Question about Apple iPhone Smartphone
My iphone 2g is not charging and its not even syncing.
My iphone is neither charging(with wall charger or USB) nor syncing with itunes.i tried all possibilities like pressing down home and power buttons together,Apple logo did appear few times and then again iphone got turned off,now iphone is not even turning on as battery is completely drained.rebooting PC while iphone attached didnt work either.
what should i do and what could be the possible reason behind this?
  • 22 Answers
The place where you plug the wire might be messed up.. do a diagnosis on it with apple
Posted on May 02, 2010
I want to sync iPhone to iPad.
  1. Open iTunes. ...
  2. Use the USB cable that came with your iOS device to connect it to your computer.
  3. In iTunes, find and then click your iOS device.
  4. On the Summary tab, select "Sync with this [device] over Wi-Fi."
  5. Click Apply, then disconnect the USB cable.
Sep 30, 2016 | Cell Phones
I repaired my lcd on my iphone 4g and now it wont sync to my computer or even charge however if i conect it to my wall usb charger it comes on and says conect to itunes
The dock connector is not connected properly or maybe the ribbon cable was damaged. The guide to re-assemble it properly is here: http://portatronics.com/guide/
Jan 07, 2011 | Apple iPhone Smartphone
I plugged my iphone to the computer but it wont charge or sync
Try turning it off and then back on, if turning it on and off doesn't work, restoring it might work. Also try to remove the SIM card and put it back into the phone. I recommend simply exchanging the phone at the Apple store if it is still under warranty. Click on the links below to see other soultions for the charge and sync iphone problem
http://discussions.apple.com/thread.jspa?threadID=1392386
http://support.apple.com/kb/HT1737 (For PC users)
http://support.apple.com/kb/TS1410 (For Mac Computers)
Jan 06, 2010 | Cell Phones
My iphone 2g only shows the apple for 10 seconds then shuts down
Try restoring it...here's how...
  1. Disconnect the USB cable from the iPhone or iPod touch, but leave the other end of the cable connected to your computer's USB port.
  2. Power off the device (Press and hold the Sleep/Wake button for a few seconds until the red slider appears, then slide the slider. Wait for the the iPhone or iPod touch to turn off.
  3. Press and hold the Home button while reconnecting the USB cable to iPhone. When you reconnect the USB to iPhone, the device should then power on.
    Note: If you see the message "Charging... Please Wait" , let the device charge for at least 10 minutes to ensure the battery has some charge and then start with step 2 again.
  4. Continue holding the Home button while iPhone starts up. While starting up, you will see the Apple logo.
  5. When you see "Connect to iTunes" on the screen, you can release the Home button andiTuneswill display the recovery mode message:
    If you don't see the "Connect to iTunes" screen, then disconnect the USB cable from iPhone and repeat steps 3-6.
After this you'll need to jailbreak it too....
Sep 04, 2009 | Apple iPhone Smartphone
I have a iphone 2g 8gig that will not charge or connect to itunes
I have seen this many times, but not to this degree with so many different problems. The issue is your main flex cable which holds the Charger, Microphone, Speaker and connects to the main board. It is extremely difficult to replace. I do not know what country you are in, but you need a proffessional repair center. If you are in US you can contact me if you like. cellularcpr@aol.com. Thank you
Jun 23, 2009 | Apple iPhone Smartphone
My iphone 2g wont charge & wont turn on
Try using another cable or charger. A damaged charger or cable could cause it not to charge.
Otherwise, contact apple or apple store for repair.
May 06, 2009 | Apple iPhone Smartphone
Drain battery for my iphone 2g
Download the latest iTunes to your computer and reset the iPhone. Then re-sync it.
To reset iPhone, press and hold the Sleep/Wake button and the Home button at the same time for at least 10 seconds. During this time, a red "power off" slider may appear and the screen may go black, but do not release Sleep/Wake and Home buttons until the Apple logo appears
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Iphone 2g wont sync
Please look here:
iphone Troubleshooting Assistant
http://www.apple.com/support/iphone/troubleshooting/phone/
Reset and Restore iPhone to Original Default Factory Settings with Recovery Mode iPhone display freezing? iPhone doesn’t detect by or appear in iTunes? iPhone cannot sync with iTunes on PC or Mac? Cannot make or receive calls, send or receive text messages, or access email or the web? Or worse, iPhone simply won’t turn on and does not respond to tap or button press? If the problem still persists after you have reseted the iPhone, or tried various iPhone troubleshooting, it may be worthwhile to invoke recovery mode to restore iPhone to default factory settings, the original state as when you first received and unwrapped the phone.
Restoration of iPhone to original factory defaults will likely to fix all problem, with the downside that all data and information stored on your phone will be lost. Normally iTunes will make a backup automatically when you connect and sync the iPhone with the program, however, it’s still a good recommendation to copy out and backup everything that you may need on the phone before proceed to restore the iPhone.
To restore iPhone and reset the phone to default factory settings, follow these steps:
  1. Turn off iPhone - Hold down the Sleep/Wake button for a few seconds until the red slider appears, then slide the red slider. Ignore this step if your iPhone is already off.
  2. Press and hold down the Home button for about 10 seconds until a yellow triangle with a text which says Please Connect to iTunes appears. iphone-recovery-mode.jpg
  3. Plug the iPhone into Mac or Windows PC. Release the button if you haven’t.
  4. Run and open iTunes if it’s not already opened yet.
  5. iTunes will prompt a message that says iTunes has detected an iPhone in recovery mode. Click OK.
  6. You will be taken to the iPhone pane. Then, click on Restore.
  7. Wait for the full restoration process to complete, and the iPhone will be back to the original settings state as when it left the manufacturing factory, typically a working phone again if you face any problem, unless it’s hardware related
http://www.mydigitallife.info/2007/10/04/reset-and-restore-iphone-to-original-default-factory-settings-with-recovery-mode/
Jan 02, 2009 | Apple iPhone Smartphone
My iphone won't sync with itunes. it did at first but now keeps coming up with an error I have an original iphone, never been jailbroken or any such thing, and can not currently get it to sync with itunes...
Recharge
Make sure iPhone is charged. Connect to a USB port and look for the lightning bolt battery icon in the upper right. If you don't see this icon, then iPhone is not charging. The battery will charge to 80% in an hour.
Note: If you put your computer into sleep mode while iPhone is connected via USB, iPhone may not charge.
This screen means to keep iPhone connected so it continues charging. Please note:
If iPhone is not sufficiently charged it will not show up in iTunes
Use a high-power USB port such as the one on your computer, or use your iPhone AC adapter.
Don't use the USB port on your keyboard because it is a low-power port and iPhone will not charge.
Make sure you are using USB to charge. Accessories that use FireWire to charge are not supported with iPhone.
If you see the red part of the battery image flash three times and then the screen goes black, it means that iPhone is not receiving power to charge.
If the above steps dont resolve follow the following steps :
Retry with a different USB port.
Note:
Restart
Try restarting iPhone. To turn it off, press and hold the Sleep/Wake button until the red slider appears. Slide your finger across the slider to turn off iPhone. To turn iPhone on, press and hold the Sleep/Wake button until the Apple logo appears.
Does iPhone appear frozen or stuck? Try pressing and holding the Home button for at least 6 seconds to close a frozen application. Then try restarting iPhone again.
Note: If that doesn't work, try restarting your computer.
Reinstall
Reinstall iTunes 7.7 or later.
Get the latest version of iTunes (7.3 or later) from http://www.apple.com/itunes/download/
Thanks.
Oct 21, 2008 | Lands Phones
Apple iPhone Smartphone Logo
293 people viewed this question
Top Apple Cell Phones Experts
Computer Repairing
Computer Repairing
Lesley Cameron
Lesley Cameron
Are you an Apple Cell Phone Expert? Answer questions, earn points and help others
