Question about Scott LCT37SHA TV
TV got static shock and died, but red LED stayed lit. Local vendor described diags as microprocessor - BGA- is messed up (busy trying to process a volume-up command and 'stuck' ) and I should get new motherboard, TV is Scott LCD37'' LCT37SHA
  • peasep May 01, 2010
    Thanks, the board I was directed to is p/n E3761-058010-4 WITH Tuner, is that what I need? Also, where do I find a board to replace the broken one?
  • peasep May 02, 2010
    yes, thanks
  • Scott Master
  • 11,800 Answers
The red LED tells you that the power source of the tv is - al least partially - functional. Most likely what the local vendor said is correct - the first part that fries in an electrical shock is the microprocessor, taking the entire board with it.
Unfortunately finding parts will be difficult since Scott is a no-name chinese assembler , usually using LG/Philips designed parts. Your only hope is for a second hand part found on eBay - some thing like this one http://cgi.ebay.com/SCOTT-LG-6870C-0060F-LCT37SHA-LCD-CONTROLLER-LC370WX1-/260590781558?cmd=ViewItem&pt=LH_DefaultDomain_0&hash=item3cac6bc476
Posted on May 01, 2010
  • Azrael SRL May 01, 2010
    Sorry, without actually looking at the tv i can't be absolutely sure.  But the local vendor appears legit so probably he identified the correct part.
    As i said the most likely place to find parts for it is on sites (or even shops - if you can find ones close to your location) that sell second hand parts - i don't think that replacement parts are imported for sale thru retailers.
  • 4,889 Answers
Its not the motherboard. Its the audio/video main board and if the microprocessor is dead then you have to get a new board as solid state electronics cannot be repaired coz they are embedded into the board.
Posted on Apr 27, 2010
  • eagle338
    eagle338 May 02, 2010
    Yes that is it. Try to get a new board if you can find it. A lot of stuff found online or refurbished/used pieces.
    Sai.
  • eagle338
    Please accept the solution If I have answered all of your questions by
    clicking the accept button next to my solution.
    Thanks,
    Sai.
Need a code to program an innovage jumbo remote to an RCA tv. nothing fancy just the tv code please
The Innovage Jumbo users manual lists over two dozen RCA TV remote codes. They are:
000, 003, 004, 005, 007, 009, 011, 015, 048, 082, 092, 094, 096, 098, 101, 102, 103, 107, 113, 125, 129, 167, 179, 187, 188, 191, & 194.
To program your remote by entering a code, follow these steps:
  1. Turn on your TV.
  2. Press and hold the CODE SEARCH button for at least 3 seconds until the red LED lights up and stays lit.
  3. Press the TV button on the remote so that the LED blinks once and then remains solid red.
  4. Enter the first set of 3-digit codes from the list. The LED will blink once every keypress. After the 3rd digit, the red LED will turn off indicating that the code was recognized for the device. If the code was not compatible, the LED will flash several times and you need to return to step 2 to try that code again or to try the next code in the list.
  5. After the LED has turned off, aim the remote at the TV and press ON/OFF. If the device turns off, you have used the correct code and the remote was successfully programed. If the device does not power off, return to step 2 and try again with the next code in the list.
If you can't be bothered to enter each of those codes one at a time, you might consider the auto-search function.
To have the remote try each TV code it knows one at a time, follow these steps:
  1. Turn on your TV.
  4. Press the ON/OFF button slowly and repeatedly until the TV turns off. The LED will blink once each time you press the ON/OFF button.
  5. Once the TV turns off, press the ENTER button to store the code and the LED will turn off.
I hope that helps.
Dec 09, 2009 | Innovage Jumbo Remote Control
I have a jumbo universal remote,how do I programit to an rca tv?
  1. Turn on your TV.
  1. Turn on your TV.
I hope that helps.
Nov 23, 2009 | Innovage Jumbo Remote Control
Need code for cable box(motorola)and tv(rca) can
The RCA TV codes for an Innovage Jumbo Remote are: 000, 003, 004, 005, 007, 009, 011, 015, 048, 082, 092, 094, 096, 098, 101, 102, 103, 107, 113, 125, 129, 167, 179, 187, 188, 191, & 194.
  1. Turn on your TV.
There are so many codes to try, you may want to try the auto-search function that I am going to describe below.
I don't see a code for a Motorola cable box, so I advise using the auto-search function for CABLE or SAT.
To have the remote try each CABLE or SAT code it knows one at a time, follow these steps:
  1. Turn on your cable box.
  3. Press the CABLE or SAT button on the remote so that the LED blinks once and then remains solid red.
  4. Press the ON/OFF button slowly and repeatedly until the cable box turns off. The LED will blink once each time you press the ON/OFF button.
  5. Once the cable box turns off, press the ENTER button to store the code and the LED will turn off.
To program the remote for your TV, repeat this process starting with turning the TV on, then follow the steps substituting the TV button for the CABLE or SAT button.
I hope that helps.
Nov 16, 2009 | Innovage Jumbo Remote Control
I have an innovage jumbo remote did not loose it!!! LOST THE DIRECTIONS TO PROGRAM IT.
You can program the Innovage Jumbo Remote by entering three digit codes, or by using the auto-search function.
  1. Turn on your TV.
  1. Turn on your TV.
To program the remote for your VCR, repeat this process starting with turning the VCR on, then follow the steps substituting the VCR button for the TV button.
I hope that helps.
Oct 31, 2009 | Innovage Jumbo Remote Control
I bought a universal jumbo remote and i followed instructions i to program it to my Jvc tv but it does not work can u help?
Make sure you try every code in the list for your JVC TV.
The codes for your Jumbo Universal Remote to control a JVC television are 013, 054, 055, 060, 065, 067, and 089.
  1. Turn on your TV.
  1. Turn on your TV.
I hope that helps.
Sep 24, 2009 | Innovage Jumbo Remote Control
Need code for Innovage jumbo universal remote for a rca tv
  1. Turn on your TV.
  1. Turn on your TV.
I hope that helps.
Sep 17, 2009 | RCA TruFlat 27F520T 27" TV
I have a Jumbo universal remote by Innovage and I need the programing codes for the tv. Do you have them???
To program your remote by entering a code from a manufacturer's list, follow these steps:
  1. Turn on your TV.
  1. Turn on your TV.
I hope that helps.
Aug 21, 2009 | Innovage Jumbo Remote Control
How do I program innovage to my tv?
  1. Turn on your TV.
I hope that helps.
Aug 02, 2009 | Innovage Jumbo Remote Control
Red led stays on after turning off.
Aren't you talking about the standby led? cause that is perfectly normal... when it's on it means you can turn the TV on by remote, usualy it goes away when you turn the TV off manualy by pressing the OFF button on the set, but is this really your problem?
Jun 23, 2006 | Hitachi 53FDX20B 53" Rear Projection...
Scott LCT37SHA TV Logo
178 people viewed this question
Top Scott Televison & Video Experts
Radames Pagan
Radames Pagan
Sp Gupta
Are you a Scott Televison and Video Expert? Answer questions, earn points and help others
