Question about Amana ATB1832AR Top Freezer Refrigerator
Servis M7004 suddenly stopped working
Hi there, I have Servis M7004 freezer which was working fine for more than a year and would generally make some sound. This morning I found that there was no sound.
There are three lights in top front (guess Power, Warming and Defrost). The middle one (Warning) and Poewr both are glowing now. Any idea what would have happened? My wife tried pushing Defrost button but no luck!
Any help will be deeply appreciated.
SOURCE: refrigerator will not get cold, but freezer works
i have a amana model ars26677as side by side the fan in back is running but the fridge and frezer is defrosting ?
Posted on Sep 04, 2008
  • 61 Answers
SOURCE: Amana XRSS287BB side by side fridge freezer (3 years old)
you may try hard restart by shuting the fridge off and unplugging it from the wall . plug in back in and after 5 min turn it back on . close both doors and wait one hour . check the temp. if the unit still will not respond calll the local woranty amana repairman only. hope this helps you
Posted on Oct 20, 2008
lenwest
  • 150 Answers
Make sure your fan is working ,its located behind the freezers back wall. If it is working the vent from the freezer down to the refrigerator may be blocked (usually with ice).With out a fan you have no circulation but your freezer may look likes its working,it may last 3 days.Also if you can move everything out unplug it turn it off w/ doors open untill all traces of ice are gone this will free up any clogged tubes. Good luck.
Len West
Posted on Feb 27, 2009
woodchuck789
  • 4070 Answers
SOURCE: Frost free freezer icing up
It should still be covered under the warranty.
How to check everything
http://www.acmehowto.com/howto/appliance/refrigerator/refrigerator.php
check defrost timer, defrost heater, defrost thermostat. In most newer models the timer has been replaced by an electronic control board. If the heater and thermostat are ok it’ll be the control.
You can turn the defrost timer till it clicks and everything shuts down. The heater should now come on. If it does, replace the timer. If it doesn't, check the heater and defrost thermostat. Turn the timer again till everything starts back up to end the defrost cycle.
Posted on Sep 02, 2009
SOURCE: SERVIS MO262S FROST FREE FRIDGE/FREEZER, FRIDGE NOT WORKING
servis frostfree fridge freezer not working after 2weeks holiday returned it had completely defrosted fridge & freezer power supply still connected. warning light on. done all the trouble shooting in the srvice manual still want go cold or freeze. light on in the fridge, no water in the rear tray & cleaned the overflow pipe??. Model No M0330-ALU 5yrs old. think it has 2 seperate thermostats, surely they wont both have gone at the same time???????
Posted on Oct 13, 2009
My RJ 523V-R refrigerator has worked perfectly for 8 years, but suddenly stopped cooling the fridge properly while the freezer seems ok. how can I fix this?
Often times their is a fan from the freezer section to the refrigerator section, of some brands of boxes. If the fan goes out, the refrigerator sections no longer cools.
May 23, 2014 | Electrolux Refrigerators
Servis m7684s
First listen inside the freezer section, and see if you hear the fan running. You may need to hold down the door switch to get the fan to come on. If you can hear the fan check the rear wall inside the freezer for frost accumulation. If you have frost you need to check the defrost system.
Nov 16, 2013 | Washing Machines
Servis Fridge Freezer not working
fridge appears to be working, but freezers section intermittingly keeps going off
Apr 19, 2010 | Refrigerators
Hotpoint FFA71 fridge and freezer suddenly stopped working
Sounds as though the compressor has stopped working. It feeds both compartments with control from a printed circuit above the top door.Where all your red lights are ablaze! (This can be replaced by removing the 2 screws and "clicking" out the small panel) Check that the compressor is running at the bottom rear of the fridge/freezer before anything else.
Jun 30, 2009 | Hotpoint FFA70 Bottom Freezer Refrigerator
All of a sudden stopped getting cold in the fridge portion, freezer is fine
If you completely defrost the freezer and restart the unit and it doesn't get cold in the refrig portion it could be the internal fan that moves cold air from the freezer to the frig area if it does get cold after an hour or so then it is probably the defrost coil needs replacing. I am not familar with your exact model but this senario applies to many different units.
Apr 18, 2009 | Refrigerators
Mar 30, 2009 | Amana ATB1832AR Top Freezer Refrigerator
Flashing red light
red light flashing on servis fridge freezer
Mar 19, 2009 | Freezers
Servis frostfree fridge freezer
Hi, I had that last year - It was the control board!
Oct 24, 2008 | Freezers
Servis Fridge not cold enough
Hi ruthcart1,
I'm Harvey the Master Plumber.
Your problem is: You have a free standing fridge freezer from Servis (silver) and the fridge doesn't seem to be as cold as it should be. The freezer is absolutely fine just the fridge even though you have adjusted the thermometer inside.YouI've had it maybe 3/4 years.
You're still under warranty. Modification now voids the warranty. I would call warranty repair. This should be their headache not yours.
Feel free contact me again!
Please give me a rating here at fixya.com before you sign off
Thank you,
Harvey your Master Plumber
Sep 10, 2008 | Refrigerators
Refrigerator stopped working, freezer works fine
Sounds like the evap fan is not running. The fan takes cold air from the freezer to cool the refer compartment. If the freezer is cold the compressor is running. Generally the freezer will stay cold since the cooling coils are there but it must have the fan working to get the air up to the refer area. Pull everything out the freezer and take the back panel off to view the coils and fan, etc. It's a simple easy job to change the fan. If you find the coils are a total block of ice then it's another problem... the defrost cycle isn't working. Sooo... see if the fan is running in the freezer compartment first. See http://www.partselect.com/Schematics/Maytag/AA43-57.gif for fan location, item 18 is the fan motor. Let us know what you find out.
Jan 02, 2007 | Jenn-Air JFC2089HE French Door...
Amana ATB1832AR Top Freezer Refrigerator Logo
130 people viewed this question
Top Amana Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you an Amana Refrigerator Expert? Answer questions, earn points and help others
