 20, 2011 | D-Link AirPlus DI-524 Wireless Router
I lost my access code
If you lost the wireless access key you can find it by logging into your router. Using an internet browser type 192.168.1.1 into your address bar. A login window should pop up. The default login is username: admin password: admin . If these do not work then you need to reset your router to factory defaults. If this does work then look for the place where you can change the key and change it. You may need to reset the router after this for settings to take effect but after that it should work.
To reset to factory defaults, look for a button on the back that says reset. Press and hold this down for 30 seconds. Everything should reset to factory defaults and you should be able to connect without a password.
May 12, 2011 | ASUS RTN12 IEEE 80233u IEEE 80211bg...
Need security key for linksys router
If it is your router your trying to access try these https (only necessary to try second one if first doesn't work)
these are the network/password config for linksys
http://192.168.1.1
http://192.168.0.1
May 06, 2011 | Linksys WRT54G2 Wireless Router
Lost wep key
if you lost it your out of luck. Hold the reset button on the back of the router for 10 seconds to reset to factory and then you can reset up the wep key with a new one.
Mar 03, 2011 | Linksys Wireless-G WRT54G Router
Web key wireless internet service
I think you meant WEP key. this is a wireless encryption security key. and it is normally required when you try to connect to a secured network. Your administrator should be able to provide you with this. because it varies. i.e you can set it to whatever you want if you have access to the wireless router. in your case Belkin 54g Wireless DSL/Cable Router
so please if you have access to it, log in to the router and check from wireless security settings.
Regards
May 20, 2010 | Gateway Belkin 54g Wireless DSL/Cable...
Paraphrase key/code
try resetting your access point. There should be a pin hole on the back of the router. Press the pin down for 10 seconds until the lights on the front of the router start blinking.
Jul 27, 2008 | Belkin (F5D7132) 802.11b/g Wireless Access...
I lost the instillation CD and need the wep code
The WEP code is whatever you make it when you set up the wireless connection. If you have lost this key. It is best to use the manual reset located on your wireless router. Will require a small point like a paperclip. Then you will have to access the router and set up the wireless internet over again. Then you can secure it with a new WEP key.
If you need further assistance please ask me.
Thanks,
Lee
Jun 17, 2008 | Belkin (F5D7633UK4A) Wireless Router
LOST SECURITY KEY
Sivi,
All you need to do is access the router setup page and check the network key from there. You can go this link and use it as a guide on how to access the router and check the security set on it.
May 20, 2008 | NetGear DG834G Router
D-Link AirPlus Xtreme G DI-624 Wireless Router (DI624RE) Logo
115 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
