Question about Cameras
Sony Cybershot DSC-W55 Flash Error Code
I have several cameras that I have been refurbishing and reselling. I recently have attempted to refurbish one that had an error code E:91:01 with no flash function. I replaced the flash board and re-initialized the camera. The code persisted. I then replaced the main board and re-initialized the camera. Still got code. Replaced the ribbon connectors between the boards, no improvement. Returned all cannibalized parts to original cameras, code has now migrated to previously known-good cameras. There is obviously a procedure for resetting this code that is needed when the flash board is disconnected from the main board. I discharged the flash capacitor as directed in the Sony Level 2 Manual for this model with a 1Kohm/1W resistor for 10 seconds before disassembly. When I re-initialize, the screen shows a flash icon with an orange flashing indicator that lingers for a while then beeps repeatedly before disappearing. The camera will work fine except there is no flash function. It shows the same indicator and symptoms after re-initializing with no flash board installed, suggesting that the flash circuit is not even being recognized when installed.
ANY help would be greatly appreciated.
James
  • 1 more comment
  • Kinsierian Mar 24, 2008
    I think maybe you have the camera model confused. There are no controls on this model that you described and there is no LCD cover.
  • Kinsierian Mar 26, 2008
    Need help with the Flash error code. Re-initializing does not fix the error.
  • Kinsierian Mar 27, 2008
    Ok, i took the entire flash unit with it's associated ribbon connector out of the camera, installed it in another camera and it works fine. I replaced the main board, no go. Replaced the control board, no go. Replaced the lens and the top board too. i cannot figure this out. All of the individual components of this camera will work if installed in another unit. Gremlins I guess.
  • 2,326 Answers
Try to go to setup menu, select the toolbox icon 1 and select "INITIALIZE" click OK. Master reset and it should go back to normal.
Posted on Mar 26, 2008
  • 13,433 Answers
I would directly contact sony.
    Guru:
  • 1,894 Answers
1. Turn OFF cam
2. Remove the battery or the power supply
3. Turn the switch to CAMERA for about 30 sec
4. Turn the switch to OFF
5. Install the battery or power supply
6. Turn the switch to MEMORY
7. Open the LCD cover and press the RESET button ( small inner button )
8. You will be prompt to adjust date/time. Do it
9. Take some pictures
Posted on Mar 24, 2008
  • 2 more comments
  • dewan nafees ahmed Mar 26, 2008
    sorry for late reply:
    This E:91:01 indicate that the camera flash function is faulty.you need
    to replace the faulty flash unit. to get away the E:91:01 flashes on
    screen , what you can do is to do a factory reset follow by turning off
    the flash function.the screen will not show the E:91:01 and you can use
    the camera without flash function.
    I have a method to stop the E:91:01 error flashing on the screen.it
    were not solve the flash function but atleast you can use the camera
    without flash.
    1)at setup do a initialize.
    2)go to flash function to turn off the flash (must do it fast,b4 the E91:01 appear,if not you need to reset it again )
    by
    now E91:01 will never appear.you can use it like normal,be sure not to
    turn on your flash again or go to night mode.if not you need to perform
    step 1 & 2 again.hope it help.
    Apparently, if you do a Google search you will find E:91:01 error all
    over the place with many Sony digital camera models. I think Sony
    engineering needs to fix this for good and Sony QA definitely needs to
    do a better job at not selling defective pieces and messing up others
    vacations and works.
    note:: error code is normally cleared when u remove the battery. (except for the flash unit)
    also i found that
    this is a purely electrical fault.
    E 91:01 ----Charging the flash does not complete within the specified time
    tis is some problem with the charging capacitors i think..
  • dewan nafees ahmed Mar 27, 2008
    hmmm. seems like a complex problem.
    there need to be some place.
    it must be either power supply to the flash which is not supplying power enough to get it charged.
    else the flash unit itself that is refusing to get it charged.
    problem is lying in either of those two places.
    now u try to figure it out where exactly. it will need some trial and error methods manually.
I have a sony cybershot dsc w55 with error e:91:01. i have pressed the reset button and initialised the camera numerous times. the error is removed but the camera will not take a picture in auto or p mode...
E:91:01 is an error code that indicates problem with flash unit circuit in camera.
Flash unit board will be replaced to resolve this problem and temporary fix is to set flash Off quickly, before error could appear after initializing camera, hope this info will help you.
Thanks.
Oct 18, 2010 | Sony Cyber-shot DSC-W110 Digital Camera
Sony Cybershot DSC-W55 flash not working Code
GO TO SETUP MENU, SELECT THE TOOLBOX ICON 1 AND SELECT INITIALIZE CLICK OK.
Aug 10, 2010 | Sony Cyber-shot DSC-W55 Digital Camera
Hi I have a sony cybershot DSC W55 BIG PROBLEM
if you have guarantee change the lcd screen .. it is quite easier.. but the cost for changing is nearly 3/4 of the camera so better buy a new camera..
May 30, 2010 | Sony Cyber-shot DSC-W55 Digital Camera
I need another copy of the full manual Sony DSC w55
hi
you can download the manual at the folowing URL
http://esupport.sony.com/US/perl/model-documents.pl?mdl=DSC-W55&region_id=1
happy clicking
pls rate if this was any help
Jul 14, 2009 | Sony DSC-W55 Digital Camera
DSC W55 Error code E:91:01
Hi,  Its an error of flash unit(E:91:01 denots flash unit problem) which get started malfunctioning. Therefore you have to replace the FLASH UNIT ASSY.
  For changing of flash unit assy. You can contact any sony service centre nearby to you. For your convenience please visit:
www.sony.net
or
www.sonyworld.com
Here you can find contact info of nearest service centres.
Thanks for using FIXYA.
Jan 28, 2009 | Sony Cyber-shot DSC-W55 Digital Camera
My Sony Cybershot DSC W55 "7.2 mega pixel" does not flash. Error code E:91:01 ?
Please RESET your camera , go to Menu > Initialize > OK
If problem still exist you need to replace flash unit in camera.
Let me know if you need further help.
Jan 28, 2009 | Sony Cyber-shot DSC-W50 Digital Camera
Sony Cybershot W55 digital camera- needs proper USB connector.
Hello Voyager2Lcat,
You need Multi-Use Terminal Cable for DSC-W55 and its Sony Part Number is 1-829-866-51
Picture is attached as reference.
May 27, 2008 | Sony Cyber-shot DSC-W55 Digital Camera
Panoram pic with Sony Cybershot DSC-W55
its sad but the dscw55 does not have panorama effect.
Jan 21, 2008 | Sony Cyber-shot DSC-W55 Digital Camera
Cameras Logo
94 people viewed this question
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
