Question about Whirlpool Washing Machines
How to relpace lid switch on whirlpool washer model number lsr5101lq0
    President:
  • 1,218 Answers
Good day,
Here is a tutorial on replacing the lid switch. Their position and installation will vary on certain models but it will be easily understood once the cabinet is apart.
http://www.youtube.com/watch?v=fC8SY3cU1Yc
Posted on Apr 27, 2010
Washer will not spin r drain model whirlpool la7680xmwo
Sounds most likely a broken/defective lid switch. The lid switch on a top-load washer is a safety switch that detects whether the top-load washer lid is closed. The lid must be closed when the basket spins; some top-load models require that the washer lid be closed before the washer drive motor runs (thus no draining). If the lid switch isn't properly detecting whether the lid is closed replace the switch.
Dec 24, 2016 | Whirlpool Washing Machines
I was given a whirlpool ultimate care II washer recently, and the lid switch is broken, but I cannot find what the model number is for my washer (believe me, I have looked EVERYWHERE for it!), and the part...
Usually the model number is on the lip of the inner rim of the washer when you open the lid...near where the water comes into the basin. But even if you can't find the part number for the switch or the washer, you can just defeat the switch by taking the two colored wires from the switch and twisting them together...no switch needed then!
Jul 27, 2011 | Whirlpool Ultimate Care II LSQ9549L Top...
My Kenmore washer will fill with water and oscilate, then nothingf won't spin or drain. I 'm guessing that it is the lid switch , ( relay switch ) ?? Mod # 110.94518201 serial # VLG 1601709 can this...
This assumes that you have a basic Kenmore / Whirlpool top load, direct drive, neutral drain (it doesn't spin until the pump removes most of the water) machine.
First, see the Sears parts site for your washer:
http://www.searspartsdirect.com/partsdirect/part-model/Kenmore-Parts/Washer-Parts/Model-11094518201/0582/0153200?pathTaken=
and you'll see a list of major sub-components with diagrams and parts.
Look at the diagrams for the cabinet and you'll see a list of component parts (Lid Switch) with the Sears part numbers (the manufacturer authorized substitute numbers are Whirlpool) and the Sears price.
Newer model Whirlpool / Kenmore washers use a Lid Switch as a safety device. Unless the switch senses that the lid on the washer is closed, the washer will neither agitate nor spin.
Older models only used the switch during the spin cycle.
Try to bypass the Lid Switch by removing the Console and jumping the two outermost pins on the switch.
To bypass the switch, you only have to disconnect the power to the washer, tilt the console back, unplug the switch and using an short piece of insulated wire, jump the two outermost contacts on the connector coming from the console and plug the washer back in.
Following is a description of how to gain access to the console and how to remove the cabinet if necessary.
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=131&osCsid=913ba652cd504fb162f87d892bcb427b
With the jumper in place, try to re-start the washer.
If it works, the Lid Switch is a relatively inexpensive part and only requires you to access the console and remove the cabinet.
Dec 03, 2010 | Washing Machines
Kenmore 20712 goes trough the first cycle OK but when it comes to draining and spin cycle it stops.
http://www.searspartsdirect.com/partsdirect/index.action
Enter your model number (###.######) and you'll see a list of major sub-components with diagrams and parts. (20712 is a stock number for a number of products, you'll need the full model number that starts with 110. )
This is a Whirlpool PDF on how these washers operate. It has a diagram on jumping the switch as well as a detailed section on how the transmission works.
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/f7e2147fa98b28cf85257122007475cb/$FILE/L-55.pdf
It also has a troubleshooting guide.
Oct 12, 2010 | Kenmore 20172 Top Load Washer
Lid switch doesn't work
Enter your model number (###.#######) and you'll see a list of major sub-components with diagrams and parts.
On most top loads, you can usually find the model number by lifting the lid and looking at the top of the tub. The model number may also be on the label with the serial number, part number etc.
If you find the model number, also go to the Sears site that has on line (PDF version) manuals.
SEARS ANSWER SITE
http://www.managemyhome.com/
The Kenmore / Whirlpool top load uses a reversing motor to initiate the pump for draining and the transmission to spin.
If you cannot hear the motor trying to turn the pump, (but the washer will agitate) the problem points to the Timer, or the Lid Switch.
Following is a description of how to release the console for access to the pins.
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=137
Also see the following for a more detailed description of how the transmission works.
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/2550f737b3129b0c85256b0600504738/$FILE/787772%20%234.pdf
If it works, the Lid Switch is a relatively inexpensive part.
May 03, 2010 | Kenmore 24032\24036 Top Load Washer
My whirlpool washer will not go to drain cycle . i put it on regular wash it fills and aggitates but when it stops it stops .
If the washer fills, agitates, then stops at the rinse and won't drain, or if the washer does an initial fill, then stops, this is a symptom of a lid switch malfunction.
The following link explains how to access and/or replace one:
http://www.fixya.com/support/r385198-replacing_lid_switch
The lid switch is usually mounted under the washer top casing, on the right hand side on most top load models. It is activated by a plastic piece on the lid (called a "Lid Strike") through a small hole on the rim of the wash tub opening. In many cases the lid strike breaks off the lid, or the lid switch becomes loose and no longer makes contact. Inspect the lid to make sure the lid strike is still intact, and then inspect the mounting screws (adjacent to the small opening on the wash tub rim) and make sure they are snug.
If the model number you have this listed under is correct, the part number for a replacement lid switch is 3949247. This is a very simple repair, that usually costs about $30 to repair yourself.
Appliancepartspros.com, pcappliancerepair.com and searspartsdirect.com usually have excellent exploded view diagrams of what I am referring to. Just type in your model number and look under the "Top and Cabinet Parts" section. The lid switch is listed as item 11 and the lid strike is listed as item 20.
If you have questions, or require additional assistance, please let me know. Post back with a correct model number if the model number is not correct. I hope this helps you.
Oct 02, 2009 | Whirlpool Ultimate Care II LSQ9564J Top...
Washer
The symptoms you describe are typical of a broken lid switch. The lid switch is located under the washer top on the right hand side. It is activated through a slot by a small plastic piece on the lid called a "lid strike". Make sure the lid strike is still installed and not broken. Make sure the lid switch itself is not loose, as well. There are two mounting screws along the washer tub opening that hold it in place. If the screws become loose the switch will not make contact with the lid strike when the lid is closed. If you need to replace the switch or lid strike, the parts are available at searspartsdirect.com. Just type in your model number and look under the "Washer Top and Lid" heading on the next page. The lid switch is listed as item number 22 (part #3355806) and the lid strike is listed as item number 16 (part #358684). Both parts combined will cost you about $30. If you have further questions and/or require additional assistance, please let me know. I hope this helps you.
Jul 21, 2008 | Whirlpool LTE6234D Top Load Stacked...
Washing Machines Logo
Dan Webster
Dan Webster
Sal De
