Question about Toro 42'' Zero Turn Lawn Mower 22hp Kawa Consumer
Need manual to see what size bolt is that holds on
Need manual toro z5000 to see what size bolt is that holds on cutter blade
  • 3,740 Answers
Hi and welcome to FixYa. I am Kelly,
It appears your model number is 74370 There are 3 bolts one for each blade and the part number is 26-0671 or 260671 for the blade mount.
Part look up:
http://www.jackssmallengines.com
then enter part number 260671 $6.31 ea.
You can not use just any bolt for this. They are hardened bolts with an NF thread. If you use a non hardened bolt the blade will fly off when the bolt shears.
This bolt is available at most all Lawn Mower Parts Supply sources. Toro uses the same bolt on most all of their mowers.
If you do not have a Lawnmower Parts Supply near by, you might be able to go to an Autoparts supply source with yet one of the other blade bolts in hand and have them match the markings on the bolt head with yours so that you have the exact replacement bolt.
Any other parts for your mower can be found here:
http://www.jackssmallengines.com/help.cfm
Use the Search model window. each line below is a drop down window
Toro
Riding
74370 <- there are numerous models up to 74704
enter your model number if different.
Thanks for using FixYa.
Kelly
Posted on Apr 27, 2010
How do you replace the drive belt on a time cutter z5000 model no 74370
Release tensioner adjuster fit new belt and readjust,could have slide slots holding the rear axle also(adjustment.)
Jul 09, 2015 | Toro Garden
Toro clutch removal
PTO clutch removal.
remove the crankshaft bolt and be prepared for the clutch to fall
if it doesn't get a soft faced mallet and tap on it
no, get some pb blaster and let is soak for a day or two
then tap a little harder
if still no you will need an air hammer
Aug 14, 2014 | Toro 110-6892 Timecutter Z5000, Z5020,...
Toro z5000 bogs to almost stalling out with minimal load
I would purchase a compression tester from auto parts store and check compression.
Oct 19, 2013 | Toro 110-6892 Timecutter Z5000, Z5020,...
Is the bolt holding the blade reverse threaded or conventional?
it's a 5/8" socket use air impact wrench to remove and install if you do not have these tools available take it to a reputable service station your safety could depend on it.
Apr 12, 2010 | Toro Lawn Mower With Toro Power Tools
TORO Z5000 zero turn mower. right side
it should hold hydralic fluid there should be a resirvour somewhere on the back along with the pump you should be able to check the level there and if you don't get the leak stopped it will lock up the whole drive system.
Aug 23, 2009 | Garden
How to take off blades in self propelled push mower
Remove the bolt holding the blade.After removing the plastic piece that should have several screws holding it.you may need to feel around or clean a bit to find them.RICHARDM69
May 03, 2009 | Toro Lawn Mower With Toro Power Tools
Toro 42''  Zero Turn Lawn Mower 22hp Kawa Consumer Logo
630 people viewed this question
Top Toro Garden Experts
Joseph Mueller
Joseph Mueller
Mike Squire
Roland W VanLue
Roland W VanLue
Are you a Toro Garden Expert? Answer questions, earn points and help others
