30.1.7 error on a hp lj4100 - Computers & Internet
  • 33 Answers
This code means: Flatbed optical-unit-motor failure
Steps to check this failure
1. Verify that the optical-unit lock is in the unlocked position.
2. Verify that the flatbed optical unit moves during initialization when the power is turned on.
-Or-
Use the control-panel diagnostic menu to test the scanner motor. See "Diagnostic tests below.
3. Contact HP Customer Care for further assistance.
Posted on Mar 24, 2008
55.00.00 error message display on the control panel
Error 55 is a major Engine or DC controller issue.
HP LaserJet Enterprise Printers 55 00 0x and 55 0x 06 Errors
Try spares from salvaged printers. Look for "working pull from damaged unit". Of course reconfirm model and spare compatibility.
Printer Works RM1 9371 000 DC Controller As M775 mfp
HP LaserJet DC Controller For M775 Printer RM1 8898 - USD70+shipping
Mar 18, 2016 | HP LaserJet M775DN Laser Multifunction...
Hp lj 4100 50.2 error
is this error on a lj4100 or on a cm1017?
if on a 4100- then the complaint is that the fuser has not reached the required temperature in the allocated time- replace fuser kit with CORRECT fuser ( lm4100MKIT) and not a 4000 fuser which is not the same even though they look like each other.
if its a cm1017 then the error is poor communication with the thermal resistor measuring the fuser temp. again replace fuser kit to resolve
Dec 17, 2013 | HP LaserJet CM1017 MFP All-In-One Color...
49 error on HP laserjet 3050
Internal Embedded Software Error. Manual says to power off for 30 seconds. Power it on and let it initialize. If the error persists you will need a tech.
Aug 15, 2011 | HP LaserJet 3050 All-In-One Printer
We have a networked HP Laserjet 4100; a new PC was added and the printer does not show as available on the network for this new Dell Vostro 460. The driver was installed and still nothing. Can you suggest...
Thank you for contacting FixYa with your printer inquiry.
This is usually a pretty common network problem for printers and other devices on a network. If you network uses DHCP that automatically assigns IP address's you may have developed a conflict when you installed your new printer.
You will want to print a configuration page from both printers to determine what the IP address of each is then manually configure independent IP address for each to preclude further conflicts.
Refer to this excellent HP document page on the LJ4100 Jet Direct Card for manual configuration:
http://www.printerhacks.com/how-to-setup-an-hp-laserjet-printer-with-the-built-in-jetdirect-network-card/
Hope this helps helps. Please keep us updated and remember to rate this answer.
May 10, 2011 | HP LaserJet 4100 Printer
My hp Laserjet 3330 Had error 79
Firmware error. Unplug the power cord. Wait 30 seconds. Plug it in, power it on. If the error comes back, you will have to upgrade the firmware.
May 20, 2010 | HP LaserJet 3330 All-In-One Printer
How to change the display language on LJ4100
Request to follow the link below;
http://www.laseredge.ca/servicemode.htm
Warm regards,
Anirban Mazumdar
Oct 09, 2009 | HP Office Equipment & Supplies
HP LJ4100 network printer
Hi dpotter,
I presume at least the printer's Ready light is on. Click on Start|Settings and select Printers and Faxes. Right Click on the printer and select Use Printer Online (if printer is online, then this should be "Use Printer Offline").
Rgds
S88
Dec 10, 2008 | HP LaserJet 4100 Printer
Hp6180 all in one has an error 30
Here is a list of all HP service error codes. Hope it helps :)
Oct 06, 2008 | HP Photosmart C6180 All-In-One InkJet...
Camara hp m627
la camara cuando enciende dice error lens: m627-30 que significa eso y como puedo repararla
Jul 09, 2008 | HP PhotoSmart M627 Digital Camera
Computers & Internet Logo
523 people viewed this question
David Payne
David Payne
