Question about Maytag Atlantis MAV7551 Top Load Washer
Will fill with cold water but not hot
Hot water will run only for seconds, then shut off. can hear humming noise from fill valves. will fill on cold water fine.
  • 1,557 Answers
The hot water inlet valve is shot replace it
Posted on Apr 28, 2010
My Fisher Paykel GWL 15 will only fill if Hot wash is selected. Should I call a service technician? Thanks Glenn
Try to swap the plugs and hoses to the hot /cold solenoids see if that works the hot valve with cold water if work you need to buy a cold valve.
Jan 24, 2012 | Fisher Paykel EcoSmart GWL15
Water wont go in washer when on cold /cold or warm cold but will fill on hot cycle. Only cold water is connected. i dont even have hot hose connected---has worked fine for a year on cold/cold. Now has a...
The inlet valve on the cold water inlet is clogged, dirty or jammed. You need to remove the inlet valve and clean the valve and filter. use back flushing with brushing to clean the filter.
the hum you hear is of the coil working but is not opening to allow water into the system.
Also you can switch the inlet valve from the hot line if needed .
check this link for removing the inlet valve:
http://www.espares.co.uk/advice/washing-machines/a/7/1408/how-to-replace-the-inlet-valve-on-a-washer-dr.html
Sep 13, 2011 | Washing Machines
We can only use hot water in our Whirlpool 7.5kg WFE1070BD 1000RPM - how to we shut off the hot water and use cold water? We have tried only cold but the machine will not operate. Please help. Many...
Turn off the water to the machine. Disconnect the cold water hose from the back of the machine and put it in a large bucket. Turn on the water to see if you get full-pressure cold water from the hose. If not, the shut-off valve or other plumbing has a problem.
If you do get cold water from the hose, check the strainer inside the hose fitting on the back of the washer. Clean it if it is clogged. If you still don't get cold water in the machine, you have a problem with either the solenoid valve or the cold water fill contacts in the timer (the timer won't start until the tub is up to the selected level, but if the valve isn't opening or the supply line is otherwise blocked, the machine will never fill). Sometimes in this case you can hear the solenoid valve humming (normally the sound is masked by the running water).
If the problem is a clogged strainer, clean out the hot water strainer also.
I find I get better wash results with warm water (runs both hot and cold for the wash cycle). The soap is more active than in cold water, so I don't need quite so much, and the machine doesn't take as long to finish a cycle since it fills faster. Of course, the cold water has to be running to get the energy savings compared to hot only.
Jun 06, 2011 | Whirlpool Ultimate Care II LSQ9549L Top...
Water comes up to tub but doesn't fill the tub. Help and when I pull the knob I hear a humming noise
Hi and welcome to FixYa, I am Kelly.
The humming noise your hearing is the inlet water valve solenoid. Before proceeding try switching between warm cold and hot to see if any of those selections give you water. If you get water on either hot or cold then you probably have debris in the inlet screens of the water valve where the hoses connect. Turn off the water. remove BOTH hoses noting hot and cold installed positions and the use a thin knife blade on the outer edge of the screens to lift the inlet screens out of the water valve body. Wash then under slowly running water rubbing them between your fingers. Reinstall the screens. Connect the hoses in their original positions, turn on the water and test your water fill again switching between warm, hot and cold. This should get you going. If your still having problems after doing the above; please respond with MODEL: number and I will help you.
Thanks for choosing FixYa,
Kelly
Feb 17, 2011 | Maytag Washing Machines
Hot or cold water won't come on
If there's no water at all, make these checks:
  • Is there water getting to the machine?
    Check to be sure that someone did not turn off the water, usually the faucet or faucets are on the wall behind the machine.
  • Is the water-volume selector switch set properly and are the control panel buttons pressed in all the way?
  • If you have a Maytag® washer, is the fuse (if there is one) in the control panel at the lid-switch bracket blown?
  • Is there a faint buzzing or humming noise coming from the water-inlet valve? (The water-inlet valve is the device on the washing machine that the fill hoses are attached to.) If you can't hear anything, the water-inlet valve may not be getting any power. If you can hear some noise and there's water present, you may need to completely replace the water-inlet valve.
Aug 03, 2009 | GE WDSR2080D Top Load Washer
My washer won't fill with cold water...only the hot works.
Cold water solenoid on the water mixer valve is likely shot.
Change the valve.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Mar 17, 2009 | Kenmore 3.2 cu. ft. Plus Top Load Washer
Can't get the cold water to turn on. I have 1. switched hoses 2. no kinks 3. water is turned on Model 1220
Aug 17, 2008 | Hoover Washing Machines
Washing machine wont fill
the humming noise is usually the inlet valve energised but no water there to come in. i appreciate you have checked. the other possibility is that the appliance has not pumped out completely and the noise you hear is the drain pump energised but stuck due to perhaps a foreign object in it. fault is unlikely to be inlet valve
Apr 01, 2007 | Maytag Atlantis MAV8551 Top Load Washer
Maytag Atlantis MAV7551 Top Load Washer Logo
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
