Question about IBM ThinkPad T30 2366 Notebook
IBM does not work
Laptop IBM ThinkPad T30 2366 was working perfect.It was sittin for a few weeks and when I tried to power it up with power adapter,I can see the light next to the battery ,laptop does n ot power up
Thank you.David
  • 1 more comment
  • david1963 Mar 24, 2008
    Thank you.David
  • Sonny_01 Mar 25, 2008
    i have the same problem with the battery light and oneother problem with the cpu speed. i have a pentim 4(M) 2 Ghz but now it works with 770 mhz. i cant work with anything with 770 mhz, too slow.
    what should i do to have back 2 Ghz of speed?
    Thank u, Sonny
  • Anonymous Mar 29, 2008
    T-30 will not start up on power cable or battery. The fan comes on but no hard drive activity. Just dark screen! I have removed the back of the thinkpad and unpluged and pluged the cpu. No help. Thats an old aircraft fix. I have cycled power button several times, no help. It was running perfectly then just failed to start up.
  • 55 Answers
I guess the problem is with your laptop battery, chek your battery with other T30 2366, u will get solution that your battery is dead.
thanks
chirag
Posted on Mar 24, 2008
  • 58 Answers
Try memory or replace system board
6ya staff
SOURCE:
IBM ThinkPad T40, when connected to docking station the laptop will randomly stop working with USB connected items like mouse, keyboard, printer all connected to USB ports on docking station.
Try a power adapter with more amperage. When you connect a dock, the 3 amp adapter that comes with IBM laptops will not have enough power for lots of add-ons. You'll need the 4 amp adapter.
Oct 15, 2013 | IBM ThinkPad R51 Notebook
Tip
IBM Laptop Battery Power Saving Tips
How to try to extend the battery life are much concerned by many laptop users. Utilizing some small skills and minimize unnecessary waste of battery during the using process can make you full use of your laptop battery power.
The engineers of IBM personal computer business division give vast laptop users some good suggestions here to ensure that you can maximum extend laptop battery utility time. Therefore, it will improve your work efficiency; let you enjoy mobile office work and entertainment pleasure without limits.
IBM batteries on sale :
IBM thinkpad t40 Battery £ 37.52
ibm thinkpad t41 battery US $ 41.24
ibm thinkpad r60 battery. US $ 71.27
IBM ThinkPad T60 Battery £ 38.51
* Turn down the brightness of the screen. At the same time, although IBM ThinkPad laptop keyboard is equipped with lights, ThinkLight, but in order to save power, it is better to turn on it when under darkness conditions.
* When not using the wireless receiver device, turn it off please.
* Some users like opening CD or DVD to play music anytime, the power of battery will flow away quietly along with the music playing. Suggest everybody turn on the music only under the situation that they do want to enjoy the music.
* When the battery during using process, try to fully charge and discharge the battery.
* Try to avoid using it under high temperature and low temperature, for example, when you enjoy sunshine on the beach, please don’t leave your laptop in the car to enjoy SAUNA.
* Use proper AC adapter for your ThinkPad laptop.
* Use the IBM ThinkPad battery Battery MaxiMiser management software you select the most suitable for the extension of the power program.
* Use the IBM ThinkPad battery management software – Battery MaxiMiser, select the power extension program which suitable for you.
* Setup the standby time of monitor, hard disk and system sleep time, because it is no need to let your laptop still running at full load when you are at non-working stage.
* Under the Intel SpeedStep technology effect situation, the processor based on the current load situation adjusts the speed automatically to save battery power overall.
In fact, the laptop battery is a spiritual guy, after got expert advices, please treat it properly, it will bring you to enjoy a better mobile life.
battery info via:
http://www.sales-battery.com
http://www.global-battery.co.uk
on Jun 04, 2010 | Computers & Internet
Lenovo thinkpad plugged in not charging is there a problem
laptop plugged in not charging:
1. Take the battery out of the laptop & try to turn on the laptop using power adapter only. If the computer turns on, then the battery is defective & needs to be replaced.
2. Make sure the IBM ThinkPad X40 power adapter is not defective. Test the output voltage of the power adapter using a voltmeter. Compare the voltmeter reading to the nominal value written on the adapter or the laptop.
3. Make sure the DC jack is not loose or broken. A loose DC jack will need to be re-soldered. A broken one will need to be replaced.
4. If you have another processor which is compatible with your laptop's model, try swapping processors & test to see if the laptop will work.
5. The power button could be bad
6. The motherboard could be defective & needs to be replaced.
Jan 01, 2013 | IBM Lenovo ThinkPad X40 Notebook
Ibm thinkpad R52 laptop no powering on, adapter is ok.
There could be a problem with the battery. A fast check to determine whether you have a problem with the power adapter, power cord or the laptop's battery is to turn off the laptop, remove the battery, connect the power adapter, turn on the laptop & see if it works.
If the laptop works directly from the power adapter with the battery removed, then the power adapter is good. In this case we can suspect that the battery is defective & needs to be replaced.
If this did not work, try also disassembling the laptop & make sure that all main components are seated properly. Also make sure that all ribbon cables interconnecting the various components of the laptop are tightly connected.
Dec 26, 2009 | IBM Lenovo ThinkPad R52 Motherboard -...
IBM thinkpad will not turn on ...had been used for 2 hous earlier..could heat have been the problem
Could have been a power surge that affected it by try a few things to be sure:
unhook the battery and only have the ac adapter hooked up. If you have a green light on the ac adapter then you know your getting power from that.
Try turning on the laptop and if you still get nothing then the motherboard is definitely bad.
Jun 27, 2009 | IBM ThinkPad T40 2373 Notebook
I keep losing my connection - IBM Thinkpad t42
Are you using IBM SW or Windows to manage the wireless? Occassionally, the IBM SW has issues with certain model routers and encyrption types.
You can also try unchecking the "Allow Computer to turn this device off to save power" in the adapter properties and
Adjusting the power on the wireless device to the max. By default IBM sets it in the middle to conserve power.
Mar 03, 2009 | IBM ThinkPad T42 Notebook
Laptop Battery Not Charging
first try in other power socket if it works then you have to replace the power adapter...
Feb 18, 2009 | IBM ThinkPad R50e Notebook
Problem with audio in ibm thinkpad t30,2366-y1b model
T30- no sound altho SOUND MAX drivers installed...
Try Control Panel, Sounds, Sounds (tab), choose a sound toward bottom of list. press the BLACK PLAY ARROW...if BLACK SQUARE appears at the arrow, your sound is installed $\& probably OK...
NOW,,,insert a musiv CD. then press the VOLUME BUTTON, (2nd one over from the THINKPAD button, & you should get sound aplenty !!
Dec 13, 2008 | IBM ThinkPad T30 2366 Notebook
Ibm thinkpad no power with ac power adapter but works with battery
If prior to this it works intermittently with the AC adapter, it means the connection from the adapter power unit to the motherboard was lost and this is a typical problem with the Thinkpad. It needs a re-soldering job and not something that one can do without a proper repair manual on how to open the laptop. Try googling your problem and find out if someone has the same experience and managed to resolder by him/herself.
Oct 18, 2008 | IBM ThinkPad T41 Notebook
IBM Thinkpad laptop wont start up
hi dear
Hi RD, Ouch! Have you tried taking the battery out to see if it will run on AC power when the battery is not installed? Sometimes a bad battery can kill the system.
Do you have a meter that you can measure the output of the AC adapter with to see if it is correct? If not, any chance you could swap adapters with someone for a while to see if theirs works on your computer and vice versa? A local shop may also be able to test your adapter to see if it's working.
oke
regards, cropp
Mar 27, 2008 | IBM ThinkPad T41 Notebook
IBM ThinkPad T30 2366 Notebook Logo
205 people viewed this question
Top IBM Computers & Internet Experts
Ekse
Alun Cox
Thomas F. Schneider
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
