Question about Ovens
Having trouble replacing an oven ignitor
I have a gas oven ignitor that needs replacing. I do not understand what it means to strip a wire and attach to the ceramic nut. It has a connector but the connector on the new ignitor wont easily connect to the one in the oven. What do I do?
  • Ovens Master
  • 43,501 Answers
All that means is to take the outside insulating coating off of about 1/2" of the wire... that is stripping the wire and making it bare... then you take the two wires that need to be connected and twist them together,,,, then twist the ceramic nut over the wires til it gets tight...this gives you a good connection... make sure that none of the bare wire is out past the back of the nut where it could hit metal and short out..
heatman101
Posted on Apr 28, 2010
How to change ignitor
Igniters are fairly easy to replace, it will be on the oven burner tube. there are a couple screws that hold it on. Most have a connector that unclips and just clip the new one together. If the connectors are different then you will have to remove the connector if equipped and strip about a half inch off the wires from the igniter and the wires cut from the old igniter and use the supplied wire nuts. A tip spray a small amount of WD40 on the screws that hold the igniter in place. Sometimes they will strip otherwise. It will burn off in a few minutes after turning the oven on.
Oct 02, 2014 | Whirlpool 30" Self-Cleaning Freestanding...
Tip
Replacing igniter
GE wall ovens have panels for regulator and ignitor wiring at the lower back of oven. remove all screws and plates to expose wiring. clip off defective igniter and use ceramic wire nuts to fasten new one. re-assemble.
I learned from local gas company that igniter is most frequent part to replace.
cost = $35
GE technical support = non-existent.
power of the internet - priceless!
on Jun 18, 2008 | GE JGRS14 Gas Single Oven
I have a Maytag Oven Model CRG9800BAE Will not ignite gas when turned on.
are you saying that when you set it to bake the oven doesn't heat or are you talking about the top burners?if it's the oven you have a bad ignitor, the oven flame should lite in under 40 seconds to a minute,if it doesn't it's the ignitor,part number 12400035 and it's around 80 bucks.unplug it or kill the braker,take out the racks,remove the bottom panel or oven floor,take off the wing nut and remove the metal cover and you'll see the burner tube and the ignitor,,with a wet paper towel wet the screw threds on the two screws with water so they don't strip out and then remove the two screws holding the ignitor on,trust me it works.if you have to, unplug the ignitor or if it's not the original ignitor cut the two wires at the end of the old ignitor and connect the new ignitor with the ceramic wire caps and remove the burner tube if it's hard to get at the ignitor screws.put it back together and the ignitor should lite the flame in less than a minute.let me know how you make out
Aug 22, 2010 | Ovens
Where is the oven igniter located at in a Frigidaire single gas oven located if I need to replace it?
remove the oven racks, in back there will be two chrome screws, remove them. Lift the lower oven panel out by pulling up from the rear. Remove the screws holding the flame spreader and remove the flame spreader. Now you will see the burner and igniter attached to it. There are 2 quarter inch hex screws holding the ignitor on. GE likes to put them on an angle, so it is easier to remove the burner tube. Remove the bottom drawer and remove the screws securing the burner to the back wall. There should be one in the front too. The burner will now lift up and you can get at the screws. The new ignitor should come with ceramic wire nuts. Just cut the old igniter, strip the ends of the wires going to it and wire nut the new one on. Reverse the rest of the steps. There is also a video at www.appliancehelponline.com/servicemanual.html that walks you thru testing this part. You can also enter your model # for diagrams and illustrations.
Apr 09, 2010 | Frigidaire FGB24L2A Gas Single Oven
I replaced the WBX20154 glowbar for my oven as
The model number on a built in oven is usually found on the oven frame, just behind the oven door. (should be a metal tag, or silver sticker) It is NOT LIKELY that the oven valve is bad. (although if you have a self clean model, they would have seperate valves for bake and broil)
When the oven is turned on, there should be 120 volts across the ignitor. You can test the igniter by putting one wire into the left side and one into the right side of a standard recepticle, but you have to be careful with bare wires and the ignitor gets hot very quickly, and stays hot for awhile, so if you try it, be very careful. I'm assuming that your original ignitor was a round one also (not a flat one). It is very important to use the same type as the original.
I suspect you have a poor electical connection. Make sure wires are stripped back about 1/2 inch, then make sure the ceramic wire nuts are tight when installed.
Nov 05, 2009 | GE Profile JTP18 Electric Single Oven
How do you light a gas oven
Chances are your hot surface ignitor is bad. Take off the bottom panel inside the oven you will have to removes grills also. You will see a center beam under the panel that is where the flames of your burner are. The hot surface ignitor is right there at the start of the burners. As a test turn the oven on and notice it hot surface ignitor glows. If it didn't glow then it needs to be replaced. Easy fix only held on by two small screws 1/4 size nut runner and two wires. You will have to cut the wires as they run back into the back of the oven. The new one just take the wire nuts that come with it and attach. Don't make the wires too short as you will need the length. let me know how it goes ken
Jan 11, 2009 | Amana AOGD2750 Gas Double Oven
Oven wont heat (igniter help needed)
Once again...I apologize for not getting back to you sooner. My email notification doesn't seem to working.
The part number for the bake igniter is WB2X9154. You can order a replacement part online at any of the following websites: searspartsdirect.com, repairclinic.com, pcappliancerepair.com or appliancepartspros.com. I recommend these sites, because they seem to offer the best service and offer competitive pricing. I would recommend checking all of them for the best price.
You do not need to remove the oven floor to access the connector wires for the igniter. Remove the lower drawer for access. Make sure you unplug the stove and turn off the gas before servicing. As stated before, the new ignitor may or may not have a matching plug to fit your range. If the connector does not match, there will be guidance provided with the new ignitor that instructs you to cut the wires and splice using heat resistance ceramic wire lugs. They should be included with replacement kit. DO NOT use standard wire lugs. They will melt. Let me know if you require further assistance. I hope this helps you.
Dec 14, 2008 | GE JGRP17 Gas Single Oven
Oven not working
CW, the problem with your oven is the igniter. The igniter is wired in series with a safety valve. The safety valve monitors the amount of electrical current flowing through the igniter when you ask it to "bake".  When the igniter gets "weak" it won't allow current to flow through it properly, this will keep the oven from heating.
Before you begin the repair, you should have the new part on hand. The part number is WB2X9154 and can be purchased at your local appliance parts retailer for about $50.00. Here's one online for $65.00.
First, UNPLUG YOUR OVEN!
To replace it... Remove the racks and lower panel (oven floor). This will expose the burner manifold where the igniter is mounted.  (It's the round thing on the manifold near the back... it has 2 wires going into it.) You'll need a 1/4" socket or nut driver to remove it.
(*TIP---> before removing the screws from the igniter, put a few drops of liquid dish soap on the threads to lubricate them. If you do this, you will not strip the threads of the screws and it will ease their removal.)
The new igniter kit will have two ceramic wire nuts in it. Cut the two wires off of the old igniter and strip them back about 3/8". Then connect the wires of your new one to the wires in the oven using the ceramic wire nuts provided. Then mount the new igniter and rebuild the oven.
(*TIP---> The new igniter is very fragile! [that's why it came wrapped tightly in bubble wrap] Handle it gently!)
There ya go! Total job time? ~45 minutes.
Oct 11, 2007 | GE JGRP17 Gas Single Oven
GE JGRP17 Gas Oven
Rosanne, he problem with your oven is the igniter. The igniter is wired in series with a safety valve. The safety valve monitors the amount of electrical current flowing through the igniter when you ask it to "bake".  When the igniter gets "weak" it won't allow current to flow through it properly, this will keep the oven from heating.
First, UNPLUG YOUR OVEN OR TURN IT OFF AT THE BREAKER!
To replace it... Remove the racks and look up at the broiler manifold. You'll see the igniter mounted at the rear (the round thing with 2 wires going to it). You'll need a 1/4" socket or nut driver to remove it.
The new igniter kit will have two ceramic wire nuts in it. Cut the two wires off of the old igniter and strip them back about 3/8". Then connect the wires of your new one to the wires in the oven using the ceramic wire nuts provided. Then mount the new igniter, tuck any loose wires as far back into the oven as possible and replace the racks.
Apr 11, 2007 | GE JGRP17 Gas Single Oven
Ovens Logo
42 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
